05-17-2024, 08:03 PM | #1 |
Rep 1,280
HELP! Paging tire and wheel experts (BrockDM and others)
I started talking to Andy over at ORT wheels, based on this listing
https://x3.xbimmers.com/forums/showthread.php?t=2103707 And working with them to do carbon-copy of 789M in gold bronze (M5CS). He suggested 275/40 and 315/35 20s tires on 10/11" rims. The calculator numbers look amazing, but I have significant concerns with fitment, rubbing and "poking" past the fenders. I really dont feel comfortable with this setup. I would like to do 275/45 and 305/40 20s, and there are some good options in those sizes. The other question is, what offset do I need to make this work? Opinions/Suggestions/Comments/Concerns are more than welcome. Let me hear from the experts. Last edited by TacosRule!; 05-17-2024 at 08:36 PM.. |
05-17-2024, 08:19 PM | #2 | |
Need mo $$s
977
Rep 983
I'm running this setup, with no poke at all... Vossen HF-5s in Satin Silver, Deep Concave 21x9.5 ET16 with 275/35-21 PS4S 21x11 ET35 with 315/30-21 PS4S Photos: https://x3.xbimmers.com/forums/showt...ight=completed
2020 TRM-BLACK X4///M Competition
1995 Dodge Stealth TwinTurbo Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
05-17-2024, 08:32 PM | #3 | |
Rep 1,280
But on your setup, Do you have any issues with rubbing? How much space do you have between the end of the rim and the suspension? How much stiffer is the ride driving on rubber bands? What tires are you running on these sizes? Thanks again for the info |
05-17-2024, 08:52 PM | #5 | |
Need mo $$s
977
Rep 983
No, but I'm not lowered at all, stock suspension How much space do you have between the end of the rim and the suspension? No issue with clearance to the suspension at all, did trim a very small part of the sound insulation at the top just as a precaution. How much stiffer is the ride driving on rubber bands? It rides better on my 21s than on my winter 20s to be honest. My winter 20s are: Asanti ABL-31 in Satin/Gloss Black Deep Concave 20x9 ET25 with 265/45-20 Pirelli Scorpion Zero AS 20x10.5 ET38 with 295/40-20 Pirelli Scorpion Zero AS What tires are you running on these sizes? As mentioned above, my 21s are mounted with PS4S
05-17-2024, 09:11 PM | #6 | |
Rep 1,280
Didnt see the PS4S. Thank you much for the follow up, appreciate it. EDIT: forgot to mention. I'll be going MSS but will leave them at the highest possible setting. Talking to Ben from RGSport, leaving it at 40mm front and 45mm rear should put me at around 1/2" drop from stock, mostly due to springs settling down. I feel it's cutting it close. Last edited by TacosRule!; 05-17-2024 at 09:23 PM.. |
95wildtt977.00 |
05-17-2024, 09:52 PM | #7 | |
Rep 2
05-18-2024, 09:03 AM | #8 | |
Need mo $$s
977
Rep 983
He's seen a LOT of these
1995 Dodge Stealth TwinTurbo Past: 2020 Macan, 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 05-18-2024 at 09:08 AM.. |
05-19-2024, 12:56 PM | #9 |
Rep 1,280
