BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > WTF!! How do I get the Idrive updated!!!?
      07-06-2007, 12:53 AM   #1
SMBowen
Drives: 08 E63M
I had the infamous ELV steering lock. Can't start my car get it towed in and ask that along with the fix they upgrade the CIP and nope. I even mentioned how long it takes for me to listen to music.
What is the "line" I need to tell SouthBay BMW to get it updated?
-sm
08-E63M - Space Gray, full black leather & carbon fiber interior w/ every option available, Vorsteiner Decklid Spoiler, RD Sport Roof Spoiler (CF), etc.
06-E90 330i - Totaled 30 Sept 10
      07-06-2007, 05:04 AM   #2
rob72
/dev/random
rob72's Avatar
31
Drives: .
It clearly depends on the dealer.
I brought my car in today for regular service, and asked if they could update progman, and gave them the line of the slow iDrive on startup, and they just added it to the list of things to do, no further questions asked.
It might also depend on how busy they are. And since the holidays just started, I did not have the feeling they had lots to do.
So when I go to pickup the car tonight it should be all done.
      07-06-2007, 02:52 PM   #3
rob72
/dev/random
rob72's Avatar
31
Drives: .
just to add, the update was done, and although I have no idea if it is v25 or v26, I clearly have the new version as all the colours changed. Not sure if I like the new map colours, but at least the route sticks out more.
      07-06-2007, 04:25 PM   #4
SMBowen
Drives: 08 E63M
Cool...thanks for rubbing it in!! haha j/k
Well this blows, I need to find out who I need to talk to and what I need to say to that person and whatever dealer to get this updated.
I can't stand when I get in the car and music doesn't start until I am part of the way down the road and I would really like the POI search. The colors are just colors and yeah probably makes it easier to view, but I want the function.
-sm
      07-07-2007, 01:38 AM   #5
RyBMW
RyBMW's Avatar
78
Drives: X5
2012 BMW X5  [0.00]
2008 335i  [0.00]
What version do you have right now? Maybe you can tell them you have the pop up arrow missing.
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar
Old: 06 E90 330i|Black Sapphire/Black /Burl
      07-07-2007, 01:41 AM   #6
magmd
magmd's Avatar
Drives: '06 330i
2006 330i  [0.00]
Damn...you have an early 330i.
Have you done ANY updates??
If no...there was an emissions recall for you vehicle. Its an automatic upgrade if you mention it.
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
      07-07-2007, 01:50 AM   #7
magmd
magmd's Avatar
Drives: '06 330i
2006 330i  [0.00]
Just in case you need it...print it out and just show them. It applies to most vehicles produced before 10/05. You get an automatic upgrade the latest version under warranty PLUS THEY TOP OFF YOUR GAS TANK as stated at the end of bulletin. So, if you have not had this issue addressed, and it appears your car qualifies...slap them in the face with this shit and say top it off BITCHES!!
SI B12 06 06
Engine Electrical Systems April 2006
Technical Service
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES BEFORE CUSTOMER DELIVERY OR THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
Voluntary Emissions Recall 06E-A01: N52 - Reprogramming Vehicle for OBD Diagnostic
MODEL
E90, E91 and E60, E61 with N52 produced up to 10/04/2005
SITUATION
The DME programming, as originally installed, may cause the OBD diagnostic not to detect potential malfunctions of various emission relevant sensors. As a result, in case of a sensor malfunction, a pending fault code will be erased rather then permanently stored in the DME memory. Consequently, the "Service Engine Soon" light will not illuminate.
In one case (P1030 Valvetronic position control), the diagnostic works correctly, but the scan tool cannot read out the fault code.
This diagnostic software error would not cause any drivability problems.
In order to remedy this situation, BMW is conducting a Voluntary Emissions Recall Campaign to reprogram the DME control module on all affected vehicles. With the completion of this campaign, the software in the E90, E91, E60, E61 vehicle's control units will be updated as described in SI B09 05 01 (Coding, Individualization, Programming) Procedure B.
A copy of the customer letter is attached.
AFFECTED VEHICLES
This Recall Campaign involves 325i/iA/xi/xiA/xiTA, 330i/iA/xi/xiA, 525i/iA/xi/xiA and 530i/iA/xi/xiA/xiTA vehicles with N52 engines which were produced up to 10/04/2005.
In order to determine if a specific vehicle is affected by this Recall Campaign, it will be necessary to utilize the "Service Menu" of the DCS (Dealer Communication System). Based on the response of the system, either proceed with the corrective action or take no further action.
The Chassis Number Ranges listed below are only for informational purposes and are not to be considered as the only deciding factor.
Model
325i
KR56053 – KR59937
NH93005 – NH93141
PS64040 – PS64170
325iA
PT00048 – PT02060
KR62113 – KR66999
NK30024 – NK31128
325xi
KT78014 – KT78076
325xiA
KV00032 – KV00478
325xiT
AV98013 – AV98018
325xiTA
KW22040 – KW22096
330i
AZ85053 – AZ87580
PS05034 – PS05101
330iA
KR72054 – KR81997
KS31001 – KS33204
PS10006 – PS10211
330xi
KL59027 – KL51130
300xiA
KV59027 – KV59415
525i
B992033 - B992199
525iA
CK78008 – CK86240
525xi
B999050 – B999092
525xiA
CB86014 – CB86997
CS34091 – CS35760
530i
B996037 – B996305
530iA
CM30011 – CM38979
530xi
CC34005 – CC34253
530xiA
CG65038 – CG68274
530xiT
B799019 – B799094
530xiTA
CN00039 – CN02415
CORRECTION
Update and recode complete vehicle as per SI B09 05 01 (Coding, Individualization, Programming) Procedure B using Progman V21.00.01 (Target Data Status E060-06-03-510, and E89x-06-03-510), or higher.
LABEL INSTRUCTIONS
After the vehicle has been checked and corrected, obtain a label (SD 92-319) and with a ball point pen print your dealer code (5 digits) on the Recall Completion Label (see illustration). An initial quantity of 50 labels will be sent to all BMW automotive centers. Peel the label from its backing and affix it to the right (passenger) rear side of the hood in the engine compartment, close to windshield.
For California centers only: It is required by the California Code of Regulations that an executed orange "Vehicle Emission Recall - Proof of Correction" certificate (SD92-084, see illustration) be provided to each customer (for vehicles registered in the state of California) once the Recall on their vehicle has been completed.
Note: Additional labels can be ordered on line at BMW TIS.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
00 12 19 02 00
Labor Operation:
00 56 774
Reimbursement via a different technical campaign
Labor Allowance:
1 FRU
Labor Operation:
00 56 128
Program/code control units
Labor Allowance:
12 FRU – E90/91
13 FRU – E60/61
Labor Operation:
00 56 129
Program/code control units including CAS
Labor Allowance:
13 FRU – E90/91
14 FRU – E60/61
Note 1: Should the vehicle be affected at the same time by another repair in which programming of control units is also required, programming may be claimed only once.
Note 2: In the case where Progman requires the replacement of control modules, or additional programming because certain control modules failed to program correctly, print out the Measures Plan and Status Report/Final Report as described in the Progman programming procedure (B09 05 01), and attach these reports to the RO in the vehicle file. The Defect Code, Labor Operation, and Labor Allowance for this additional work should be selected from the KSD.
REFUELING COST
BMW of North America, LLC will provide reimbursement to have the gas tank topped off once, as required, for each vehicle affected by this Recall Campaign. Attach the appropriate receipt to the work order.
Defect Code
85 99 00 66 NA
Refuel vehicle
Sublet:
Actual cost to top off the fuel tank
Sublet code:
VALET COST
BMW of North America, LLC, will provide reimbursement for vehicle valet services (pick up & delivery) for each vehicle affected by this Recall Campaign. Attach the appropriate receipt to the work order.
Defect Code
99 99 77 77 NA
Valet Service
Sublet:
$25.00
Sublet code:
RENTAL VEHICLES
Retailers participating in the Retailer Administered Customer Assistance Program and the BMW Service Loaner Car Program may self-authorize claims for reimbursement of rental costs from independent rental agencies in certain situations. For more details refer to SI B01 07 03.
view PDF attachment B120606Customer_Letter.
