2.6KVIEWS
47REPLIES
25APPRECIATES
10ACTIVE PEOPLE
04-22-2026LAST POST
03-08-2026
03-08-2026
kimona user avatar
kimona
108 REP
pgw85706 wrote
Today, I installed the front plate bracket (flipped upside down) using the wire cable zip ties then mounted the plate to the bracket. Works great and looks good..
OK! Pls. post a photo if you can.
03-08-2026
pgw85706 user avatar
pgw85706
'26 X3 M50, '20 540 iX, '24 Tundra
62 REP
The bracket is flipped. 3 cable ties are used. A large one that goes around the grill's vertical center post (I drilled 2 small holes at the top of the bracket to thread the tie) and 2 smaller ties that use the bracket's lower two mounting holes and thread around the grill's horizontal frame.
Appreciate1
03-08-2026
03-08-2026
rmorin1249 user avatar
rmorin1249
1,828 REP
2.8K POSTS
Stupid question, but where did you get wire cable ties? I have only seen plastic. Thanks. I live in MD and also have to have a front plate. I know some refuse to mount theirs but I had a run in with the law and was threatened with a ticket if I didn't install one on a MINI I owned years ago.
03-08-2026
pgw85706
62 REP
My ties were plastic. Kimona reported the steel wire ties. I agree though that the plastic will get brittle over time and break. It is why I installed a couple extra.
03-08-2026
kimona user avatar
kimona
108 REP
SYS-Bimmer suggested wire ties. I actually used nylon zip ties. I tightened the ties just enough to snug the bracket without stressing the plastic grillework. The bracket is firmly in place.
03-09-2026
rmorin1249
1,828 REP
2.8K POSTS
May be overthinking but how much does this location reduce airflow to the radiator? Don't have my X3 yet. Are the vents shutters that open and close?
03-09-2026
Artdnj user avatar
Artdnj
483 REP
Nice diy design, the tow hook varients are pretty sweet too although they cost a bit more than the DIY
03-09-2026
pgw85706
62 REP
Negligible. No.
Appreciate1
03-09-2026
03-09-2026
pgw85706
62 REP
The tow hook variants often interfere with the proximity sensors and give false alerts.
03-09-2026
rmorin1249
1,828 REP
2.8K POSTS
pgw85706 wrote
Negligible. No.
I've advised my CA to NOT install the front plate. Going to try this mod. Thanks.
03-09-2026
pgw85706
62 REP
Smart move. Plus I like that the plate is lower on the front of the vehicle and not as noticeable as the ugly distraction that it is. I think you will be pleased with the look and that you're not drilling holes in your new car. And make sure they do not install any dealer decals on the rear!!
Appreciate1
03-09-2026
03-09-2026
kimona user avatar
kimona
108 REP
Some dealers install the front licence plate bracket unless the customer specifically requests not to have it installed.
I remember refusing delivery of a car years ago when the dealership decal had been installed on the paint even though I had requested not to have one installed in the contract.
03-10-2026
Artdnj user avatar
Artdnj
483 REP
I hear that's common, what was the outcome, apology I assume?
03-10-2026
pgw85706
62 REP
I always write into the purchase agreement that the front plate bracket and dealer decals are not to be installed.
03-10-2026
SYS-Bimmer user avatar
SYS-Bimmer
31 REP
My dealership installs their branded license plate bracket in the rear. It's a fine quality bracket, so instead of replacing it with another, I painted over their branding. It's hardly legible unless you take a close up look.
03-10-2026
pgw85706
62 REP
I usually find that those brackets cover portions of the plate hiding things like state name, stickers for validity, etc, making them not legal. Just something to check.
03-11-2026
SYS-Bimmer
31 REP
I had done the same when I purchased an X3 from the same dealership back in 2015. No issues. My Volvo plate bracket, on the other hand, did cover up about half the stickers.
04-21-2026
rmorin1249
1,828 REP
2.8K POSTS
pgw85706 wrote
kimona wrote
This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
I did the same thing using heavy duty zip ties.
Appreciate1
04-21-2026
04-21-2026
Artdnj user avatar
Artdnj
483 REP
can any of these options be used in a auto car wash? I know, I know, I live in the NE and during the winter I have to as there are no hand wash services near my home.
04-21-2026
pgw85706
62 REP
I have not taken my car through the car wash but it should do just fine. It is pretty securely attached.
Appreciate1
04-22-2026
04-22-2026
dzar user avatar
dzar
41 REP
I used black metal zip ties (like those used on fences) as they blend in well and should hold up great in the weather. Been through the car wash a few times and no issues.
Appreciate1
04-22-2026
04-22-2026
Artdnj user avatar
Artdnj
483 REP
does the ties wear away the paint at the contact points with paint? I would think there is a lot of stress due to wind while driving.
Appreciate1
