Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Turbo question on E92 335i ?
      09-09-2006, 09:31 PM   #1
vinen
Drives: 335i coupe
My buddy drives a 911 turbo and has to cool down the turbos by letting the car idol before turning off the engine. He says it is a necessary step with any turbo engine, otherwise the oil does not continue to run through the turbos while they have a chance to cool down. Otherwise the oil would just frye inside of the turbos (not good).
Is letting the engine run while the turbos have a chance to cool necessary with the 335i?
      09-09-2006, 09:50 PM   #2
Pedal2Floor
Pedal2Floor's Avatar
Drives: 335i Euro Delivery Fall 2008
How old is his Porche? This has not been true for most modern turbos in a long time. Unless it specifically says so in the manual, it is not required for modern turbos. The reason for this is at one time because engines used Dino Oil. With Synthetic oil it is not necessary because there is no "coke" up effect that used to happen before Dino Oil. When this was a problem people used "Turbo Timers" that would do the cooling down for you. On a modern turbo when the engine is shut off, coolant continues to circulate due to thermal convection, helping to prevent long-term heat-related damage to the turbo bearings.
Its not necessary unless your buddy has an old Porche that required Dino Oil and will certainly not be required for the 335i.
This question has been answered many times in Motor Trend and C/D. At one time one of the Acura sites had a very good write up on this but I can't find it anymore.
      09-09-2006, 10:19 PM   #3
vinen
Drives: 335i coupe
okay, thanks for the info. I thought it seemed odd...his is an 02 and maybe he is just misinformed or being ultra cautious over his baby...
      09-09-2006, 11:14 PM   #4
r3amir
r3amir's Avatar
88
Drives: 2023 X2
The BIG question is: Are the Turbo engines as reliable as other engines?
2018 540i Mineral White/ Cognac
2015 435i GC Midnight Blue Metallic, Saddle Brown
2011 535i Alpine White, Oyster/Black leather
2006 325i Arctic Metallic
      09-10-2006, 08:20 AM   #5
Pedal2Floor
Yes -- what would make a Turbo less reliable? The boost on the 335i is not exactly very high. The new compression ratios are not in the startosphere.
In the past, reliability was more do to the turbos themselves. A lot of R&D and lot track time has made them reliable. If you go back to the 70s, there was no question to the 2002ti's reliability. When Nelson Pekay won the Formula 1 championships in the first ever turbo powered car, there was no issues.
While turbos do run hotter, cooling, coolant systems and synthetic oils have all been designed for the high heat.
Answer me why they would be unreliable?
      12-21-2021, 08:36 AM   #6
Bush Pilot
Bush Pilot's Avatar
Drives: 08 BMW 335i Coupe, 04 BMW 325i
The answer to the original poster's question is a resounding, "Yes.". The rationale is that the turbo motor is more complex with more parts that can fail. In addition since the turbo runs hotter the whole system experiences a greater range of heat cycling thereby putting more heat stress on the entire system.
      12-21-2021, 09:08 AM   #7
stewbets
Drives: '08 335xi, '04 545i
THANK YOU!
I've been waiting FIFTEEN YEARS for this answer.
2008 335xi 6MT - 16T China Turbskies - eBay FMIC, DP & CP - VRSF Inlets - SSR DCI's - Walbro 450 LPFP - RFP e85 Tune
      12-21-2021, 12:18 PM   #8
Saif2018
Drives: E90 335i
Originally Posted by stewbets View Post
THANK YOU!
      12-22-2021, 04:59 PM   #9
Bush Pilot
Bush Pilot's Avatar
      12-22-2021, 05:39 PM   #10
whyzee125
Drives: Dinan stage 2 335i
The reason our cars have an electric water pump is to keep coolant cycling after cooldown to allow the turbos to cool down slowly. I never wait for the car to cool down and just turn it right off unless I've been pushing it in the last few minutes or the oil temps are above the usual 200 deg range. If they're like 230-240, I'll let it idle for a minute or drive very gently the last mile.
      12-23-2021, 11:08 AM   #11
Bush Pilot
Bush Pilot's Avatar
I agree with your philosophy. That said, my oil temperature is typically 215-220 F under normal driving. I did see 250 - 260 at the track.
whyzee1251690.50
