02-20-2024, 02:22 AM | #1 |
Rep 35
Front fog lights
Is there a way/trick to turn on the front fog lights without turning on the headlights? On my 325Ci you simply turn on the parking lights then turn on the fog lights that didn’t work..
02-20-2024, 06:26 AM | #2 |
Found the Search Button
1663
Rep 1,217
Drives: 2022 X3 30i xDrive
Get BimmerCode
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
02-20-2024, 08:18 AM | #3 |
Rep 110
02-20-2024, 08:45 AM | #4 |
Rep 662
Haven’t seen a way to do it automatically, it’s a pretty manual process. My bigger issue is I can’t get the halo’s to dim with only parking lights, they run at full power until the headlights are on. It’s in bimmercode and I’ve tried multiple times, maybe just won’t work. I have the adaptive led (just not icons). Pre-lci
02-20-2024, 08:49 AM | #5 | |
Rep 752
Drives: BMW 2018 X3 GO1
Not a real good picture but .
Present:
Jet Black 2018 X3 30i Previous: Sapphire Black 2013 X3 28i , Jet Black 2007 X3 3.0 Liter |
02-20-2024, 10:32 AM | #6 |
Rep 7,588
DITTO...if you go to the www.bimmercode.app website and click on the SUPPORTED CAR link at the top center of the page...you can select your model and then get a list of areas that can be coded and the module in which it can be found.
See example below..found under the LIGHTING heading:
02-21-2024, 04:52 AM | #9 |
Rep 7,588
Happy coding. I’m sure there are other parameters you might enjoy. Go through the supported coding parameters on the website for your model so that you can make a list. Then you can code all the things you find interesting and make all the changes in one coding session. If you go longer than a few minutes….you should either break up the coding session or hook up to a battery charger so that your BMW doesn’t shut down during coding. This is where owners can start to have issues if a module loses power while you’re trying to code it.
03-25-2024, 09:03 PM | #11 |
Rep 35
Coded now I can run fog lights with parking lights during light rain. The dealership said they could make the change for $260 it cost me about $140 for program down load and one dbx it also works on my 2003 325Ci for key functions removed delays for windows and sunroofs🤠
03-25-2024, 11:26 PM | #12 |
Rep 1,771
Does the bimmer code let you turn on cornering lights with any option, there is no fog lights on G01 any more but cornering lights actually help a lot, only if we could enable them on demand.
2024 X3 m40i
03-26-2024, 08:16 AM | #13 |
Rep 662
I was able to code them to come on in reverse, with turn signals (as opposed to just when turning) and with high beams on, but I don’t see how you could get them on all the time. I guess you’d need a switch like a fog light switch or to dial them down to zero turning angle. Not sure that’s possible and you’d have a problem with the opposite side on your turn turning off. Note, I’m pre-lci with id6 (2019).
03-26-2024, 09:00 AM | #14 | |
Rep 1,771
2024 X3 m40i
03-26-2024, 09:08 AM | #15 | |
Rep 4,376
03-26-2024, 09:36 AM | #16 |
Rep 662
03-26-2024, 09:42 AM | #17 |
Rep 4,376
03-26-2024, 10:00 AM | #18 |
Rep 662
Not sure this apply's to LCI, but here is a link the chat, spreadsheet is attached about ½ down from Gugin-
https://x3.xbimmers.com/forums/showthread.php?t=1786778 |
hyde569.00 |
03-26-2024, 06:24 PM | #19 |
Rep 287
I haven't tried this yet but have a question. I've coded my fog lights to come on with high beams and with parking lights but if you just hit the fog light button typically the headlights come on too. With it coated for the parking lights will the headlights still come on if you hit the fog light button while your lights are off? Or does it now come on with just the parking lights?
03-26-2024, 06:26 PM | #20 | |
Rep 662
03-27-2024, 11:44 AM | #21 |
Rep 287
03-27-2024, 06:17 PM | #22 |
Rep 662
