BMW 3-Series (E90 E92) Forum
ERROR MESSAGE: Please insert navigation disk!
07-27-2011, 09:42 PM | #1 |
Rep 464
Friends,
I have a 2007 335i, last week when I tried to use my nav it gave me an error to insert the navigation DVD. I have tried everything: 1. Took out the DVD then inserted in back again 2. Restarted the car 3. Took the nav DVD and inserted a mp3 DVD and it played with no problem. I took the car to the dealer and dealer says that I have to replace the drive. Which to me is not right because I can play the mp3 DVD but cannot use the nav DVD. They want 550 for it so I was wondering if anyone else had the same problem and if there is anything I can do to fix it or how hard is it to replace the DVD drive (if I had to) myself. Could it be that the disk is bad...because I checked the disk and the are no scratches or scuffs on it. Looks very clean and new. Any help will be greatly appreciated. Thank you... |
07-29-2011, 03:10 PM | #4 |
Rep 1,573
I had the same problem. It started intermittently on several long trips from DC to FL and back. Progressively got worse. Tried my 2011 Nav DVD thinking it was a scratch/deformed DVD. Made know difference. Once Sterling replaced with a new drive unit problem solved
08-01-2011, 07:25 AM | #5 | |
Rep 912
You may try to use good quality cleaning CD for your drive first, however most probably it will not help so you should be changing your DVD drive. |
