03-30-2024, 10:56 AM | #1 |
Rep 1,121
Jump starting
For future reference, I want to know where is best to "jump start" my 2020 X3.
I have one of those NOCO jump start units for emergency purposes. Typically I would attach it directly to the car battery for a jump.......BUT.......I see that under the hood there is a remote connection for connecting cables for a jump start. My question: IF a jump start is required, is it best to connect directly to the car's battery (in the rear) ..... OR...... is it best to connect to the "remote" connection that's under the hood? My guess (but only a guess) it would be best to connect under the hood since that is much easier than taking apart or lifting panels in the rear to access the battery directly.......... Anyone? Thx Last edited by rob175; 04-02-2024 at 09:02 AM.. |
03-30-2024, 11:09 AM | #2 |
Rep 981
Have not used on X4…. But had to do so on Audi TTs and wifeys LR… both with under the hood receptacles. Use under the hood for jumping… that’s the main reason they exist. Works flawlessly.
03-30-2024, 11:10 AM | #3 |
Rep 1,367
BMW recommends you jump start the car from under the hood:
On the X3 the negative chassis ground is a rather large bolt, can't miss it under the passenger side of the hood. |
JDsX3520.50 nyalpine907444.00 |
03-30-2024, 11:25 AM | #4 |
Rep 2,797
Drives: 2020 M4 ZCP / 2023 X3 M40i
Always use the connection in the engine bay. The only reason to access battery in the trunk is to replace it.
nyalpine907444.00 |
03-30-2024, 03:09 PM | #6 |
Rep 282
Drives: 2019 X3 xDrive30i, 2021 X3 M40
I've used this portable charger in the past. Works well and no other car needed.
https://www.amazon.com/NEXPOW-batter...68542532&psc=1
Present: 2019 X3 xDrive30i, Mineral White/ Mocha Vernasca / 21" 701M and 20" Savini Black wheels / RaceChip
Present: 2021 X3 M40i, Alpine White / Oyster Vernasca / 20" 699M Former: 2006 Z4, 1981 320i, 1973 2002, Jag XKE, SS396 Chevelle, 440 Dodge RT, 40+ others |
04-01-2024, 07:59 AM | #7 |
Rep 1,121
Thanks but I prefer the NOCO GB40 for jumps starting all of my cars, motorcycle and boat if/when needed. (luckily seldom used). About $100 but very well made with lots of other features (emergency lighting, cell phone charging etc etc.)
04-01-2024, 09:02 AM | #8 |
Rep 282
No problem. Just as an fyi to others, the $42 Nexpow has the same emergency lighting and cell charging features. I also have an earlier purchased $100 NOCO but decided on the Nexpow to keep in our other car for half the cost.
04-02-2024, 01:19 AM | #9 |
Rep 271
Attach it to the front terminals. It's easy - power must be delivered to the engine starter, ECU, ignitor - no point in transferring "precious" amperes from the rear. It's said that those cables (I think 5 m of them) are not the best quality - like 20 mm2 of solid copper. I wouldn't be surprised they were aluminium copper coated. Just just to crank the engine if the battery is OK.
04-02-2024, 04:03 AM | #11 |
Rep 164
Rottweiler4073.00 |
