zhoudaniell wroteThen you must update PSdZData. PM sent.Sorry for the late response, was out of town.
When I try to read the HKFM_LS module, I get an error that says
"File for cafd_000007c8-007_001_023_ not found!"
pretty much won't let me read it and open it so I can recode.
2.2MVIEWS
3.9KREPLIES
121APPRECIATES
837ACTIVE PEOPLE
YesterdayLAST POST
05-11-2018
05-11-2018
05-12-2018
05-12-2018
Hello,Shawnsheridan i have X3 F25 LCI fabrication date Jan 2017, Is my first bimmer will you be so kind to tell what do I need to start doing some coding on my car.
Thank you very much for your effort .
05-12-2018
05-12-2018
voli wrotePM sent.Hello,Shawnsheridan i have X3 F25 LCI fabrication date Jan 2017, Is my first bimmer will you be so kind to tell what do I need to start doing some coding on my car.
05-13-2018
05-13-2018
Has anyone come across a fault code B7F87F "CIC: coding data implausible" and/or B7F8AA "CIC: coding data not released"? I tried coding CIC_HU but keep getting stuck because it says there's no data to code.
I seen an option to reset the head unit but worried it might brick. Can anyone give advice on what to do?
05-13-2018
05-13-2018
chknlytle wrotehttps://cartechnology.co.uk/showthread.php?tid=27313&pid=271083#pid271083Has anyone come across a fault code B7F87F "CIC: coding data implausible" and/or B7F8AA "CIC: coding data not released"? I tried coding CIC_HU but keep getting stuck because it says there's no data to code.
05-14-2018
05-14-2018
Almaretto wroteThanks for the info but not quite sure how to use it. Anybody else have any other input?
05-18-2018
05-18-2018
I coded the trunk close via fob based on the cheatsheet, but it didn't work. Is this a common problem or do I just need to try and recode?
05-18-2018
05-18-2018
zhoudaniell wroteOlder firmware sometimes takes 15 minutes of car sleeping to take affect.I coded the trunk close via fob based on the cheatsheet, but it didn't work. Is this a common problem or do I just need to try and recode?
Make sure you selected "Code FDL."
06-03-2018
06-03-2018
neosez wroteF025.Hi, I'm new to coding, I just received my cable and get E-Sys + instruction from Shawn - Many thanks your are the Best.
Now I connect my laptop with my X3 2013 x28i F25.
When initiate connection (Target Connection) which one should I select
F020 or F025
06-04-2018
06-04-2018
i have one problem please help me
i have bmw f15 x5 2014
i have esys 3.27.1
launch v2.6.2.124
psdzdata 63.1.002
i wont to coding my bdc body and allways i get error a send you picture and than i loss cafd file always and with error. in bdc body i have all ……255_255_255
please help me what must i do
i have i step curect f025-15-3-503
i send you error code
thankyu wery much
sori my english not god
i have esys 3.27.1
launch v2.6.2.124
psdzdata 63.1.002
thankyu wery much
06-13-2018
06-13-2018
neosez wroteAre you using launcher cheat codes?Hi, I've 2013 X3 F25. I've just completed coding for DVD in Motion, Close mirrors + Windows + moon roof through Confort Access / Key Fob.
But when I try to do "Close Trunk / Tailgate through button on FOB"
Module = HKFM
Section = 3010
Function Value = SCH_FBD
Function Value = TASTER_FBD
I find SCH_FBD but did NOT find TASTER_FBD.
Can anyone help me out what should I do, Am I missing something ?
06-21-2018
06-21-2018
bunbun9981 wroteWhy did you quote the original giant post?Hi April1,
Im a newbie here.
Could you please tell me how to get the E-token and Psdzdata 54.2?
I missing this two steps right now.
Thank you!
April1 has not been around in years.
You cannot send or receive PM's yet. Send me one when you can.
06-21-2018
06-21-2018
shawnsheridan wroteIm sorry Shawn,Why did you quote the original giant post?
Please guide me. Would you please send me the link.?
Im a bit lost right now..
Haha.
Thank you:happyanim:
06-21-2018
06-21-2018
bunbun9981 wroteYour account is new, so you cannot send or receive PM's (Private Messages) yet. Wait a bit, and it will become enabled, then send me a request via PM.Im sorry Shawn,
Haha.
06-21-2018
06-21-2018
shawnsheridan wroteAlrightYour account is new, so you cannot send or receive PM's (Private Messages) yet. Wait a bit, and it will become enabled, then send me a request via PM.
Thank you
But How Long do I have to wait?
06-21-2018
06-21-2018
bunbun9981 wroteYou don't anymore. It is working now. I just sent you a PM.Alright
Thank you
06-25-2018
06-25-2018
shawnsheridan wroteThank you very much Shawn~!You don't anymore. It is working now. I just sent you a PM.
06-29-2018
06-29-2018
Good Afternoon.
Does anybody know someone that can provide support to install whatever will allow me to code my stupid trailer kit?
I'm computer savvy and can set up any remote access software that may be required.
Thanks guys!!!!
Thanks guys!!!!
06-30-2018
06-30-2018
where do i see the cheat codes in Esys ?
should i place the cheat codes in Esys program folder ?
can i get a guide or video on how to code pls. Thanks
06-30-2018
06-30-2018
plikmuny wroteIn FDL-Editor.where do i see the cheat codes in Esys ?
06-30-2018
06-30-2018
great info on this thread thanks
07-01-2018
07-01-2018
hi everyone
i have follow this tuto to do a full backup off all my settings before to try coding something
i have an issue with the CAFD backup one line as not been save correctly
here is the error
i'm a newbie and doesnt whant to start coding before have a perfect full backup
thanks
here is the error
could someone can tell me what i have to doBKOMBI [60] [XXXXX]
readCPS o.k.
CAFD_00000760_007_003_032 Fehler:
File for "cafd_00000760-007_003_032" not found! [C012]
thanks
