06-14-2012, 11:41 AM | #1 |
Rep 48
iPhone Case with Snap-in Adapter?
I'm currently using my iPhone with the snap-in adapter, but I don't use a case with my phone. I will be upgrading from the 4 to the 4S and am thinking about using a case. Can I?
Does the snap-in adapter prevent using any sort of case? Thanks
2012 X3 35i, DSB/Black, M-Sport, Prem, Tech, Prem Sound, Apps
06-14-2012, 11:46 AM | #2 |
Rep 106
I have a 3Gs iphone and use the snap in connector. There is no room for a case as its a very tight fit into the connector at the bottom and the connector in the top. I would think that that would be the case across the range.
Hope that helps |
06-14-2012, 12:21 PM | #3 |
Rep 256
Yep with the 4 or 4S there is absolutely no clearance to put a case on. Even the skin type coverings like Zagg or Gelaskin may add too much thickness, but if I were to try, I would avoid applying it to the top and bottom of the phone (the metal band surfaces) as the clearances there appear to be very tight.
