F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > 3rd gear pull against a 2013 S4
Extreme Powerhouse
      03-16-2014, 11:17 AM   #1
1987E30M3
1987E30M3's Avatar
Italy
30
Drives: E30 M3 & 325ic-F30 335i Xdrive
I was very surprised today. I have a 2013 335i Xdrive F30 6 speed with MPPK and a AFE dry flow drop in oem intake (Basically stock). On my way home I saw a kid I knew in his 2013 S4, his car has the sport S tronic dual clutch transmission. The kid also has an exhaust and a stage 1 tune (not sure what brand of both). I would say he has to have at least 40 hp to the wheels above stock. I also realize the S4 is heavier (3,935 pounds VS 3,591 pounds.)
I instantly put my car into sport + mode, got next to him put my window down and said lets do some 3rd gear pulls. After the third tap of the horn I instantly pulled away from him I would say at least an entire car and 1/2 a head of him. I was infront of him up until 120 mphs, he then gained on me and eventually passed slowly and I probably let off the gas earlier then he did .
With that said I believe MPPK is drastically under rated. I have a 6 speed so my car lacks the torque converter needed to get me the extra torque with MPPK and I was still able to beat him. I just thought I would share this proud moment with you guys .
      03-16-2014, 01:53 PM   #2
M-terkait
M-terkait's Avatar
Kuwait
210
Drives: F30 335i 3/13
with jb4 and more stuff you'd killed him
Docrace 6266
      03-24-2014, 02:31 PM   #3
apexit
Drives: 15 SO M3
What mph did you start at?
      03-26-2014, 08:04 AM   #4
1987E30M3
1987E30M3's Avatar
Italy
30
I would say between 40 and 50 MPH, we did it three times
      03-31-2014, 05:22 PM   #5
ShlemonboostedM
ShlemonboostedM's Avatar
92
Drives: 335i F30
good shit !! i wanted to race one for long time ..
      04-09-2014, 04:34 PM   #6
apexit
Drives: 15 SO M3
The B8 has basically 0 lag and it especially evident lined up against a turbo car. Try being higher in the RPM range and brake boosting. Should help off the line.
f30post
