01-06-2024, 07:39 PM | #1 |
Rep 3,029
Drives: 2019 M2 Competition
Hey yall
Anyone else running into your parking brake badly sticking down? After rain or a wash, about 75% of the time the parking brake pad will be completely stuck to the rotor. It takes pressure to move then BANG its free. 2300 miles on the car and have been told that "they all do that", which is not an acceptable answer for me. Anyone else seeing this?
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
01-06-2024, 07:47 PM | #2 |
Rep 297
Yes, is normal especially if the rotors are very wet when you park, and then it completely dries. A layer of surface rust builds up between the pad and the rotor. It’s less intense if you don’t apply the parking brake in these situations.
01-06-2024, 07:53 PM | #3 | |
Rep 3,002
I think your problem is right there... |
BMW DIY Guy3080.00 |
01-06-2024, 07:56 PM | #4 |
Rep 3,029
01-06-2024, 07:57 PM | #5 |
Rep 3,029
Really frustrating if so..
01-06-2024, 08:08 PM | #7 |
Rep 297
01-08-2024, 09:45 PM | #10 |
Rep 88
Yeah this happens. At least after a wash, if you could drive the car afterwards, it would help. it also helps if you don't use your e-brake.
It's common and much more stuck with more performance oriented brake pads. It actually happens with all sorts of brake pads but in many lower priced cars, they have smaller pads/rotors, so the surface of adhesion is less. You might also notice this less in cars that use the drum as the e-brake. |
nype139.50 |
01-09-2024, 09:17 AM | #11 |
Rep 8
This happened to me this morning for the first time. Really freaked me out until I finally got it to break free. I washed the car last night to get the road salt off of it, but I guess the rotors never fully dried afterward. Going to do some hard braking next time to make sure it doesn't happen again.
01-09-2024, 09:36 AM | #12 | |
Rep 1,176
After a drive in the rain I ride the brake pedal a bit to warm up the brakes and dry the brakes before putting the car away in the garage. Before when I had just car ports to use while the brake discs might get a bit of rain water on them it was not enough to cause the pads/rotors to stick. If there is any rust any suspected rust on the rotors it is important to use the brakes lightly to remove any rust. I had one case where the brakes were really rusty, so much so the parking brakes were frozen similar to what you experienced -- my fault I failed to drive the car after a wash -- and didn't use the brakes until I had to make an emergency stop. Afterwards the brakes manifested a bit of a pulsing. The stop resulted in uneven pad material deposition on the rotors. This was way back in 2002. I learned my lesson. Since then when I wash a car I always drive it after and make it a point to use the brakes enough to get them hot and thus dry. The parking brake hardware is buried in the rear hubs and there is no way to know when the parking brake hardware is dry but so far when I go to use the car again the parking brakes do not stick so I must be getting the brakes, including the rear hubs/parking brake hardware hot enough. |
aerobod3638.50 |
01-09-2024, 09:39 AM | #13 |
Rep 3,029
All solid advice but I live in Washington.. its raining 50% of the year and about 4 months straight during the winter. Its not reasonable to get the brakes dry before parking in the garage every day, just no way to make that work.
I am just confused by the behavior candidly, and never had this issue with any prior model of BMW. Maybe its the new OEM pads, the material or whatever.. its irritating behavior honestly.
01-09-2024, 10:05 AM | #14 | |
Rep 1,176
I've parked cars after driving in the rain and the discs are dry. They are also warm I'm sure. I've never had any real issues with a car parked during a rain or sitting out in the rain for a reasonable amount of time. The only time I've had an issue with the brakes locking up was when I parked a car after washing it. The parking brake hardware rusted up some and after releasing the parking brake the car didn't budge at first. More throttle and a bit more aggressive clutch engagement and the brakes let go with a pop. If you find you can't avoid the issue about all I can recommend -- and it is not ideal -- would be to not use the parking brake. But you must leave the transmission in gear (manual) or in P (automatic). And I would chock the wheels. In gear/P and with wheel chocks I believe the car would be ok in a garage assuming the car is parked on the level. Out on the street I'd not use chocks but of course apply the parking brake along with using the transmission to help secure the car and leaving the car with the front wheels turned in the correct direction. |
aerobod3638.50 |
01-09-2024, 10:08 AM | #15 | |
Rep 3,029
01-09-2024, 11:41 AM | #17 |
Rep 263
The best thing to keep rust off your brakes is to coat your brakes with a grease or a heavy oil. That will provide a "lifetime" protection of rust on your brakes.
ps- please don't do that
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
01-09-2024, 12:56 PM | #18 | |
Car Geek
3639
Rep 3,602
Our Macan S and prior Golf R have the same problem due to a similar setup with the electric parking brake. |
M2siast5916.50 |
01-09-2024, 01:43 PM | #19 | |
Rep 297
However, when I wash the car on the same level in our parkade, that’s a whole other story. The brakes really stick if I leave it to dry in the parking spot overnight, for example. |
