2.5KVIEWS
47REPLIES
25APPRECIATES
10ACTIVE PEOPLE
04-22-2026LAST POST
03-03-2026
03-03-2026
I really don't want to drill holes in my front bumper. Any suggestions out there?
03-03-2026
03-03-2026
There are actually 2 points under the bumper (using 2 existing screws) that could be used as mounting points for a front licence plate bracket.
I thought about something similar to these designs:
03-03-2026
03-03-2026
On our 540, we use the tow hook screw to mount a special bracket.
lucycan
03-04-2026
03-04-2026
I ordered a STO N SHO Front License Plate Bracket from Amazon. It's quite expensive and way over priced for what it is ($99.99), but it does offer an alternative to drilling.
The attachment points are two screws under the car.
kimona
pgw85706
markap326
+2
03-04-2026
03-04-2026
SYS-Bimmer wroteThank you for the information and the great photos!I ordered a STO N SHO Front License Plate Bracket from Amazon. It's quite expensive and way over priced for what it is ($99.99), but it does offer an alternative to drilling.
03-04-2026
03-04-2026
SYS-Bimmer wroteLooks good but what is the ground clearance?I ordered a STO N SHO Front License Plate Bracket from Amazon. It's quite expensive and way over priced for what it is ($99.99), but it does offer an alternative to drilling.
03-04-2026
03-04-2026
Was it necessary to attach the plastic OE bracket to the S-N-S frame to hold the plate?
03-04-2026
03-04-2026
rmorin1249 wroteThe ground clearance is the same as the bottom of the front bumper, which is about 10 inches from the ground.Looks good but what is the ground clearance?
03-04-2026
03-04-2026
pgw85706 wroteNo. I have the OE bracket on until my license plates arrive. It'd look funny driving around with X shaped thingy on front.Was it necessary to attach the plastic OE bracket to the S-N-S frame to hold the plate?
pgw85706
kimona
03-04-2026
03-04-2026
Another thing that I don't like about the bracket, other than that it's overly priced, is that the license plate and the bracket can be easily stolen by a simple pull of the pull pin underneath.
03-05-2026
03-05-2026
SYS-Bimmer wroteYes. I like the attachment, but am concerned about the quick release feature. Is there some way you can delete the pull pin to make the fitting more permanent?Another thing that I don't like about the bracket, other than that it's overly priced, is that the license plate and the bracket can be easily stolen by a simple pull of the pull pin underneath.
03-05-2026
03-05-2026
3m 50lb double sided tape
03-05-2026
03-05-2026
Carbonio look best, but also the most expensive option
Bones Mccoy
03-05-2026
03-05-2026
kimona wroteI'm not sure it's a good thing to find a permanent fitting solution. The product warning states that the bracket needs to be removed when taking the car into a carwash. If you never use a carwash or ever see a need to detach the bracket for whatever reasons, then one permanent solution could be soldering the area where the rods slide into or using a loctite.Yes. I like the attachment, but am concerned about the quick release feature. Is there some way you can delete the pull pin to make the fitting more permanent?
kimona
03-05-2026
03-05-2026
This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
SYS-Bimmer
pgw85706
lucycan
03-05-2026
03-05-2026
kimona wroteThat'd work! I'd change the zip tie with steel wires, though, as zip ties get brittle with time and snap off.This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
kimona
03-05-2026
03-05-2026
kimona wroteDang, clever, well done. Might be worthy of a patent! Thanks.This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
kimona
03-06-2026
03-06-2026
kimona wroteThat looks much better that the $100 and $180 options.This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
kimona
03-07-2026
03-07-2026
kimona wroteI like this.This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
03-07-2026
03-07-2026
kimona wroteLooks like a good option at a GREAT price. Well done. Does it interfere with any of the shuttered vents?This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
03-07-2026
03-07-2026
rmorin1249 wroteI don't think so.Looks like a good option at a GREAT price. Well done. Does it interfere with any of the shuttered vents?
03-08-2026
03-08-2026
kimona wroteToday, I installed the front plate bracket (flipped upside down) using the wire cable zip ties then mounted the plate to the bracket. Works great and looks good..This is what I did this morning: I simply turned the front bracket upside down and zip-tied it. Fits snugly.
kimona
