      02-21-2013, 07:24 PM   #1
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
Update: Rear Brakes - service indicator
2012 x3 28i, 25,000 km. Rear brake service indicator signaling to service rear brakes (pads perhaps)
Normal? Thinking this is early?
Thanks
Ok, just got my first service done. Re: rear brakes (system called for servicing) result: 9.5mm pad remaining. BMW answer - " as per puma measure #52904112-03 requires prog/code" (software issue, brakes fine.)
Front brakes - 11.5mm.
I also learned why rear pads wear faster!. BMW sets more braking power to rear wheels to reduce "nose dive" effect...! I.e. The front of vehicle dipping during braking...
Also had them check clatter/rattle from center beam on sunroof. Cause: plastic divider hitting glass. Solution: felt tape on divider. Seems to have fixed rattle.
Wind noise from driver side pillar. Cause: gap in middle of the drivers gutter strip. Solution: strip removed and adjusted. Fixed wind noise.
Hope this is of benefit to others.
Cheers!
      02-21-2013, 07:44 PM   #2
Hornet_Rider
Drives: X3 35i 2011 M-Sport
Same here, 30000km on mine and 2k left on the indicator...
      02-21-2013, 11:24 PM   #3
centexE9x
Drives: e9x coupe
Sounds about right. There are a few models that are having CBS errors that cause services to come up earlier than they are due. Have them check pad depth and reset the CBS data to the correct pad depth If not due.
      02-22-2013, 07:43 AM   #4
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
I'm at 41,000km and just had my annual oil/filter/cabin filter etc changes. Brakes were part of the inspection also and the work order says I still have roughly 7mm left on front & rear pads (down from 12mm or 13mm, can't recall what he said they started at).
Dave
      02-22-2013, 01:00 PM   #5
cheesebag
Debadged and Alpine Weiss!
cheesebag's Avatar
Drives: 2012 F25 X3 Msport
My rear pads ACTUALLY needed changing at 10000 miles!!! managed to negotiate them at the dealer eventually although they insisted this was normal wear!!!!
      02-22-2013, 01:07 PM   #6
epiphone3
Drives: 2013 BMW X3 35i
Extrapolating from my mileage and service display, I anticipate having to change rear pads on my X3 M-sport by about 34,000 - 35,000 km. Seems like this car does work the rears pretty hard. My old 323i (E90) is on pace to do about 95,000 km on its first set of brakes.
      02-22-2013, 08:58 PM   #7
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
Going in for service in 2 weeks, hopefully just computer error. you would think front brakes go before the rear!
      02-23-2013, 02:55 AM   #8
HighlandPete
Drives: BMW F11 535i Touring
Don't forget we can't compare our brake wear rates in modern vehicles to older designs. Brakes are now used a lot more in normal driving, within DSC, features like traction control and cornering brake control.
If you have the Performance Control option, then expect rear brake wear to be very fast if you drive with a bit of pace.
In modern automobiles, the wheels on an axle are connected by a differential – a special gear that adjusts for this difference in length. BMW Performance Control takes this individual control a step further by changing engine output and if necessary applying braking force: the outer wheels get greater drive power, the inner less, and all four can engage with maximum traction. The BMW X3 literally drives into the curve, for an even greater sense of dynamic driving and excelling stability.
Brakes can be being applied to selected wheels far more than a driver will be using the brake pedal.
HighlandPete
      02-25-2013, 11:38 AM   #9
gdstan55
Drives: X3 xDrive35i
My rear brake pads are due for replacement in another 3,000km, about 29,000km. Front pads have another 18,000km to go.
      03-02-2013, 12:19 AM   #10
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
Update
Cheers![/quote]
      03-02-2013, 09:28 AM   #11
noka
Drives: 2013 x35i M-Sport
Cheers!
"Wind noise from driver side pillar."
Just for reference, was that A or B pillar?
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
      03-02-2013, 11:21 AM   #12
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
Pillar between windshield and driver door Window.
      03-02-2013, 11:37 AM   #13
noka
"A", tnx.
      03-04-2013, 09:39 AM   #14
epiphone3
Cheers!
[/QUOTE]
Very interesting... the software issue for your rear brakes sounds like a common occurance since it has a Puma case associated already. Will have to keep that in mind for my next service to make sure they don't change my rear pads unnecessarily early.
      03-05-2013, 06:44 PM   #15
FX3OK
FX3OK's Avatar
11
Drives: 2012 X3 28i
Very interesting... the software issue for your rear brakes sounds like a common occurance since it has a Puma case associated already. Will have to keep that in mind for my next service to make sure they don't change my rear pads unnecessarily early.[/QUOTE]
Very true, I can see folks getting stung with early pad replacement if service depth. doesnt pipe up...
      03-06-2013, 11:48 AM   #16
greg2step
X3 Owner/Driver
greg2step's Avatar
Drives: 2018 X3 M40i
computer on my X3 has says rear brakes due in 1400mi - its said that for approx 2500 miles so far. I am waiting for it to light up and tell me to schedule.
2018 X3 M40i G01 | Phytonic Blue | Mocha | Premium+Exec | Driver Assist | Adaptive M Suspension
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience [traded in]
2008 328XI E91 Sportwagon l Sparkling Graphite [traded in]
      03-06-2013, 02:46 PM   #17
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
Mine have the rear brakes replaced around 24,000km...... front brakes replaced less than 11,000km due to excessive squeaking noise.....
      03-06-2013, 02:54 PM   #18
cooldude00
Drives: x3 2.0d
have done 13000 miles.. another 6000 miles to go apparently
it's here!!!
      03-06-2013, 02:59 PM   #19
Dechy
Drives: 2011 X3 35i M
Judging from iDrive; change required around 35000KMs
      03-06-2013, 08:24 PM   #20
bigblackwolf
Hong Kong
Drives: BMW X3 xDrive28i
Done 16300km and service indicator says to replace rear brake pads in 43000km. So in total that is almost 60000km.
Mostly short trips combined city, mountain and highway.
      03-07-2013, 10:02 PM   #21
TreeSkier
Drives: 2022 X5 45e
I'm experiencing the same thing. It's been showing 1400 mi till service for the rear brakes for over 2000 mi so far. I'm at 22,500 mi at this point.
      03-15-2013, 03:07 PM   #22
mrbardman
Drives: X3
Mine is a 2012 2.0d with 24000km.
Was in for my first service today, oil change. Yesterday my rear pads indicated 8000 km left.
During today's service they measured the pads and then reset the indicator to 28000 km!
Apparently the software is not calibrated correctly?
