View Poll Results: When did your rear brake pads really need changing for the first time?
0 - 10,000 miles 2 4.00%
10,001 - 20,000 miles 7 14.00%
20,001 - 30,000 miles 15 30.00%
30,001 - 40,000 miles 12 24.00%
40,001 - 50,000 miles 6 12.00%
50,001+ miles 8 16.00%
Voters: 50. You may not vote on this poll
      01-10-2014, 10:01 AM   #1
Tangsta
Drives: '22 x3 M40i
When did you actually change your rear brake pads for the first time?
I'm due for service soon, and the CBS indicates that I need rear brake pads serviced in 4000km (so at 24,400km = 15,250mi)
I've read a few anecdotes about the CBS being calibrated incorrectly, so I just wanted some rough stats for when I bring the car into BMW.
      01-10-2014, 01:56 PM   #2
Anfänger
perennial neophyte
Drives: SUV
Have you seen this thread? It's a bit dated, but it does include a lot of user data on the life of rear pads:
http://x3.xbimmers.com/forums/showthread.php?t=645517
      01-10-2014, 08:18 PM   #3
greg2step
X3 Owner/Driver
greg2step's Avatar
Drives: 2018 X3 M40i
http://x3.xbimmers.com/forums/showthread.php?t=806891
This is more current
My rear said 1400 miles remaining from about 13000 until my service center reset the computer at 22000. do not trust that at all. If it annoys you have it reset. Either way, you can only determine brake life the old fashioned way - measure the pads.... esp on the rear.
I will answer the poll when i change mine. still on orig front and rear - 24000 miles - I don't have a long commute so I have not racked up the miles like I have on past cars. kind of nice for a change.
2018 X3 M40i G01 | Phytonic Blue | Mocha | Premium+Exec | Driver Assist | Adaptive M Suspension
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience [traded in]
2008 328XI E91 Sportwagon l Sparkling Graphite [traded in]
      01-11-2014, 01:12 PM   #4
NordicBMW
NordicBMW's Avatar
Norway
Drives: 2012 X3 / 2013 X1
My rear pads have indicated replacement in 5000 KM since I turned 40 000 KM. Now I am at 47 000 KM and the car still tells me to replace in 5000 KM. I'll have them check the pads physically in a month's time when the car is due for some other work but my plan is not to do anything until the service indicator tells me I have less than 3000 KMs left.
      01-13-2014, 03:40 PM   #5
Tangsta
Drives: '22 x3 M40i
Thanks. I've seen both of the linked threads, but the majority of replies in both threads were current mileage plus remaining mileage before service according to CBS.
I was hoping that a lot of the people who made those responses have actually had their pads changed by now and can answer this poll.
I plan to have BMW reset it when I bring the car in... I just want to be able to make a case to have them measure it and adjust the cbs accordingly under warranty.
50,000km sounds a lot better than 24,000km.
I don't think mine has stopped counting down at all though
      01-13-2014, 10:51 PM   #6
96_Impreza
96_Impreza's Avatar
12
Drives: 96 Impreza,07 Vette,11 X3 35i
90% city mileage.
Rear pads replaced at 18,522 mileage, 16April2013.
2011 X3 35i Service Invoice dated 7Jan2014, Mileage 28,477.
Verbatim:
"...Front pads are 3MM and rotors are below spec of 26.4MM.
L/F is 26.3MM and R/F is 26.3MM.
Replaced the front brake pads and sensor.
Replaced the front rotors.
Cleaned brake wells...."
Warranty.
Total Invoice $0.00
      01-15-2014, 09:30 AM   #7
cheesebag
Debadged and Alpine Weiss!
cheesebag's Avatar
Drives: 2012 F25 X3 Msport
At about 10000 miles, My dealer said this was within normal range and I complained that it was not. Got them sorted in the end.
      01-24-2014, 04:41 PM   #8
Tangsta
Drives: '22 x3 M40i
Car went in this morning - 21000km
7.5mm left on the rear pads.
Reset CBS to 24000km
      01-25-2014, 11:02 PM   #9
Mingstar88
Drives: BMW X5 40i 2020
car is at about 26,200km, system saying change rear pads in 1700km. i guess ill have to schedule an appointment soon
      01-27-2014, 08:03 AM   #10
walendvay
Drives: '11 F25 28i; '13 E84 35i
I have ~40,000mi on my '11 X3. A year ago, I had the count down stop at 1400mi. Dealer checked pads and stated I had plenty of pad left. They reset the countdown timer to 6000mi or so.
Now, the countdown timer is stuck at 3100mi. Been that way for about 2-3000mi.
Will probably make an appointment after winter unless I hear a "grind"
There are brake sensors in addition to the mileage countdown, correct? (like there were on the E83?)
      09-25-2014, 02:43 PM   #11
Tangsta
Drives: '22 x3 M40i
Update:
When I left off back in January, I had 21,000km on the odometer and had the service indicator reset to 24,000km remaining.
Fast forward to 2 weeks ago, the indicator had dropped to 0km left and dropped by 50km every time I started the car (even if I only drove 5km last trip).
I finally got the car in today (31,000km on the clock) with the cbs indicating that the brakes were due 700km ago.
The dealership measured the rear pads at 4.5-5mm remaining (another 5-10k km to go), reset the CBS, and applied a software update that's supposed to fix the rate that it counts down.
      09-25-2014, 03:15 PM   #12
Rodion
Finland
27
Drives: X3 (F25)
No need for change here yet. 54 000 km on the clock, fronts are due 90 000 km and rears still have 34 000 according to OBC.
      12-01-2014, 05:32 AM   #13
jeschiotz
Drives: BMW X3
Here is what I found:
My car had 57k KM on the counter. It started to give me warnings on the rear pads. The thing is that it has a sensor build in so when pads wears of it will also at one point start to wear of that sensor. At this point a yellow warning will be shown. Before this point You can go into the menu yourself and reset the value for next service. Also,if you change the pads yourself the service could be resetted to new pads. When the yellow warning shows it wil start to count down. If you change the pads at this point,remember also changing the sensor(only 1, on the right wheel)If not, timer could not be reset as the sensor has a variable resistor giving the countdown.
      12-01-2014, 09:49 AM   #14
Mingstar88
changed my rear around 32000km ish. was advised by the tech after the install that it could've lasted another 3000km
      12-01-2014, 10:11 AM   #15
ReturnZero
Drives: 2013 X3 35i M-Sport
I just ticked over to 51000 miles. Computer has been saying pads will be due in about 3k miles since around 45k. Not sure when I'll have to do it, guess I'll just wait for the actual sensor to go off. Bummer that it had to wait until my warranty went out though.
      12-01-2014, 12:17 PM   #16
Crashnbrn5
Drives: 2016 335i GT M-Sport
I drive HARD!!, so BMW changed mine at 26,000 miles. I'm proud of that too! lol, maybe front brakes at 36k miles.
      12-03-2014, 03:43 PM   #17
5against8
Drives: F80. 3 pedals.
Had my rears changed at 32k and haven't changed fronts yet (currently 43.5k-ish), and the fronts will probably last until at least 50k.
all "k"s refer to k-miles, not km
(somewhat) related question, how long has anyone been able to stretch their first set of TIRES! (the only thing we actually have to pay for right? I almost got to 40k, but I probably should have changed them at 30k)
Current: '16 F80 BSM/SO 6MT | '17 F54 Clubman S [Wife's]
Previous: '14 E84 28i, Valencia/Terra/X-line, '12 F25 35i ZAP, Jet/Chestnut, JB Stage 1, '88 E24 635CSi, '00 S4 Imola/Black Stg II APR/Milltek/AWE & some garbage GM SUVs!
      12-03-2014, 03:45 PM   #18
5against8
Mine has been at 3k miles for front pads for a bit also, but just had them measured at about 9mm I think, so they should last awhile.
      02-02-2015, 03:02 PM   #19
Tangsta
Drives: '22 x3 M40i
Finally had my rear pads and rotors changed at 36,600km with 3mm left.
A bit disappointing that the brakes have such a short life... hopefully the next set is a little better.
      02-02-2015, 08:16 PM   #20
Upstate_X3
Drives: 2015 X3 xDrive28i
2015 BMW X3  [0.00]
Just turned in my 2013 with over 49,000 miles and still had original front and rears. According to the on-board system rears were due at 59,000 and fronts at 79,000.
In terms of the tires, replaced them around 30,000 with non-RFT. I felt the ride was way better.
2015 BMW X3 xDrive28i Deep Sea Blue Metallic / Leather Oyster Nevada
2013 BMW X3 xDrive28i Vermillion Red Metallic/Leather Nevada Mojave, Retired with 49,750 miles
      02-02-2015, 08:26 PM   #21
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
8,000 miles for my pnero rear tires. I think the wear rating is 220 though. The michelins are over 400. Either way thinking of a square setup so I can rotate. The staggered setup is not so nice on my pocket book.
      02-02-2015, 08:26 PM   #22
E92LNGCGY
Drives: F97/Q5/982 GT4
If you don't mind me asking how much was the cost? Did you change both front and rear? I am due for both and wondering what they charged you. I am also in Calgary.
Last time they checked I had about 5mm left.
