2.2MVIEWS
3.9KREPLIES
121APPRECIATES
837ACTIVE PEOPLE
1 hour agoLAST POST
02-19-2026
02-19-2026
shawnsheridan user avatar
shawnsheridan
Supreme Allied Commander
13,562 REP
50.8K POSTS
Tresfal wrote
Hey shawnsheridan's user avatarshawnsheridan
New to the group can I also get ista+ and pdz?
Thank You.
PM sent.
03-05-2026
jejupods user avatar
jejupods
44 REP
Hey hoping to get the latest copies of everything. I need your help to accidentally break my car :P
03-05-2026
shawnsheridan
13,562 REP
50.8K POSTS
PM sent.
03-05-2026
jejupods
44 REP
03-15-2026
TMKnights user avatar
TMKnights
0 REP
Hi,
Probably wrong place to post my issue on here but I bought a new head unit from BMW for my 2017 230xi. After installation, there's sound and visual display but I cant adjust volume, some of my options in the menu are gone, back up camera not showing, bluetooth is missing. My question is what's my next step? Do i need coding like bimmercode?
03-15-2026
shawnsheridan
13,562 REP
50.8K POSTS
TMKnights wrote
Hi,
What is VIN?
03-16-2026
TMKnights
0 REP
Wba2h9c34hv642387
03-16-2026
shawnsheridan
13,562 REP
50.8K POSTS
TMKnights wrote
Wba2h9c34hv642387
You have ENTRYNAV Head Unit. You need to inject CAFD and VO code it. And if you want Sat Radio (SiriusXM) you need to import your original 6F SDARS FSC Code in donor head unit.
03-16-2026
TMKnights
0 REP
Thanks for the info. Sorry completely noob to coding. How would I inject CAFD and VO code it? Thanks again
03-16-2026
shawnsheridan
13,562 REP
50.8K POSTS
With E-Sys:
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Left-Click on desired HU_ENTRYNAV => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on HU_ENTRYNAV (the ECU itself not the underlying CAFD) => Select CODE.
03-16-2026
TMKnights
0 REP
Ok. How do I connect my BMW with E-Sys?
03-16-2026
shawnsheridan
13,562 REP
50.8K POSTS
You need E-Sys, PSdZData Lite, and an ENET cable.
03-16-2026
TMKnights
0 REP
Ok. Where do I download PDsZData Lite and E-Sys?
03-16-2026
shawnsheridan
13,562 REP
50.8K POSTS
Your PM function is disabled. Send one when enabled.
03-16-2026
TMKnights
0 REP
Ok will do. So in layman’s terms, my head unit needs to be coded to my VIN even though the head unit was bought from BMW?
03-16-2026
shawnsheridan
13,562 REP
50.8K POSTS
Seems so. Otherwise, all functions would be working if it came precoded. Coding is not about writing VIN to head unit; it's about aligning all the coding inside the head unit to your car's FA (Vehcile Order).
03-17-2026
TMKnights
0 REP
Hi again,
So I went to the dealership to have it recode the headunit but now the idrive freezes. The error code is S 0273 and S 0275. What does this mean? And how to fix this?
Thanks
03-17-2026
shawnsheridan
13,562 REP
50.8K POSTS
TMKnights wrote
Hi again,
Thanks
Dealer coded new HU, you left, and now it freezes up?
Where are you getting these? error codes from?
03-17-2026
TMKnights
0 REP
Yes dealer coded new HU. Codes went thru but the idrive freezes. Codes were reported by the technician report. Technician suspects battery but can’t access becuz I have a customized subwoofer box that I now need to remove for access
03-17-2026
shawnsheridan
13,562 REP
50.8K POSTS
No idea. Those are not standard fault codes.
03-26-2026
JP_Stang user avatar
JP_Stang
0 REP
I would love to have the latest ISTA+ and PSDZData please! I know have to wait until my PM function is active, so I will send you a PM as soon as it is. Thanks!
03-26-2026
shawnsheridan
13,562 REP
50.8K POSTS
Thread has nothing to do with ISTA. Your PM function is disabled. Send one when enabled.
