03-24-2014, 06:57 PM | #1 |
Veteran U.S. Army
62
Rep 771
Mid cycle oil change
So I'm about to get the mid cycle oil change done and from what I've read on the forums the F10 M5 takes 9 quarts? Is that exactly 9 quarts or should I get an additional quart?
03-29-2014, 06:55 PM | #5 | |
Rep 1,622
I would recommend 0W-30, Castrol brand, European formula (often referred to as German Castrol). German Castrol 0W-30 (code 06244) can be purchased from amazon. After you buy it, just verify it says European Formula on the bottle before you use it. I am currently using 0W-30 since my break-in service. A few other members on here are using this as well. The car warms up faster, and some say the motor runs quieter at idle. BMW recommends owners to always use Castrol brand oil. You can put any brand (meeting correct specs such as LL-01) fully synthetic 0-40 in the car, as it's an approved alternate weight for the S63TU engine. However, I would recommend Castrol brand, and would recommend 0W-30 weight.
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
03-29-2014, 07:29 PM | #6 |
Rep 1,622
Here is what Castrol 0W-30 looks like.
03-29-2014, 09:42 PM | #7 | |
Veteran U.S. Army
62
Rep 771
So far using Mobil 1 is just an experiment, but I gotta tell ya, I'm loving it! This is what I have seen so far. Engine warms up quicker. I'm getting better MPG. Turbos running cooler. (I had to do a Google search to make sure the turbos are oil cooled) The fan(s) are quieter after shutdown with multiple pulls over 100mph! So far the engine seems to be running more efficiently, but I'll see how it holds up in 8000 miles. |
04-26-2014, 06:00 AM | #8 |
Rep 305
