7.7KVIEWS
7REPLIES
0APPRECIATES
5ACTIVE PEOPLE
06-06-2023LAST POST
02-28-2017
02-28-2017
Chopper45 user avatar
Chopper45
77 REP
X4 30d - Car won't accelerate cleanly in lower gears. it feels like slippage n slight shudder as the revs increase. not so bad when taking it easy... anyone have the same issue? Cheers
02-28-2017
Tjalle user avatar
Tjalle
193 REP
1.3K POSTS
Chopper - sorry about that.
There are discussion right now on X3 forum about similar problem, but more related to turning.
One proposed solution is flushing transfer case. BMW say transfer case is sealed for life, but there are some -("many ?") which have resolved problem with flush.
03-04-2017
Chopper45
77 REP
well BMW have now checked the car and can't figure it out. booked in next week for 3 days and hopefully they will figure it out. thank God for warranty :happyanim:
03-20-2017
Chopper45
77 REP
All sorted. Transfer case and diff oil changed. All is good again :thumsup:
03-20-2017
Tjalle user avatar
Tjalle
193 REP
1.3K POSTS
This is - a bit - surprising, since BMW says transfer case is "sealed for life", but , again, other people have testified good result with changing oil/flushing.
Any comment on status of oil? - infested with water or whisky? :o
03-04-2023
Glene user avatar
Glene
87 REP
I had exactly the same issue. No codes and no CEL. Opening up the actuator motor and black gear is good. Replaced the transfer case drive chain, and problem fixed. When accelerated from stop, it jumped teeth due to stretched chain (dirty oil caused the chain to stretched). I spent less than $100 for part and dealer wanted $3,000.
https://www.ebay.com/itm/191033934838
05-26-2023
couchflyer user avatar
couchflyer
268 REP
There really is no such thing as lifetime oil. I always change mine around 80,000 miles. My X4 has 117,000 miles with no issues.
06-06-2023
bmwPower99 user avatar
bmwPower99
90 REP
I changed mine around 50k+ miles and the transfer case fluid was disgusting as was the front diff oil and zf trans oil. Rear diff oil looked like new. I don't know what a reasonable interval is for the transfer case, anything but never.
