09-08-2023, 04:09 PM | #1 |
Rep 71
Does X3 Need Coded When Replacing TPMS Aerial/Antenna?
If you replace the antenna for TPMS sensors, does it need recoded again to communicate to wheel sensors?
09-08-2023, 06:16 PM | #2 |
Rep 8,098
Help us help you better…remember to leave enough info about your vehicle so that the forum can look up correct info.
What is your model/model year or build date? Do you have an RDC module, or does your X3 fall within the production range when the RDC module’s function was incorporated into the DSC control unit? Perhaps an answer is in the data below:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-08-2023 at 06:54 PM.. |
tracer bullet3433.50 pungo960.50 |
09-17-2023, 01:43 PM | #4 |
Rep 8,098
Wow…after all the stuff I look up…you delete your posts…and without a stinking thanks?
pungo960.50 |
09-18-2023, 05:17 PM | #5 |
Rep 71
All I asked was if the car needed coding when you replace the aerial in the back. Nothing you provided answered my question when, the simple answer was yes, it does need coded to communicate to the TPMS sensors in the wheels. None of what you provided from your saved Bookmark was of any use to my initial post.
09-18-2023, 06:28 PM | #6 | |
Rep 2,650
Drives: Z4MC, X3-35i,525i, Corrado G60
