04-11-2024, 02:08 PM | #1 |
Rep 11
Catted downpipe question(s)
New member, just picked up a low mile 2020 X4 M40i. About the only thing I want to do at this time is a high flow catted downpipe.
Do all the lower cost (20 cell/inch/square) generate a CEL? Or is it a luck of the draw of it will/won't? Seems there is only one that has the same cell density as stock that guaranteed not to generate a CEL, but it's $1500 (Active Autowerke). Those that have the cheaper version and get the CEL, is there a way to permanently get rid of it? Thanks |
04-11-2024, 02:33 PM | #2 |
Cowboy Astronaut Millionaire
2326
Rep 2,896
Cell will happen on all except AA.
Then either live with the light or you need a tune like MHD or BM3 to clear out the CEL.
04-11-2024, 02:39 PM | #3 |
Captain (Retired)
4075
Rep 1,798
Depending on your 2020 production date you MIGHT NOT need to send your DME off to Helsinki to get it unlocked to upload a proper tune
Someone here will know that particular cutoff date but you’re likely close |
earlgsxbusa126.00 |
04-11-2024, 02:51 PM | #4 |
Rep 65
Rottweiler4074.50 |
04-11-2024, 02:51 PM | #5 | |
Rep 620
I too am on the hunt for a DP for my 2021 X3 M40i. 200 cell seems to be luck of the draw, but it seems most will have the dreaded CEL pop up at least intermittently, if not consistently without a tune with a 200 cell DP. As far as 400 cell DP's go, there is also MST: https://www.mst-performance.com/products/bw-5809dp and possibly Racing Dynamics: https://www.racdyn-usa.com/PROD/130+10+58+170.html While they don't specify fitment on the G01, other products do crossover between the G05/G06 and G01/G02 B58's. Cutoff for FEMTO unlock is 6/2020. If your DME has a production date prior to this, you can do a simple bench unlock in the states, which typically runs about $250. Easiest way to check this is buy the OBDII adapter and download the MHD app. It will tell you if yours needs a FEMTO unlock for zero out-of-pocket expense beyond the OBD adapter. The next easiest way is to get under your hood and pull the DME up just enough to see the production date on the sticker. Last edited by biz77; 04-11-2024 at 02:58 PM.. |
04-11-2024, 08:10 PM | #7 |
Captain (Retired)
4075
Rep 1,798
https://www.bimmerpost.com/forums/sh...php?p=31039519
Get this and then do a tune w/ the money you save |
earlgsxbusa126.00 kini620.00 |
04-12-2024, 04:05 PM | #8 |
Rep 217
On my X3 M40i LCi I have CG Precision DS-1 catted downpipe
Perfect sound, cheaper than AA and no CEL! https://www.youtube.com/shorts/x9S2MGcNmzQ |
04-12-2024, 06:33 PM | #9 | |
Rep 11
As for the previous post, no desire to go for a tune. At most it would just be some type of piggyback module. |
04-13-2024, 01:46 PM | #10 |
Rep 267
Drives: 2022 X3 M40i
Here’s a link to the sound of my decatted downpipe… Decatted X3 M40i
04-14-2024, 04:00 PM | #11 |
Rep 5
I have a 2021 X3 M40i and got the Apex Built catted downpipe. It is a 400 cell GESI that is guaranteed to not cause a CEL. Purchased it a year ago for $1,100. It also cost $1,250 to get it installed by a professional shop. I’m still not sure if I overpaid.
HOWEVER, do not buy it. I get a CEL once a month or so, more frequently during the summer months. It is always the same; low cat efficiency. If I clear the code and drive it slow, the emissions test will pass (all green check marks). If I rev it to redline though, it will fail emissions. The CEL comes on after I push it for a few days, but at least I can pass emissions when needed. I contacted Apex Built a few times, but they are not responding to my emails. Even contacted the CEO directly via email. No luck. They seem to be refusing to honor their “guarantee.” Avoid them at all costs. Definitely try AA. Here is how it sounds, even got rid of the resonator. |
kini620.00 |
04-14-2024, 04:15 PM | #12 |
Captain (Retired)
4075
Rep 1,798
I’m waiting for the responses to this detail
Some members here are going to be 2b below… https://www.merriam-webster.com/dictionary/apoplectic |
04-14-2024, 04:38 PM | #13 | |
Rep 1,840
md_m40i180.50 lakerzfan_24695.00 |
04-15-2024, 04:54 PM | #14 | |
Rep 11
As for the install it seems like even a DYI only takes an hour even without a lift. |
04-16-2024, 06:12 AM | #16 |
Rep 287
Unless you have a tune, not a piggyback, getting any DP is pointless and actually results in less power in the usable range. With a tune they can actually dial back in power using the higher exhaust flow and mitigate any CEL's.
If you're going to spend money use it on things that actually add performance. |
04-16-2024, 06:17 AM | #17 |
Rep 287
"It also cost $1,250 to get it installed by a professional shop. I’m still not sure if I overpaid."
Let me settle that for you. Yes, you way overpaid. My last car had two cats and they were a PITA to get out. Cost me $500 for a reputable shop to do the swap. |
04-16-2024, 06:19 AM | #18 |
Rep 287
04-16-2024, 04:17 PM | #19 | |
Rep 11
04-16-2024, 04:28 PM | #20 |
Rep 287
Modern cars are limited by torque to their Factory spec. No matter what bolt ons you put on the car is going to keep its torque ratings in the range of its spec. The only Pace you normally see any gain without a tune is on the top end which is pretty much unusable under normal driving. 9 out of 10 people that get these things without a tune typically just want it so they can say they modded and improve the sound. In a turbocharged car you will get way more gains with just the tune then if you had every bolt on available dropped on with the factory tune. Once you get a tune from a reputable tuner it can be modified to adapt to the new bolt ons and then you'll get even more horsepower and torque.
kini620.00 |
04-17-2024, 05:16 PM | #21 | |
Rep 11
04-17-2024, 05:35 PM | #22 |
Rep 287
I am not sure about the cat backs that are available but you're on the right track. You'll be able to get a much better sound without the threat of warranty issues. I'm looking at these options as well and I would not consider any Cat-Back unless it also Incorporated the exhaust valves. I wish borla made a system for this car because I have used their exhaust many times in the past and they always make a wonderful deep tone without any drone or raspiness
