07-06-2012, 11:40 PM | #1 |
Rep 39
Has anyone had this problem with oem roof rack?
First time installing BMW oem roof rack on my 2012 x3. I have fitted the rack onto my rails at the appropriate locations. When I tighten them down the drivers side responds fine but the passenger side will not tighten down fully no matter how many times I turn it. The nuts are attached on the inside and I can't seem to figure out why it won't tighten. So I'm hoping that someone here has encountered this since this is the sort of thing that I hate to take to the dealer and have them show me just how simple it is to fix.
07-07-2012, 12:20 PM | #2 |
Rep 128
Drives: 2012 X3 XDrive 35i
When you talk about the nut being attached, do you mean you used the hex key to loosen the nut? It is what I had to do to get the bolt to engage.
08-21-2012, 08:34 PM | #3 |
Rep 1
CaliRuicon -did you ever figure this out? I am having the same issue and I am leaving tomorrow on a trip and I can't get this damn rack to tighten. I have used it for over a year but now it is not working.....ugh!!! I tried the allen wrench but no luck.
08-23-2012, 02:45 PM | #5 |
Rep 138
Drives: 2011 BMW X3 35i Space Gray
Ditto....having the exact same problem. I was going to try to disassemble and figure out what the issue is, but I may see if they dealer will replace them. They are about 10 months old.
01-08-2013, 03:01 AM | #7 |
Rep 15
I realize that the last post was back in August last year, but just wondered if you sorted it out?
I had the same problem, but fixed it (hopefully not temporarily) - the manual says that if you get into a situation where you can't tighten down fully, you use an Allen key & turn 1/4 clockwise. This did the trick for me. Hopefully it will stay that way... Hope this helps anyone else with the same problem |
01-09-2013, 05:05 PM | #8 |
Rep 40
I talked with the dealer this morning for my new X3 I've had for 6 hours and they're still issues with those units.
I decided to spend a little more and currently sitting at Rack Attack having a new Thule base system installed.
'13 X3 28i M Sport Carbon Black Metallic w/Oyster Nevada
01-09-2013, 05:22 PM | #9 |
Rep 13
Roof Rails
I am having problems too. I ordered the rails and when I installed the front bar I noticed the spring on the right side nut was already broken. I called the service department and the person who took the call put the receiver down to talk with the parts manager. I heard the conversation, which the parts manager said he wished BMW would stop selling them. They are nothing but trouble. They sent me another set and when I tried putting them on, the spring broke on the left side! I'm taking both sets back to the dealership tomorrow and demanding my money back. I'll order some after market rails. They may not look as good but at least they'll work.
01-10-2013, 07:58 AM | #10 |
Rep 70
Not sure if this is the issue but in the instructions for the rack it says if you turn the tightener/loosener too far to the left you will need to use an allen wrench to tighten it enough to use it as intended. I've got a 2012 and had a similar issue with tightening. Once I followed the above direction all was in good working order. I've had to do this a couple of times.
01-10-2013, 04:33 PM | #11 |
Rep 40
I don't think the Thule looks bad at all and very much the same foot as BMW. Additionally I got the Aero cross bars and are much quieter due to their design.
[IMG][/IMG] [IMG][/IMG]
01-10-2013, 06:36 PM | #12 | |
Rep 13
01-12-2013, 10:40 AM | #13 |
Rep 13
Thanks
Thanks Davy, I took my racks back to the dealership and ordered the Thule AeroBlade system. They look better and the reviews for the most part are positive.
07-19-2013, 09:13 AM | #15 | |
Rep 78
Thank you Teegee. |
07-19-2013, 09:23 AM | #16 |
Rep 47
Drives: 2014 x3 35i
No issues at all with the Thule. I needed the square bars for my Yakima tandem rack. Ugly but rock solid attachment.
Regards,
Bob |
07-20-2013, 08:48 PM | #17 |
Rep 427
I also went to Rack Attack in Portland...
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars 2005 S2000 2018 i3S |
09-01-2013, 07:04 PM | #18 |
Rep 5
Anyone look at the Thule Aeroblade Edge? I really like the look online but it's a newer system and not much feedback out there yet. Thanks for any info!
10-16-2013, 06:32 PM | #19 |
Rep 2
roof rack removal problems
when I tried to remove the rack, two of the four would not turn counterclockwise to loosen the clamps to remove the rack with the rooftop storage unit. The dealer said it was broken, is supplying another, but seems ignorant of what seems to be a relatively common occurrence.
do new racks have different mechanism design? The replacement looks just like the broken one, so am I just going to repeat my problem? |
10-16-2013, 09:42 PM | #20 |
Rep 19
Mine are even worse. I blagged them for free from the SP at purchase in order to clinch the deal, and he fitted them for me when they arrived.
One of the legs has the Allen bolt protruding from its housing, and it'll only undo half way. Fortunately it's far enough to still be able to lever that leg onto the rails. Took them back to the dealer's service centre to complain and they fobbed me off saying they'd "fixed" them i.e. refitted them with no change. I'm fairly certain they were a customer return, and as I have no sales receipt I have no recourse. Oh well, you get what you pay for... |
10-17-2013, 06:05 AM | #21 |
Rep 19
Is it on your purchase order? If it is, then you are ok.
The reasons why I went with the oem racks were: 1. Two years manufacture warranty 2. They were 50% off brand new at a dealer when I bought them! Keeping my fingers crossed but so far my roof racks have been functioning just fine. I only put them on when I need them. |
10-17-2013, 11:22 AM | #22 | |
Rep 2
x 3 roof cross bars included parts
