F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > What to expect during the first Service visit ~15K miles
Extreme Powerhouse
      12-07-2012, 01:09 AM   #1
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
Exclamation What to expect during the first Service visit ~15K miles
This is not my first BMW, but it is my first Brand Spankin' New Cost-an-arm-and-leg BMW...
I have tried to search for the appropriate topic, but none could be found.
Here is my current situation:
my car has reached 13,200 miles and is requesting it's first Service Inspection etc etc... (technically it should be 15K miles, but the car does the calculation depending on how bad a driver you are)
The car is also requesting another quart of oil since the last top-off at around 9,000 miles. It would seem based on the trend that my 335i is burning a quart of oil every 3,000 miles.
But no matter, BMW is supposed to change the oil and the filter...
For those who have gone through this process, what can you tell us please?
how was your experience ? did it cost you anything despite them saying the car maintenance is zero for the first 4 years.
Did they force you to buy anything else ? any additional service?
were you treated nicely or bad? I think Lexus customer service is great. how is BMW's ? And how do you know the service has been properly performed?
There is no dipstick... how can i know if they really change the oil and filter without being able to see the color of the oil...
I have always serviced my own car myself, but with the F30 it's the first time i am going through the stealership...
Any tips? Any advice please? I want to make the process as smooth and pain free as possible...
I want to have my four-wheel alignment done... that's free service right?
cabin microfilter... is that free and part of the 15k factory service?
I told them to perform the necessary task to contain the seat frame rust (if my car is affected) ... do you think they will do it for me ?
the car is faintly pulling to the right...and my steering wheel doesn't seem to be absolutely straight when driving straight on the highway... Will they correct it for me free of charge?
I have noted a light buzz at the front right under carriage when driving around 50 mph and also at 70 mph... if they are able to confirm it and identified what the problem is, will they fix it for me as well (for free)?
      12-07-2012, 02:30 AM   #2
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
Alignments and anything having to do with tires are typically not covered.
      12-07-2012, 05:52 AM   #3
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
The first service is "oil service". The second is "inspection I".
You should expect nothing more than a simple oil change from BMW for the first service.
      12-13-2012, 03:37 PM   #4
c.cash
Drives: 2013 328i modern line
No tire rotation?
      12-13-2012, 04:34 PM   #5
Yobyot
Yobyot's Avatar
494
Drives: MY19 X3 M40i
Originally Posted by c.cash View Post
No tire rotation?
Actually, BMW specifically recommends AGAINST tire rotations.
I only buy BMWs with square tire/wheel setups and ignore this advice.
I would follow BMWs advice if I had a car with staggered setups.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      12-13-2012, 06:38 PM   #6
c.cash
Right -- I thought they recommended against it only for staggered setups, which I can kind of understand. But for regular setups, I've always rotated every 5k (with the oil change), and my tires last a really, really long time.
I'm having my oil changed every 7,500 and I'll do a tire rotation at the same time. I guess I'll just have to make additional appointments at a tire shop for the 15k service.
Maybe it's time to buy some jack stands.
      12-22-2012, 12:06 AM   #7
Dudeonthego
Drives: 2012 BMW 328i - Luxury Line
Only Oil change for first service ?
f30post
