Dear guys , one ring of the "angel eyes" is losing intensity day by day and moreover is changing color from white to yellow (look attached photo to understand what I am speaking about). Consulting bmw electronic parts catalogue I noticed that, unlike previous versions of x3 and other bmw cars, there is no replacement for the drl's LEDs.
Does anyone know if the lighting is integrated into the lighthouse or if there is a method to change it?
Thank you for your help.
My car is a x3 f25 facelift.
60.3KVIEWS
55REPLIES
8APPRECIATES
27ACTIVE PEOPLE
05-16-2025LAST POST
10-30-2019
10-30-2019
10-30-2019
10-30-2019
My guess is the box is sealed; I have heard of people with much older Bimmers heating the enclosure in oven to loosen/remove and replace lenses- and some cut the enclosure open to add halo rings as a DIY upgrade.
Best bet may be to replace entire unit- perhaps source from EBay or salvage place.
Good luck
Bill
Good luck
Bill
10-31-2019
10-31-2019
Wgosma wroteThank you Bill.My guess is the box is sealed; I have heard of people with much older Bimmers heating the enclosure in oven to loosen/remove and replace lenses- and some cut the enclosure open to add halo rings as a DIY upgrade.
Good luck
Bill
I think it's unbeliveable I have to change the whole headlight for a single led failure. I am so disappointed about this BMW choice.
slowblackx3f25
10-31-2019
10-31-2019
I looked at repair instructions at NewTis.info site and could not find any info about the angel eye halo rings. You might take a look, maybe I missed something but I think not.
10-31-2019
10-31-2019
Wgosma wroteI looked yesterday on that site but there is no document about the F25 LCI drl repair... When I Press "change drl led" the site redirect me to the document related to older f25 (not LCI).I looked at repair instructions at NewTis.info site and could not find any info about the angel eye halo rings. You might take a look, maybe I missed something but I think not.
10-31-2019
10-31-2019
ask one of the vendors at getbmwparts.com
it might be light module thats going bad.
10-31-2019
10-31-2019
Angel eye LEDs are replaceable, but they are installed on the bottom of the headlight.
https://www.fcpeuro.com/products/bmw-repair-kit-led-module-63117263051#fitment
nyalpine90
10-31-2019
10-31-2019
doodlebro wroteUnfortunatelly BMW changed that system with the LCI version. Look this photo:Angel eye LEDs are replaceable, but they are installed on the bottom of the headlight.
In the lower part of the headlight Is only installed the Xenon control unit
10-31-2019
10-31-2019
what year is your X3?
10-31-2019
10-31-2019
10-31-2019
Iangiulu wroteI don't know that I'd trust that diagram. I've seen plenty of errors in them before. Only real way to know is pop off the front bumper and see.Unfortunatelly BMW changed that system with the LCI version. Look this photo:
nyalpine90
11-01-2019
11-01-2019
The problem is that diagram is not for your 2014 x3
You need item 15, module thats is located at bottom of headlamp.
doodlebro is correct
https://www.getbmwparts.com/v-2014-bmw-x3--xdrive28i--2-0l-l4-gas/electrical--headlamp-components
11-01-2019
11-01-2019
nyalpine90 wroteYour link points to pre LCI headlight parts. He has the first month of the new facelift production as we can see on the picture, so this is not going to work.The problem is that diagram is not for your 2014 x3
You need item 15, module thats is located at bottom of headlamp.doodlebro is correct
Pelicanparts fitment for this item is up to 03/2014
https://www.pelicanparts.com/More_Info/63117263051.htm?pn=63-11-7-263-051-BOE
11-01-2019
11-01-2019
Burnaby wroteExactly.Your link points to pre LCI headlight parts. He has the first month of the new facelift production as we can see on the picture, so this is not going to work.
11-01-2019
11-01-2019
The correct light is at bottom of the link, with same part you are showing that matches oem part number
11-01-2019
11-01-2019
nyalpine90 wroteLook this image:The correct light is at bottom of the link, with same part you are showing that matches oem part number
The part "15" in the link you sent doesn't fit this headlight
11-01-2019
11-01-2019
Iangiulu wroteLook this image:
the link i share are for 2014 X3 with xenons. there are only 2 headlamps for F25 which are halogens and xenons.
11-01-2019
11-01-2019
I re-iterate, this is why realOEM can be so confusing.
OP, you have to remove the bumper and see what light you have.
03-02-2020
03-02-2020
Anyone finally get the solution to the yellow drl?
03-02-2020
03-02-2020
X4guy wroteUnfortunatelly no spare parts exist for facelift. Probably we need to change the whole headlight... BMW need more and more money time by time. I am so disappointed.Anyone finally get the solution to the yellow drl?
03-03-2020
03-03-2020
Iangiulu wroteHow about a warranty claim?Unfortunatelly no spare parts exist for facelift. Probably we need to change the whole headlight... BMW need more and more money time by time. I am so disappointed.
11-30-2020
11-30-2020
I am having the same issue, one of the angel lights has turned yellow. BMW suggesting a $1600 module replacement. Thought to check before here before I go ahead and do that. what did you finally do?
