09-23-2023, 08:00 AM | #1 |
Rep 121
Engine Oil change on BMW X3
Hi.
I have BMW X3 Xdrive 20d MSport F25 chasis and i think it has B47O engine. Can some one please guide me how much oil do I need. I think it was between 5-6 litres but not 100% sure. Also what socket size do I need to remove the oil filter cap. I have tried 19mm and it was too small. next one up I have is 32mm and that's too big. any help will be much appreciated. |
09-23-2023, 09:03 AM | #2 | |
Rep 8,106
Check your owners manual (if you have one)…look in the rear index for CAPACITIES to see if this info is listed in your manual. The B47 engine takes 5 liters of oil:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-23-2023 at 09:49 AM.. |
09-23-2023, 02:48 PM | #4 |
Rep 121
in case someone else is searching the same question i found the answer about oil filter cover size here
you will need 27mm socket to open it. |
