2.6KVIEWS
47REPLIES
25APPRECIATES
10ACTIVE PEOPLE
04-22-2026LAST POST
03-03-2026
03-03-2026
kimona user avatar
kimona
108 REP
I really don't want to drill holes in my front bumper. Any suggestions out there?
03-03-2026
kimona user avatar
kimona
108 REP
There are actually 2 points under the bumper (using 2 existing screws) that could be used as mounting points for a front licence plate bracket.
I thought about something similar to these designs:
03-03-2026
pgw85706 user avatar
pgw85706
'26 X3 M50, '20 540 iX, '24 Tundra
62 REP
On our 540, we use the tow hook screw to mount a special bracket.
Appreciate1
03-04-2026
03-04-2026
SYS-Bimmer user avatar
SYS-Bimmer
31 REP
I ordered a STO N SHO Front License Plate Bracket from Amazon. It's quite expensive and way over priced for what it is ($99.99), but it does offer an alternative to drilling.
The attachment points are two screws under the car.
Appreciate5
03-04-2026
03-04-2026
kimona user avatar
kimona
108 REP
Thank you for the information and the great photos!
03-04-2026
rmorin1249 user avatar
rmorin1249
1,828 REP
2.8K POSTS
Looks good but what is the ground clearance?
03-04-2026
pgw85706
62 REP
Was it necessary to attach the plastic OE bracket to the S-N-S frame to hold the plate?
03-04-2026
SYS-Bimmer
31 REP
The ground clearance is the same as the bottom of the front bumper, which is about 10 inches from the ground.
03-04-2026
SYS-Bimmer
31 REP
No. I have the OE bracket on until my license plates arrive. It'd look funny driving around with X shaped thingy on front.
Appreciate2
03-04-2026
03-04-2026
SYS-Bimmer
31 REP
Another thing that I don't like about the bracket, other than that it's overly priced, is that the license plate and the bracket can be easily stolen by a simple pull of the pull pin underneath.
03-05-2026
kimona user avatar
kimona
108 REP
Yes. I like the attachment, but am concerned about the quick release feature. Is there some way you can delete the pull pin to make the fitting more permanent?
03-05-2026
visualexstasy user avatar
visualexstasy
146 REP
3m 50lb double sided tape
03-05-2026
kukugege user avatar
kukugege
62 REP
Carbonio look best, but also the most expensive option
Appreciate1
03-05-2026
03-05-2026
SYS-Bimmer
31 REP
I'm not sure it's a good thing to find a permanent fitting solution. The product warning states that the bracket needs to be removed when taking the car into a carwash. If you never use a carwash or ever see a need to detach the bracket for whatever reasons, then one permanent solution could be soldering the area where the rods slide into or using a loctite.
Appreciate1
03-05-2026
03-05-2026
kimona user avatar
kimona
108 REP
This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
Appreciate3
03-05-2026
03-05-2026
SYS-Bimmer
31 REP
That'd work! I'd change the zip tie with steel wires, though, as zip ties get brittle with time and snap off.
Appreciate1
03-05-2026
03-05-2026
pgw85706
62 REP
Dang, clever, well done. Might be worthy of a patent! Thanks.
Appreciate1
03-06-2026
03-06-2026
JoeyO user avatar
JoeyO
593 REP
1.2K POSTS
That looks much better that the $100 and $180 options.
Appreciate1
03-07-2026
03-07-2026
rmorin1249
1,828 REP
2.8K POSTS
I like this.
03-07-2026
rmorin1249
1,828 REP
2.8K POSTS
Looks like a good option at a GREAT price. Well done. Does it interfere with any of the shuttered vents?
03-07-2026
kimona user avatar
kimona
108 REP
I don't think so.
03-08-2026
pgw85706
62 REP
Today, I installed the front plate bracket (flipped upside down) using the wire cable zip ties then mounted the plate to the bracket. Works great and looks good..
Appreciate1
