Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Problems after having some fun on the german Autobahn
      02-11-2012, 06:12 AM   #1
munters
munters's Avatar
11
Drives: E91 335XI AT Dakota Black M
Went to Germany and had some fun with a 911 RS40 from 60 to 140 MPH.
after a few pulls I let him go and cruised in the range of 130 MPH.
The throttle started to behave strange.
I pushed one more inch but nothing happened boost didn’t come up.
Got a 30ff. switched to valet map and could reproduce it.
After spending 1 week in Germany without using the car, drove back to Switzerland and tried some things.
Pushing slowly, I was able to reach 170MPH. Pushed the throttle down to see what happens, and I had the boost going up and down from 3 to 15 psi.
as long I stayed on the throttle. Got 3 codes 30FF, 2D2E and 29D2.
Boost leak, Tuner code, and misfiring on Cyl 5.
Then I tried to reproduce it and it was not possible again
the only thing stayed was the throttle doesn't react properly.
Pushing slowly a bit at a time works.
Pushing a bit faster but keep on pushing would go in limp (I guess)
Pushing full throttle boost stays at 0.0 directly lift the throttle completely and push it again full throttle boost comes up normally.
I can reproduce that on map 1 or 0 and in any gear at any speed.
Any ideas?
My Car is a XI
FMIC, Procede 3.0
Stage 0 map 11.1
new Injectors and plugs.
59 Corvette, 72 240Z, 73 Espada, ZXR
      02-11-2012, 06:18 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
You have a boost leak. Maybe even a wg stuck or does not seal properly.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      02-11-2012, 06:23 AM   #3
munters
munters's Avatar
11
Boost leak
Yeah I know, the 30FF would say that, but why is it not all the time? and repush the trottle works every time. that's the strange thing i don't understand.
WG not releasing would somehow make more sence to me.
      02-11-2012, 08:28 AM   #4
E90SoFlo
Drives: E90 335i
I have a boost leak that only appears after 6 seconds, you need to log your car
      02-11-2012, 09:03 AM   #5
etichi
Slow,fast,slow, then you die.
etichi's Avatar
Drives: 335i 07,AA short shifter, COBB
I had misfiring. Cured only with changing my plugs.
      02-11-2012, 09:39 AM   #6
EastBayE90
Formerly (-(ellblazer420
EastBayE90's Avatar
Drives: 07 E90 335i M/T, 15 F80 M3 DCT
Check your vacuum lines sounds similar to when I had ruptured vacuum lines going to my waste gate accumulators. It is most likely a boost leak as others have said.
(410whp 445ft/lbs | DCI + Meth Only)
OpenFlash OTS Stage 1 Flash | Vishnu PWM Meth Kit | Vishnu DCI| Forge DVs
      02-11-2012, 10:56 AM   #7
boostaholic786
boostaholic786's Avatar
40
Drives: E92 N54 with MHD Custom flash
Man honestly I think its a boost leak as well because basically its not holding boost pressure properly. The charge pipe diverter valves are very weak when your running the amount of boost we run so I would check there first. I have had the same issue about the car going in limp mode but that was because I pushed its limits and the car put its self in limp mode.
      02-11-2012, 07:47 PM   #8
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
It does sound like a boost leak but i always tell people to reset adaptations when any hiccup arises and go from there.
