09-26-2023, 04:33 PM | #1 |
Car guy
1049
Rep 1,324
Driver profile keeps changing to "Guest"?
I've noticed lately that when I get in my car the driver profile frequently changes to "Guest" on it's own and I have to manually change it back to my profile. It seems to happen randomly and for no apparent reason.
I'm the only driver of my car and I have only used one key fob since I bought it. I never use the key fob to lock or unlock so it just stays in my pocket. I changed the battery on the fob a few months ago so I know it's not that. Any ideas why this keeps happening? |
09-27-2023, 01:37 PM | #2 |
How YOU Doin?
1815
Rep 1,635
Drives: 2022 BMW X3 M40i
Does your car have the new 03/2023 update? I thought that there were a few people who remotely updated theirs and had that problem. I see you have a pre-LCI, so it would have had to be a dealer-installed update, but maybe it's a bug in the software?
09-27-2023, 04:49 PM | #3 |
Rep 71
Same thing happened to me after dealer updated mine to 03/2023. Seemed to change to guest mostly if I opened the hatch first using comfort access before opening drivers door. Now if I’m opening hatch first, I unlock the car by pressing the key fob and it seems to keep my profile.
09-27-2023, 05:39 PM | #4 |
Rep 1,040
My 2020 has done it 2 or 3 times. It's OK if you notice before you start the car as you can change profiles, but once you start it, it is a right pain to switch profiles.
GloppyGlop8.00 |
09-27-2023, 07:01 PM | #5 |
Rep 1,939
Drives: 2022 X3 M40i
have you relinked your key to your profile?
09-28-2023, 12:35 AM | #6 |
Rep 71
First time it happened to me I didn’t notice it had switched to guest profile till I went to press one of my favourite keys and nothing happened. Realised they were all blank so had to find somewhere to pull over as you needed to be stationary to switch profile. One of my favourites is set to a phone number which gives me barrier access to a site I was going to. You’re right it’s a pain especially when it required a PIN number to switch which I couldn’t remember being set up. Luckily because it was a four digit one I guessed right first time.
dangerous_al425.00 |
09-28-2023, 04:52 PM | #7 |
Car guy
1049
Rep 1,324
Thanks, I'm due for service in about a month and will ask my SA to check that.
09-28-2023, 04:55 PM | #8 | |
Car guy
1049
Rep 1,324
09-28-2023, 05:27 PM | #10 |
Rep 137
Has happened to me 3-4 times as well usually when first starting the car. I usually just power down and then power up and sometimes it will switch. Otherwise I have to manually change the driver if I can remember the PIN.
It's a pain... |
09-30-2023, 12:13 PM | #11 | |
Rep 113
Is this not intended behavior? Is there a way to fix this?? |
09-30-2023, 02:58 PM | #12 | |
Found the Search Button
1913
Rep 1,404
Drives: 2022 X3 30i, 2003 330i ZHP
You are correct that you can only have one fob per profile… but I guess they figured who would need multiple fobs all for themselves? If you did use both fobs and wanted them both linked to the same profile, why not at least link then one you use most often and then manually select the profile on the other rather than do that on both?
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
2003 330i ZHP, Black / Black Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
10-12-2023, 05:16 AM | #13 |
Rep 103
My ‘21 X3 M40 does this occasionally. It’s a safety thing too because once I’m driving and realize it my side mirrors change. Of course I change them on guest profile but it really should not happen. I’ll mention to the dealer next time. Just an annoying glitch.
'21 X3 M40i (daily driver)
'22 430i gran coupe (wife's) '17 M4 6 MT azurite metallic black/amaro '07 530xiT (son's) |
