BKM0066 wroteHello. Are these with spacers? If not, what offset did you used?245/40/r20 275/35/r20
Thanks:coolpics:
FSociety wroteDid you end up putting springs? I'm really on the fence about it. Don't want to have to switch them out every time I go to the dealership and am worried it will give it a bumpy ride.H&R springs too ?
Everybody on springs lol i'm next
airbagit13 wroteI did but I have an X4 M40i not an X3, so ride will vary depending if you have EDC/DDC or Standard SuspensionDid you end up putting springs? I'm really on the fence about it. Don't want to have to switch them out every time I go to the dealership and am worried it will give it a bumpy ride.
FSociety wroteCalled both dealerships in my area and both of the Service Managers told me not to put on springs or coil overs. I love the look of the lowered x3 but don't think it's worth the harsher ride. I've had cars on coilovers and airbag hydraulics and am tired of the harsh ride. Granted those were dropped a LOT more then an inch or two so it was much worse.I did but I have an X4 M40i not an X3, so ride will vary depending if you have EDC/DDC or Standard Suspension
Ride is harsher, I actually went from 20s to 19s due to how bad ride was.
I don't see ANY benefits after adding springs all I noticed was lowered nice stance.
I would do BC-Racing Coilovers and Dealers don't care about springs or suspension.
Actually if they do switch dealership
bimmer ///man wroteWhat’s the wheel spec? Are you using wheel spacers?20" BBS CH-R (For sale if anyone is interested)
szymonr wroteAny rubbing inside front fenders on full lock turns? Cool photos btw!20x8,5 / 10
H&R springs
20mm spacers
elf8888 wroteYes, but only on rear drive with full lock left. All other directions clearAny rubbing inside front fenders on full lock turns? Cool photos btw!
vestaviascott wroteHey I checked one of the offset calculator websites and noticed that the center bore of X3= 72.6. And the X5 is 74.1. That would mean that it would be loose could cause vibrations. Not sure if you could find hub centric rings to keep them truly centered.I've found a guy on CL selling his X5 wheels - set of 4 255/25/19 with 5 spoke BMW alloys. Will these work on the F25? I have the pre LCI 2012 xdrive with Sport package. Its currently rocking 245/50/18s all around.
I'm just not sure if you can run anything wider than 245s on the front.
alpwhite46 wroteThere was a post that was removed above mine that was a spammer. I didn’t quote it because I didn’t want it copied again.///Mposter wroteYou alright homie?I hope you ^ get banned you spammer.
