shawnsheridan wroteUnfortunately, I`m not able to send PMs now as i`m no allowed. My version is NBTevo_R19144l. How can I do the conversion so I can use ConnectedDrive. Do you have any other method of speaking with you? Instagram maybe or something like that. I can leave you mine.Car can have Europe conversion. Full screen depends on firmware versions. Your PM function is disabled. Send one when enabled.
2.2MVIEWS
3.9KREPLIES
121APPRECIATES
837ACTIVE PEOPLE
2 hours agoLAST POST
11-28-2025
11-28-2025
11-28-2025
11-28-2025
Iustaz wroteBy Europe Conversoin, I meant Navigation, Language, etc., not ConnectedDrive. ConnectedDrive is function of SIM Card being supported in your country. You can always leave message for me on Bimmerfest.Unfortunately, I`m not able to send PMs now as i`m no allowed. My version is NBTevo_R19144l. How can I do the conversion so I can use ConnectedDrive. Do you have any other method of speaking with you? Instagram maybe or something like that. I can leave you mine.
12-04-2025
12-04-2025
Thank you very much for the sharing. It’s clear that a lot of time and effort went into it. I recently bought my car and while researching battery replacement I found this forum and became a member. I have ISTA+ 2.39.20, but I don’t have any coding software. Is there a place on the forum where I can find it?
By the way, my car is a 2016 X3 20i sDrive.
12-05-2025
12-05-2025
ayhan_34 wroteI think you meant ISAT 4.39.2x. Your PM function is disabled. Send one when enabled.Thank you very much for the sharing. It’s clear that a lot of time and effort went into it. I recently bought my car and while researching battery replacement I found this forum and became a member. I have ISTA+ 2.39.20, but I don’t have any coding software. Is there a place on the forum where I can find it?
12-05-2025
12-05-2025
shawnsheridan wroteİngilizcesi:I think you meant ISAT 4.39.2x. Your PM function is disabled. Send one when enabled.
Yes, I meant 4.39.20 😇. Thank you very much. I also installed E-Sys yesterday, I think it was version 2.8.0.
I haven’t tried either of them on my car yet. Honestly, I’m a bit nervous about using them. I’m going to disable the start-stop feature. Is there a guide on the forum for my car?
12-06-2025
12-06-2025
ayhan_34 wrotePM sent. You can't disable it, but you can set it to Default to the off position or remember Last position by FDL Coding one of these:İngilizcesi:
Yes, I meant 4.39.20 . Thank you very much. I also installed E-Sys yesterday, I think it was version 2.8.0.
CAS => TC_MSA_DEFAULT_OFF (or TCM_MSA_DEFAULT_OFF) = aktiv
CAS => TC_MSA_MEMORY (or TCM_MSA_MEMORY) = aktiv
12-06-2025
12-06-2025
Thank you very much. I’ll try it as soon as possible and let you know. Also, thank you for the private message.
12-06-2025
12-06-2025
ayhan_34 wroteThank you very much. I’ll try it as soon as possible and let you know. Also, thank you for the private message.
01-04-2026
01-04-2026
Happy New Year! Just added a F25 X3 to the stable and am looking to start coding on F-chassis (well versed in E-chassis) Can someone push me a link to the latest E-SYS and whatever else I'll need to get up and running? I'm looking to do a HK retrofit so I'll need to be able to FO code. I really appreciate it.
Also, are there any concerns having E-sys installed on the same laptop as INPA/ISTA? I still need to have access to code my e92 335is. I was able to connect to my X3 using the ENET cable I got and don't mind changing a few settings as i go back and forth.
Thanks again!
Thanks again!
01-04-2026
01-04-2026
apgambino wrotePM sent. No issue having both E-Sys and INPA/ISTA.Happy New Year! Just added a F25 X3 to the stable and am looking to start coding on F-chassis (well versed in E-chassis) Can someone push me a link to the latest E-SYS and whatever else I'll need to get up and running? I'm looking to do a HK retrofit so I'll need to be able to FO code. I really appreciate it.
Thanks again!
01-10-2026
01-10-2026
shawnsheridan wroteHi, could you please send me a link to the e-sys that supports v4.57.12_PSdZData? I can't find the full version anywhere (maybe 3.40.2?), and I need to update HU-NBT in my F10 LCI, because i have a problem with unstable bluetooth. Thank you very much.I think you meant ISAT 4.39.2x. Your PM function is disabled. Send one when enabled.
01-10-2026
01-10-2026
XvvvYX wroteYour PM function is disabled. Send one when enabled.Hi, could you please send me a link to the e-sys that supports v4.57.12_PSdZData? I can't find the full version anywhere (maybe 3.40.2?), and I need to update HU-NBT in my F10 LCI, because i have a problem with unstable bluetooth. Thank you very much.
01-14-2026
01-14-2026
Hopefully my PM works will appreciate a download link to 3.40.2 . Thanks
01-14-2026
01-14-2026
diagnosticcomputer wroteYour PM function is disabled. Send one when enabled.Hopefully my PM works will appreciate a download link to 3.40.2 . Thanks
01-28-2026
01-28-2026
I have an 2014 X3 LCI. I've replaced the headlight and I'm having issues with it (no high beam etc). I've used ISTA to teach in, but no luck, fails. I've been told I need to code/program in the headlight? I can't see this option on my ISTA under programming.
integr actual level f025-17-03-505 and integr level target f025-21-03-520..
Ista 4.26
anyone able to advise what it's called / under in programming?
cheers (and sorry if in wrong topic)
Ista 4.26
01-28-2026
01-28-2026
m34 wroteWhen you Program and ECU, you Encode it (VO COde) as part of the Programming Process.I have an 2014 X3 LCI. I've replaced the headlight and I'm having issues with it (no high beam etc). I've used ISTA to teach in, but no luck, fails. I've been told I need to code/program in the headlight? I can't see this option on my ISTA under programming.
Ista 4.26
You should do this with E-Sys, and then use ISTA only for Teach In.
01-29-2026
01-29-2026
shawnsheridan wroteThanks for your reply Shawn. Forgive my for my ignorance on this....When you Program and ECU, you Encode it (VO COde) as part of the Programming Process.
With e-sys, do I need to go into the VO section to make any adjustments first, or can you go to the headlight module / TMS and then click code?
Is there any good guides on how to do this? Is there a specific version of e-sys I should use?
Sorry for the questions, and thank you for any additional advice.
Much appreciated 🙏
01-29-2026
01-29-2026
m34 wroteE-Sys - Flashing Guide v.1.0.1.pdf:Thanks for your reply Shawn. Forgive my for my ignorance on this....
Much appreciated 🙏
https://mega.nz/#!p9JQhAwZ!JJ9ptw8Titz8tZbLobnZ61g5uAJjkJcnSUvG81nYMsw
Understand that for a non factory fitted ECU, its I-Step Shipment is most likely not the same as the car's I-Step Shipment. The correct I-Step Shipment is one where the ECU being flashed has HWEL in svt_soll that is Black, not Red / Blue.
So after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it.
PM sent.
01-30-2026
01-30-2026
shawnsheridan wroteIs it necessary to update ECU? The headlight is a replacement (not a retrofit etc). If the shipment and act i-step is different, and initially showing as blue, is that a problem? can I still do the VO / Code?E-Sys - Flashing Guide v.1.0.1.pdf:
PM sent.
(Sorry again for the questions, being in IT for 14 years I thought i'd have some understanding, but this is new
)01-30-2026
01-30-2026
m34 wroteMaybe not. If you can inject CAFD and VO Code it, then you can skip Flashing it:Is it necessary to update ECU? The headlight is a replacement (not a retrofit etc). If the shipment and act i-step is different, and initially showing as blue, is that a problem? can I still do the VO / Code?
(Sorry again for the questions, being in IT for 14 years I thought i'd have some understanding, but this is new)
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
02-19-2026
02-19-2026
Hey
shawnsheridan
New to the group can I also get ista+ and pdz?
Thank You.
Thank You.
02-19-2026
02-19-2026
Not sure but im ask anyone in this post. But has anyone got LCI tail lights to turn on as DRLS? through bimmercode i already coded some stuff but I didnt see any option to automatically turn them on like the F30 group.
