11.1KVIEWS
5REPLIES
1APPRECIATES
5ACTIVE PEOPLE
11-25-2023LAST POST
11-25-2023
11-25-2023
Which one do you run for daily? My car is on stock ecu tune. I just tried stage 3 and it’s wild but reading in the details it’s not that much different than stage 2. Just to avoid any unnecessary wear and tear on the car should I use stage 2 until I get the car tuned?
11-25-2023
11-25-2023
Been running stage 2 for a while (bout a year). Never tried stage 3. Don't require the super hard shifts - not generally racing and i had that similar fear of whether or not one was harder on the transmission. So far so good. I did mine around a BM3 tune so it's a bit hard to tell which benefits are from which.
Really like that it lists the gear you're in at all times. One thing I haven't had time to investigate is my vehicle seems to shift really early under relatively normal driving. Probably good for MPG but also just a pain as i'd rather be in a zone of more power. Probably need to reset some adaptations......or maybe i'm just going crazy.
Stole the below from https://x3.xbimmers.com/forums/showthread.php?t=1758472&highlight=xhp&page=2
X3 M40i (G01) SAV Stage 1
- Added Gear-Display in all Modes
- Removed Torque Limiters
X3 M40i (G01) SAV Stage 2
- Gear Display in all Modes
- Torque Limiters removed
- Totally reconfigured Shift-Logic. 3 Shift Speeds available (Comfort, Sport, Sport+)
- Overall faster shifts than stock, very fast in Sport+
- Strong/fast Throttle-Blips in Sport+
- Remapped Shift-Points
- More spontaneous reactions to driver-inputs
- Removed a bit of the nervous down-shifting in Comfort Mode during braking.
- Removed a bit of the nervous down-shifting on inclines
Description of Modes:
- D/Comfort: Relaxed shift-points with low to medium speed and focus on Comfort. Audible in the high RPM range.
- D/Sport: A tad higher shift-points with medium/high speed. Still a daily-drive mode. Audible in the high RPM range.
- D/Sport+: A tad higher shift-points with medium/high speed. Still a daily-drive mode. (Steering/Suspension are harder than Sport)
- S/Comfort: Higher shift-points with medium-speed, but still comfortable shifts.
- S/Sport: Higher Shift-Points with medium to high speed. Audible in the mid/high RPM range.
- S/Sport+: Race Shift-Points with high-speed and audible shifts
- M/Comfort: Smooth shifting up and down.
- M/Sport: Medium/High-Speed shifts up, Light blips down.
- M/Sport+: High Speed shifts up, noticeable Throttle-Blips down.
X3 M40i (G01) SAV Stage 3
- Overall faster shifts than stock, very fast/hard in Sport+
- Very strong/fast Throttle-Blips in Sport+
- D/Sport: A tad higher shift-points with medium/high speed. Still a daily-drive mode. Audible in the mid/high RPM range.
- S/Comfort: Higher shift-points with medium speed, but still comfortable shifts.
- S/Sport+: Race Shift-Points with very-high speed and audible shifts
- S/Sport+ with DSC OFF: Pure Race-Map. Optimal acceleration at all time, ready for Race-Track.
- M/Sport+: Very-High Speed shifts up, strong Throttle-Blips down.
11-25-2023
11-25-2023
I’ve been running 3 since installing it
It’s only crazy with the shifter slid to the left
11-25-2023
11-25-2023
Stage 3 since I got it. You can adjust settings to make shifts smoother.
Rottweiler
11-25-2023
11-25-2023
Stage 3 on our 20 X3M, it is not harsh or brutal at all. Takes about 200 miles for the adaptive tables to full set in.
11-25-2023
11-25-2023
Thank you all for the shared experience. I drove for a bit and didn’t notice any hard shifts even with the shifter slapped to the left.
Tried one launch control and it was ballistic.
Can you share some of your custom settings? I am thinking about leaving coasting on, stop-go and starting from second (this one still not sure about). Also have been wondering if I want to mess around with the ignition cut off shifting.
