3.7KVIEWS
8REPLIES
0APPRECIATES
5ACTIVE PEOPLE
05-28-2023LAST POST
05-21-2023
budda user avatar
budda
Norway
1 REP
Need to replace rear brake pads.
Qsilver7 user avatar
Qsilver7
6,502 REP
9.8K POSTS
Yes…if you have the Bimmerlink app…or other software:
budda user avatar
budda
Norway
1 REP
I see but I mess upp warranty by installing bimmercodes.In Norway we have 5years/200.000km.
chassis user avatar
chassis
9,665 REP
3K POSTS
icarsoft OBD devices claim to have the function that you ask about. Are icarsoft devices available in Norway (via online purchase)?
budda user avatar
budda
Norway
1 REP
Yes,they are but I think they do all bmws like the newest ones.
g11hoonigan user avatar
g11hoonigan
979 REP
1K POSTS
This is thru bimmerlink, I don't think it'll change or save anything other than giving a service function signal to enable/disable service mode for parking brakes.
But if you are really concerned about the warranty, either you manually remove and retract the parking brake or have the dealer to it for you.
budda user avatar
budda
Norway
1 REP
I bought a icarsoft cr max and that did it, thanks for the answers.
BigMart user avatar
BigMart
139 REP
Or..
You can remove the motor from the calliper.
Really easy
And wind the mechanism back in by hand
It’s a big torx bit but winds in with hand pressure clockwise.
Then refit the handbrake motor.
Did this with our 2019.. didn’t have BimmerCode then.
Was maybe 5 mins extra per side
Qsilver7
6,502 REP
9.8K POSTS
Just to clarify…BimmerCode & BimmerLink are TWO different apps.
Bimmercode - is a coding app that allows you to select and change operational functions of various control modules in the car’s communication bus.
Bimmerlink - is a diagnostic app that allows you to read & retrieve data from the car’s control modules if they have registered fault codes…or retrieve status data like temperature, voltage, level, etc.
