x3Prancer wrote So, as seen from my previous post in the thread, the upper radiator hose connector had a leak in the area where the auxiliary host connects to it. The auxilliary hose leads to the heater core. This seems to be a common failure point. There were no other leaks that I could find. Instead of replacing the entire coolant hose, I opted to replace only the plastic connector. In order to do this, I had to purchase the entire hose, and cut off the clamp, and remove the hose from the connector. When I started to remove the auxilliary hose from the side of the main upper radiator hose connector, I couldn't. It was fused so badly I couldnt get them separated. It ended upbreaking off. Once I got the side piece off, I removed the main connector from the radiator, which wasn't so bad, just required some gentle tugging. After the connector was separated, i cut the clamp off of the main upper radiator hose, and separated the hose from the connector. Then I put the new connector in (I put a little vaseline to make it go in easier), then connected the uper radiator hose and the auxilliary hose to the connector using Koehler screw clamps. To access that area a little better, I removed the screw nearest the front of the car from the silver crash brace, and pushed that off to the side.
I had very little coolant loss. Maybe 1/2 - 3/4 of a jug, most of which was loss of coolant due to the leak from before. The resevoir was filled 3/4 of the way, and Im monioring it for a few days if it needs to get topped off.
Also one important thing I realized. Because the auxilliary hose got fused to the upper hose connector, I would have had to replace BOTH hoses completely, that would have made this job considerably more work if I replace the entire the hoses instead of just the connectors.
So far so good, the job took me in total about an hour.
Here are the parts I needed to buy:
Radiator Hoses:
64-21-9-354-459 (heater core hose for 2019 X3 sDrive)
17-12-7-535-529 (upper radiator hose for 2019 X3 sDrive)
Clamps:
Koehler Enterprises Hose Clamps, Hose Clamp Box of 10, Radiator Hose Clamp, Silver, Size SAE 20
Koehler Enterprises Hose Clamps, Hose Clamp Box of 10, Radiator Hose Clamp, Silver, Size SAE 28
BMW Coolant
Distilled water
You will need a dremel to cut the existing clamps off, a screwdriver, and pliers
Here are some pics.
How did your solution work out over the next year?
I have the same leak and your method is definitely way easier than replacing the hose, specially 64219354459
