BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > PROGMAN (CIP) v25.xx BMWNA SIB
      03-22-2007, 01:58 PM   #1
cobradac
cobradac's Avatar
20
Drives: '05 645Ci Coupe
2005 645Ci  [0.00]
Complete SIB in attached pdf file.
SI B 61 03 05
General Electrical Systems March 2007
Technical Service
This Service Information bulletin supersedes S.I. B61 03 05 dated December 2006.
designates changes to this revision
SUBJECT
Software Errors Corrected with Progman
MODEL
E90, E91, E92 E93 (3 Series)
Vehicles produced up to February 28, 2007
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 25.00.00 (Target data Status E89x-07-03-515).
If there is an incoming telephone call while SVS (Voice Input System) is active it is not possible to accept or reject the call.
A loud humming noise can be heard from the auxiliary fan when the vehicle is idling.
The automatic transmission enters "Failsafe" mode during a 5-4 downshift. EGS fault "AF8D – ratio monitoring 5-4 gearshift plausibility" is stored.
CCC: The programmable diamond MFL button does not work when set to "Next entertainment source" when vehicle is in motion.
CCC: The customer occasionally has poor radio reception after the vehicle was programmed with Progman V23.x or V24.x.
The speedometer and tachometer needles shake when the vehicle is idling.
CCC: Slow response to inputs made when using controller after startup.
CCC: A high frequency whistling noise intermittently can been heard in radio mode
CCC: Navigation system pop-up arrow display missing. Refer to SI B84 61 06.
CCC: CD/CDC track advances after key cycled. Refer to SI B65 32 05.
SDARS (Satellite radio) receiver fault "A537 – Sat aerial short circuit" is stored.
PROCEDURE
For all vehicles, on a customer complaint basis only, refer to the following procedure and warranty information.
Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman 25.00.00 ( Target Data Status E89x-07-03-515) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
      03-22-2007, 02:07 PM   #2
BMW06
BMW06's Avatar
Drives: F15 xDrive35i
Thanks.. It helps.
      03-22-2007, 02:12 PM   #3
HyperM3
Too many Alex's, from now on, call me Beaufort
Drives: See Sig
Ok, out of curiosity. If my car is being delivered at the end of this month, do I request that this version is in my car or will it automatically be upgraded by the dealer during PDI?
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip
16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone)
07 335i(gone)
      03-22-2007, 02:27 PM   #4
canucklion
pull my finger to get your kinder® surprise
canucklion's Avatar
Drives: circles around you
^ check with your dealership, usually they're more willing to update it for you (if it doesn't have the updated version already from the factory) when you're just picking up the car vs later on
However, later on, you can complain about any of the above 'reasons' and voila, a new update
      03-22-2007, 02:55 PM   #5
pseto
pseto's Avatar
Drives: E92 M3 ZCP, F80 M3 ZCP- beater
So, if I go and complain about the above items, the stealer should be able to update to progman 25 (I have 24) under warranty? are there any items above that would cause an error message that is detectable to contradict what I say?
Paul Seto - BMW Car Club of America
President, National Capital Chapter (MD/DC/NoVA)
Director, National Events ///M Chapter
Become a BMW CCA member; Click HERE to join and use my member #339225 for a referral
Join our NCC Facebook Page
      03-22-2007, 03:02 PM   #6
Frank_NJ
///M Specialist
Frank_NJ's Avatar
Drives: E30 M3, E52 Z8, G83 M4Cx
Just made an appointment with my dealer and they are going to upgrade my car next week on the 28th. I had the radio issues, the missing arrow, and another issue which this should address hopefully!
2023 M340ix my Daily Driver
G83 M4CV, F80 M3 CS, E30 M3, Z8, other various BMW's
Ferrari F8
      03-22-2007, 03:09 PM   #7
Chi-town330
Chi-town330's Avatar
Drives: E90 330i
2006 E90 330i  [0.00]
GREAT! this is just another bug we can use to get them to install V25. to those that haven't read about this on the other posts - V25 supposedly has several improvements, added functionality (POI by name), faster, and resolves a few bugs.
another bug is the pop up arrow display feature when Nav is enabled and arrow display is not selected.
I talked to my local dealer earlier this week, quoted the arrow pop-up bug, and they said they would load the new SW for me....but they won't have it until next week.
MINE: E90 330i - 8.22.06 Build | Jet Black | Black Dakota | Burl Walnut | ZPP | ZCW | Nav | Step
-> Added: 162 18" rims | iPod Interface | Aluminum Pedals | 50% Tint
HERS: E46 325CiC – 02 | Steel Blue Metallic | Blue Top | Gray Dakota | PP | CW | Step
      03-22-2007, 03:27 PM   #8
SkipSauls
SkipSauls's Avatar
Drives: E70 X5 35d
I'm hoping that this fixes the "loud humming noise" that I've heard in my car, and the satellite fault fixes the problem where it sometimes thinks that I haven't subscribed.
Thanks for the info!
      03-22-2007, 03:44 PM   #9
daves335i
Drives: BMW 335i
I have that exact same radio problem! Let me know what you find out.
07 BMW 335i Sedan, JB2, Jet Black, Premium, Sport, Heated Seats, Hardwired V1
01 Audi S4 Stage I (APR) (sold)
??-01 Nothing worth mentioning
      03-22-2007, 03:50 PM   #10
GregL
GregL's Avatar
Drives: 2016 CLA45 AMG
"CCC: Slow response to inputs made when using controller after startup."
Doesn't this mean that pretty much any of us with iDrive can get a free update based on this? Unless perhaps BMW has a radically different concept of time.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      03-22-2007, 04:00 PM   #11
user1
Drives: 01 330ci; 07 335i
Some have reported 30 seconds to a minute of freeze time after starting the car. For example, selecting entertainment after start up causes the screen to hang for substantial time. My guess is this is what is meant by slow response to inputs. Just 5 seconds of waiting for a screen probably wont cause a need for the upgrade even though 5 seconds feels like an eternity when driving. It never hurts to ask your dealer. They will probably ask you to come in to take a look at the slow screens first hand.
      03-22-2007, 04:29 PM   #12
335inSC
Drives: 2007 335i
I called my dealer and quoted the arrow issue and I'm now scheduled for service in two weeks... I'll keep my fingers crossed that they upgrade to V25.
      03-22-2007, 04:46 PM   #13
shadowcoder
shadowcoder's Avatar
Greece
51
Drives: 2006 330i
Why keeping your fingers crossed? There isn't much that they can
do BUT upgrade you to V25 if them and you want this fixed. And if they
don't want to fix it, show them your baseball bat in the trunk of you car
      03-22-2007, 06:24 PM   #14
GregL
GregL's Avatar
Just make sure to take it with you before giving them the keys for service, otherwise it'll probably get stolen
      03-22-2007, 06:27 PM   #15
rrandyy
Drives: E92 328
If you get this done, please post some pictures or confirm that the POI search is functional and that the main screen graphics have been removed...
I realize some EU pics have been posted already, but would like a "second opinion"
      03-22-2007, 08:12 PM   #16
sflgator
sflgator's Avatar
148
Drives: '09 MB C63 AMG & '08 MB GL450
SI B 61 03 05
Technical Service
SUBJECT
MODEL
SITUATION
PROCEDURE
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
Can anyone explain this "CCC: Navigation system pop-up arrow display missing" thing?
Is this when you've selected a destination and the Navi map is displayed, are the routing arrows supposed to "pop up" before you take the turns (but they don't)?
What if you have the small Navi screen on the right and the large Entertainment screen on the left activated...are the routing arrows still supposed to pop up? This is the way I usually have mine set, even when I set a destination, but I would like it if I could actually "see" where I'm supposed to turn via the routing arrows; I only hear the voice telling me where and when to turn (of course, it rarely says the exact street name -- usually just says to turn up a ahead onto "the highway.")
Thanks.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod |
| TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers |
      03-22-2007, 09:03 PM   #17
shadowcoder
Greece
51
Drives: 2006 330i
Thanks.
That's exactly what it is. With V25 you will have the option to enable the
pop-ups so if you have the navi map on the right and you are doing guidance
you will see the arrows popping up for turns etc when before you wouldn't.
And if you had the navi on mute you would be happily missing turn after turn
after turn
      03-22-2007, 09:16 PM   #18
Chi-town330
Drives: E90 330i
this is a repost from another thread, but here is the service bulletin regarding the arrow display pop up bug issue, and the "fix" (V25).
http://www.bmwtis.com/tsb/bulletins/...p/B846106g.htm
I got this from Shadowcoder above
      03-22-2007, 09:59 PM   #19
GregL
GregL's Avatar
I think you'll have to re-post that link...
      03-22-2007, 10:33 PM   #20
Chi-town330
Drives: E90 330i
edited above post and repaired. sorry about that.
      03-22-2007, 10:52 PM   #21
sflgator
sflgator's Avatar
148
Thank you; looks like I'll be getting my Navi s/w update after all.
      03-23-2007, 08:26 AM   #22
tomswift
TomSwift
Drives: BMW 335i
I hope the CD/CDC track advances also fixes the problem with my iPod advancing since it uses the same CD selection. It is a pain for audio books. I also experience the NAV slow response, and the pop up window. I will be scheduling today.
Thanks for posting.
Tom
