11-06-2023, 09:07 AM | #1 |
Rep 5
Current km/miles on your X3 and Repairs done
Hey, I thought I would start this post because my car was humming along until just last year during Boxing Day when my timing chain alignment broke. After getting that replace, there were a few other items that came up that I had to fix. Just wondering what km/miles others are getting out of their car so I can look forward to that or expect to replace it soon. What minor or major repair have you had to do since you got the car. I will start with this format.
Car: 2013 X3 Xdrive28i Current km/miles: 220,000km Minor/Major Repair: 12/2022 - Timing chain kit replacement 01/2023 - Vacuum pump replacement 08/2023 - Vanos adjuster valve replacement Last edited by atl5; 11-06-2023 at 09:33 AM.. |
11-06-2023, 12:12 PM | #2 |
Rep 32
Car: 2016 X3 xdrive28i (LCI)
Current km/miles: ~80k(almost 50k miles) Minor/major repair: Absolutely nothing, all regular maintenance on time. Any advice for preventative replacements? |
11-06-2023, 12:44 PM | #3 |
Rep 5
I think you are doing well with just the regular maintenance. Don't think there is anything that you can replace as a preventative measure as it would just be a waste of money, if that part never breaks down and you still have low km.
11-07-2023, 08:23 AM | #4 |
Rep 322
Drives: E46 M3 & LCI X3 35i M Sport
2016 X3 35i - Currently 60k miles.
Bought the car 2 years ago with 48,500 miles. Only thing that was needed mechanically: VRSF Chargepipe - Stock one blew up on day 2 of ownership. Others: 3x oil changes New tires New Battery (By choice, didn't want to get stranded) Brake Fluid flush And that's it... will probably flush my TC/Diff's/Trans soon maybe. TBD |
11-07-2023, 10:13 AM | #5 |
Rep 2,928
2014 28i with 72,000 miles. Only actual repair in the history of the car is seals on the oil filter housing gasket. Not even a burned out bulb. Otherwise, one battery, a new belt, one set of pads and rotors, plugs, filters, tires and oil.
11-07-2023, 11:21 AM | #6 |
Rep 1,933
2012 X3 28i (N52)…120K miles. ….the stuff that “broke” so to speak:
-Gaskets: oil pan, valve cover, oil filter housing -Rear hatch shocks -fan belt & Tensioner |
11-07-2023, 05:30 PM | #7 |
Rep 100
2012 X3 35i with 168,000. Have owned since 2014 and 40k. Radiator, a/c compressor, battery, water pump and thermostat x2, valve cover and gasket, OFHG and oil cooler gaskets x2, oil pan gasket, intercooler pipe, expansion tank hose, oil cap, coil packs, accordion hose from PCV that age hardens and cracks super easy, vacuum pump hose split, tensioners and belt and walnut blast. Also have done trans fluid changes and pan x3, transmission cooler that mounts to fan shroud (leaking) not to mention tension struts x2, guibo, driveshaft center support bearing, brakes x3. Of course plugs, filters, tires and fluid changes (brakes, engine oil, transfer case, diffs and aforementioned trans). Taillights LED circuit board replacements (all 4), replaced passenger door armrest and drivers door pull handle and reglued glovebox door. Do all my own work.
11-08-2023, 08:38 AM | #8 | |
Rep 5
Wow, that is quite detailed which I am sure you have kept a log of all the maintenance and repair. You've saved yourself tons of money doing these yourself, wish I was that handy.
11-08-2023, 12:37 PM | #9 | |
Rep 322
Something I struggled with before I started doing my own work was thinking it was more complicated than it really is. (With exceptions of course) Once I got over that mental block I attempted some complicated repairs on my M3 and it all went great. There's a great sense of accomplishment trouble shooting and fixing things on your own. Food for thought. Last edited by mwat; 11-09-2023 at 06:46 AM.. |
Bilbofraggins284.00 Don T3.00 |
11-12-2023, 05:24 PM | #10 |
Rep 80
2013 35i, 240k kms. Runs great. Suspension is still 100% original. Had to replace turbo due to stuck wastegate. Just replaced valve cover due to leaky hard gasket. Water pump done once....counting the days. Other than that just routine maintenance. Never burned a drop of oil. All drivetrain fluids every 100k kms.
I'm considering weather to invest in replacing springs and shocks. |
Wgosma828.50 |
11-26-2023, 08:36 AM | #12 |
Rep 405
Drives: 16 X3 28d/18 540d xdrive
2016 X3 28d xdrive with 80K miles.
Repairs aside from usual wear items: Two rear springs and one rear wheel bearing. |
11-27-2023, 02:58 PM | #13 | |
Rep 683
mwat183.00 |
11-27-2023, 04:46 PM | #14 |
Rep 683
Question, I'll hit 100k in a month or so on my recently purchased F25 N55 but does the 100k service require anything major for the N55, like timing chain or is it mostly flushes, lubrication, filters, etc that I can do myself? I dont have the service manual that tells whats needed.
12-02-2023, 04:50 AM | #17 |
Rep 912
For anyone doing the timing chain job (we did on a 2015 28i Xdrive), either themselves or taking bits to an Indy - don’t use a non oem branded crankcase seal - we used a corteco (normally no prob) but it leaked after a couple weeks.
At 150K (km) only stabilizer links (on third set) are the non routine maint or non-preventative maint thing done. Grease-able links probably a better choice. Last edited by Bilbofraggins; 12-02-2023 at 04:57 AM.. |
Wgosma828.50 |
12-02-2023, 04:54 AM | #18 | |
Rep 912
12-05-2023, 03:30 PM | #19 |
Rep 39
Drives: 2023 X3 M40i
Current miles: ~86k Transfer case replacement under warranty Brakes once Third set of tires |
12-07-2023, 05:16 PM | #20 |
Rep 24
Drives: 2020 M2 Comp / 2005 330i ZHP
X3 f25 110k
Replaced diff fluid
Replaced trans fluid Replaced front diff fluid Replaced transaxle fluid Front and rear brakes Coolant change Brake fluid change Numerous oil changes 2 full sets of tires Charge pipe change, blew apart on way home from Florida Full front end replacement all hardware, w/alignments drives like new. Needs, oil pan gasket replacement in 2024 |
Wgosma828.50 |
12-09-2023, 05:59 PM | #21 |
Rep 733
Are water pump and thermostat failures less common with LCI models? Thought I'd see it mentioned but no one yet. Maybe already replaced?
Was about to buy a '17 35i today but flaked because of reliability concerns. Want one of these so bad Last edited by a5m; 12-09-2023 at 06:05 PM.. |
12-10-2023, 08:21 AM | #22 |
Rep 135
2017 F25 N20 engine.
Current mileage 76,000 km Regular engine oil changes Replaced spark plug and coil 38,055 km Flushed brake fluid 52,758 km Replaced rear differential shaft seals 64,000 km I saw lengthy postings about this subject several years ago. I could not find it now. |
