2.2MVIEWS
3.9KREPLIES
121APPRECIATES
837ACTIVE PEOPLE
3 hours agoLAST POST
07-18-2012
07-18-2012
BMWLVX user avatar
BMWLVX
5 REP
If anyone on Mac is using Parallels, you may encounter a problem when trying to connect to your X3. I resolved this issue by opening "Virtual Machine>Configure…>Hardware>Network 1" and set it to Ethernet. The default was "Shared Network" which didn't work. This was the only way I could get the Connection via VIN to work.
Once connected, I followed the instructions given by April1 and was able to code the following on my X3 2.0d 02/2012 (Europe):
3000 HMI, 78:
EFF_DYN_SPORT_CID (Power/Torque meters that appear under Vehicle Information and the Sport popup visual as a selectable item.)
CONNECTED_DRIVE (I see this as the container for the "online browser" stuff so I'd enable this either before or at the same time as enabling them.)
SPEEDLOCK_X_KMH_MIN (Video In Motion Part 1)
SPEEDLOCK_X_KMH_MAX (Video In Motion Part 2 – the handbrake option was already disabled)
3003 TELEFON_TELEMATIK_ONLINE, 50:
ONLINE_BROWSER
(This shows up under ConnectedDrive menu as "Internet" as is a web browser)
ONLINE_BROWSER_LIVE (This shows up under ConnectedDive menu as "BMW Live" and will ask you to enter your location. I entered "Other Country" so I think I was limited with the options I received in here: News, Weather, Settings. Other country settings may give you more.)
I was able to connect to the Online stuff with an iPhone using tethered bluetooth internet. Live asked me to register using an email address but I just skipped this step. I probably won't use the online stuff that much, but good to know that it's in there and BMW want to charge you a small fee to enable it.
I saw another option that makes me wonder if video over USB is disabled and can be enabled. This is the one:
CDMM_USB_VIDEO
Kommentar=Switch for the video buttons in the new Audioplayer HMI (CR7752)
The values are "none", "first_usb", "second_usb", "both". Currently it's set to "none".
The option above this one is:
CDMM_USB_HMI
Kommentar=Switch for the new Audioplayer HMI (CR7752)
The values are "new" and "old". It's set to "new".
Can anyone shed some light on these for me? Google turns up nothing.
07-18-2012
shawnsheridan user avatar
shawnsheridan
Supreme Allied Commander
13,562 REP
50.8K POSTS
BMWLVX wrote
...I saw another option that makes me wonder if video over USB is disabled and can be enabled. This is the one:
CDMM_USB_VIDEO
CDMM_USB_HMI
To get video, the 6FL USB AUX-In Port needs to be switched with a USB AV-In Port, and then a Video connection made from it to the CIC. I'm not sure if after than 6NR is still needed, but if it is, the FSC Code needs to be obtained and programmed into the CIC which is several hundred dollars.
07-18-2012
BMWLVX user avatar
BMWLVX
5 REP
Damn to that anyway. I may enable it anyway to see if it does anything. :lol:
This is what I don't get. We know the iPhone can pass audio and album art to the CIC over USB. Why not video? Why the need for a replacement USB port?
07-18-2012
April1 user avatar
April1
Love All
178 REP
BMWLVX wrote
....I was able to connect to the Online stuff with an iPhone using tethered bluetooth internet....
Did you check that after establishing internet over bluetooth, you continue to get BMW Assist? Are you able to send google map locations to Nav? Are you able to use BMW Remote?
I am asking this cause I read it somewhere that making internet available this way will disable BMW Assist? Hope that is not right.
07-18-2012
shawnsheridan
13,562 REP
50.8K POSTS
You can not have BMW Live and BMW Assist simultaneously. They can not coexist. BMW Live is slightly better in that you gain Web Browser, Google Street View, and Google Panoramio, but because you loose BMW Assist, with that you lose MyInfo and with that the ability to send maps to the car.
07-18-2012
April1 user avatar
April1
Love All
178 REP
Exactly, that was my understanding too. Also if one wants to revert back, one has to contact BMW to reactivate.
07-18-2012
jdg857 user avatar
jdg857
11 REP
I was successful last night coding the wish list I had put together. It was exciting.
Thanks to April1 and others for all the work. There are many more items to explore in there... I just need more time.
07-18-2012
April1 user avatar
April1
Love All
178 REP
Did you use the Copy_CAF and Setup utilities?
07-19-2012
BMWLVX user avatar
BMWLVX
5 REP
I didn't have BMW Assist to begin with so this wasn't a factor for me.
07-19-2012
alexg62 user avatar
alexg62
19 REP
I'm not into coding yet, but may decide to try it out if someone could find out if there an option to turn WeatherBand. BMW used to have this available in X3, but it seems to be no longer there in 2013 models.
07-19-2012
BMWs user avatar
BMWs
18 REP
Do you have NAV? I don't have NAV or BMW Assist so not sure if I can activate. Still trying to install Esys Program so can't try yet.
07-19-2012
jdg857 user avatar
jdg857
11 REP
I did use the copy_CAF and it works great. I didn't use the setup utility. The cable is very nice and works great. thanks. I am running windows 7 home premium and had trouble with the ZGW search, but was able to link up without it.
Right now I am putting all the functions from the CAF folder into a spreadsheet. I plan on looking at all the cafd files and want to eventually input all the functions on the spreadsheet. I don't know how useful it will be, but for some reason I just want a list of everything.
There were two anomalies that i found for the KOMFORTSCHLIESSUNG_FB and the KOMFORTSCHLIESSUNG_PA to get them to work the settings were activ / Werte=00.
TPMS psi and temp not working, just showing dashes.
Power and Torque meters working but in KW and Nm, even after changing the settings in BKOMBI. There must be another setting that needs to change.
07-19-2012
April1 user avatar
April1
Love All
178 REP
Copy_CAF_v2 is very useful and handy utility to keep backups. Use it whenever you cahnge the caf files.
ZGW search gives problem on Win 7, try to use following winsock utility, it might fix your issue.
TPMS will shw dashes when the car is stationary but will pickup values when you drive for a while.
Anyway, you are doing great. Congrats. Be careful, change only one function at a time, so that you can revert back if found not working.
07-19-2012
Alligator69 user avatar
Alligator69
1 REP
rgx3 wrote
I read the F25 cheat sheet codes and didn't see one for setting the Parking Ventilation. As of now the option is greyed out and can't be selected. Maybe Am I just ignorant? I can set the two timers. Thanks.
Do you try to set it on with the engine on? Try it again with the engine off.
That should do the trick, no coding needed.
07-19-2012
Alligator69
1 REP
April 1, you're my hero. I think I'll wait for the service that is in next couple of months and then will start trying....
07-19-2012
BMWs user avatar
BMWs
18 REP
I'm having trouble running the setup bat file. This is the file structure April1 told me to use:
BMWInstall will have 2 sub folders and two files:
2_46.3 psdzdata
E-Sys_3.18.4
EDIABAS.INI
Setup_3.18.4.v2.bat
2_46.3 psdzdata folder will have 7 sub folders
E-Sys_3.18.4 will have two sub folders and a file:
EST
E-sys 3.18.4 (IS THIS THE .EXE FILE OR FOLDER?)
E-Sys 3.18.nfo
Also where does the EDIABAS folder go? Any help would be appreciated!
07-19-2012
jdg857 user avatar
jdg857
11 REP
2_46.3 psdzdata
E-Sys_3.18.4
EDIABAS.INI
Setup_3.18.4.v2.bat
EST
E-Sys 3.18.nfo
EDIABAS goes into C:\EDIABAS, make sure the C:\EDIABAS\BIN\EDIABAS.ini is set to interface = ENET
07-19-2012
BMWs user avatar
BMWs
18 REP
Thanks, I moved EDIABAS file. Any comments on the other questions or why batch file won't run? I have the folders named correctly.
07-19-2012
jdg857 user avatar
jdg857
11 REP
the winsock utility didn't solve the issue. the error says "Component MSWINSCK.OCX or one of its dependencies not correctly registered: a file is missing or invalid". thanks for your help.
07-19-2012
BMWLVX user avatar
BMWLVX
5 REP
So I enabled CDMM_USB_VIDEO to "both" and what I got was this video icon appearing in the player menu and I was able to browse my iPhone for Movies, Video Podcasts, etc. No video from it, just sound. So as Shawn pointed out, a cable is required to go from the replaced AV USB port to the CIC unit. Not that I ever doubted him of course ;)
EDIT: I don't suppose adding a media snap-in adapter is going to magically make the video appear?
07-19-2012
April1 user avatar
April1
Love All
178 REP
For the same reason, dealers don't install BMApps later if you had not ordered it. Laying that extra piece of cable seems to be a difficult task.
07-19-2012
April1 user avatar
April1
Love All
178 REP
MSWINSCK assembly is a 32 bit dll and will not run on 64 bit system. I gave you a utility to get it registered on 32 bits system . Some have expressed that utility worked for them.
