25.2KVIEWS
24REPLIES
10APPRECIATES
10ACTIVE PEOPLE
10-05-2023LAST POST
10-05-2023
10-05-2023
pungo user avatar
pungo
1,210 REP
2.9K POSTS
Bilbofraggins wrote
Today started the Timing job… with valve cover off… I now know the source of the increasing tattle… the chain itself……it has stretched significantly (see pic).
Take a pic of the old chain laying next to the new chain to show how much the old chain has elongated.
Appreciate2
10-05-2023
10-05-2023
tom2021 user avatar
tom2021
339 REP
My opinion as an engineer:
The chain is made of metal. If the elongation is still within elastic limit, it will shortened back to its original length. If the elongation is permanent, that means the chain has been stretched to plastic limit, that can't be recover.
Appreciate2
10-05-2023
10-05-2023
Bilbofraggins user avatar
Bilbofraggins
305 REP
slowblackx3f25 wrote
yes, the dealership quoted me CAD$10k (CAD$9.2k) including parts + labor.
I did shop around and I asked other shops which are BMW specialized, and they quoted me anywhere from $2.4k to $6.3k (CAD$) which includes parts + labor.
I'm sitting around 1500 Cdn for the timing chain side (includes oil, coolant, filter) OEM parts. Also purchased the cam and oil pump tool (good ones) - not included in the 1500. Borrowed a crank seal remover/installer tool. Fabricated an engine support bar....two actually, first attempt deflected too much.
Had to add a front diff axle seal (broke removing the diff), but will replace both. None available locally, so ordered Corteco from Amazon...paid 24 instead of 70 BMW. That will delay things but its Thanksgiving weekend here.
Also doing tranny drain and fill, new filter and pan upgrade, diffs and transfer case oils.
The shops in Toronto doing this for $2400 CDN (xdrive), are reusing all but the 'must change item's in my opinion... which is probably fine....and will save a lot.
I'm thinking 3K Cdn +tax with OEM parts is a fair price at an Indy. At 2400...they must be really experienced - added to the fact they know what is needed.
$9.5K at BMW is of course gouging for a problem they have caused...but no Dealer/Brand is going to be cheap. I'll keep my thoughts on BMW itself for another day.
Appreciate1
