BMW 3-Series (E90 E92) Forum
oil leak
11-19-2013, 12:59 AM | #1 |
Rep 42
oil leak
11-19-2013, 06:15 AM | #3 |
Rep 5,458
I also think the picture is too small - is that turbo side?
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-19-2013, 07:17 AM | #5 |
Rep 776
Make sure your filter housing o-ring is on the right groove. It doesn't actually sit on the groove closest to the lip, it's a bit closer to the threads.
(don't ask how I know this! ) |
11-19-2013, 10:02 AM | #7 |
Rep 42
thank for the reply guys! sorry for the huge pic. my oil filter o-ring is good no leaks there. i left the motor running and it doesn't seem to be leaking. maybe i didn't clean up as well as i thought from my ofhg job. ill clean a little bit more and run some degreaser and post results. thanks again!
11-19-2013, 02:35 PM | #8 | |
Rep 776
11-19-2013, 09:38 PM | #9 |
Rep 42
ok so I cleaned up as much oil as I can find and water downed that side and dryed up everything. it took a really long time! It seems like it still is leaking!
It seems like there is a gasket in there or a space between there. Possibly oil still stuck from previous leaks still in there. Could there be another lower block and a gasket in between there. I find it hard to believe the block could be leaking! |
11-20-2013, 04:59 AM | #10 |
Rep 1,834
Drives: 08 E90 335xi TiAg
Perhaps you didnt get the gasket placed properly? I had oil in those exact same spots....it was my oil filter housing gasket. I had the engine cleaned and have not had any oil there since.
I am pretty sure if it is the valve cover gasket it will leak down the turbo side of the block. I'm just an amateur though so take this with a grain of salt. |
