08-13-2023, 07:51 PM | #1 |
Rep 1,833
Drives: 2022 X3 M40i
zf 8hp aluminum transmission pan upgrade
Shot in the dark here, but has anyone here upgraded their transmission pan to a aluminum one. I plan to change the "lifetime fill" fluid at every 40k. Yes ZF recommends to change it at 50-65k miles, but it won't hurt when done a tad early. Dealer quote 1700 to change but doesn't recommend it...the SA and I quote " we don't recommend it because over time the fluid will be thicker and when putting new fluid will be too thin."
I know PPE makes one but there is/was a fitment issue with the neutral screw being in the way maybe? It does add an extra quart of fluid but due to the extra size the underbody cover won't fit over it. https://www.turnermotorsport.com/p-1...xoCRx0QAvD_BwE or from https://www.in-power.design/product-en install vid from Kies but can be found for cheaper on other sites. I just question the filter element...but it does come with all new hardware and a service kit is avail with new filter and bolts for future changes. Or just stick with oem cover and filter... |
08-13-2023, 11:40 PM | #2 |
Rep 1,234
" we don't recommend it because over time the fluid will be thicker and when putting new fluid will be too thin" - holy crap, some people really are clueless. Jeez.
08-14-2023, 12:25 PM | #3 |
Father of Frankenfold
300
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I've done the trans pan upgrade research previously. The factory aluminum pan used on the M5, X5M, X3M, etcetera, part number 24119503407 is the best choice, even versus aftermarket pans. It adds capacity, cooling and still uses an easily source-able replaceable filter.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
08-14-2023, 12:40 PM | #4 | |
Rep 1,833
LMAO, oh jesus fuck, it 200 dollars more because of M fitment over stock pan. FCP euro has it listed for around 500.00 bucks and still no fluid, ok ok...is it still plastic? Last edited by Burr001; 08-14-2023 at 01:45 PM.. |
08-16-2023, 11:10 AM | #6 |
Rep 1,833
08-16-2023, 10:59 PM | #8 | |
Rep 1,833
As suby01 would say it was tree fiddy, plus 60 bucks for a service kit, plus shipping. Kies has just the pan for 400 but I already had a shit moment with them in a past order. |
08-16-2023, 11:16 PM | #9 | |
Rep 2,115
Just logged in to my parts guy ETK account, and looks like my price would be $346.19 + tax. |
08-16-2023, 11:56 PM | #10 |
Rep 2,115
Well, different pans fu*k for each 8HP 50, 51, 76!
ocdx30.00 gofastbmw5100.00 |
08-17-2023, 11:20 AM | #12 |
Cowboy Astronaut Millionaire
2324
Rep 2,894
I dislike it when you find things that I dont need but now want. Obviously keep us updated on the install. Im at 30k miles only but I will swing for this in the next 10-15k miles for sure.
Bee Pee1787.50 |
08-17-2023, 12:47 PM | #13 |
Rep 1,833
I figured stock pan and filter was around the same price, but the service kit is only 60 more the next time i change fluid. To me was also getting rid of the plastic pan, but I'll post pics once it comes in.
Its being sold though MST as the distributor. It comes with new hardware, but not a new fill plug, so part # is 24117552349 for BMW Automatic Transmission Fill Plug Edit:the kit kit comes with a new fill plug. Last edited by Burr001; 08-28-2023 at 11:11 AM.. |
08-25-2023, 11:51 AM | #14 |
Rep 309
Had a similar issue with my local BMW dealership. My work horse (2018 X3) has 70K and it was due for the transmission, transfer case and front / rear diff fluid service. They told me the same BS "lifetime fluid" and refused to do it.
Took it to a local indy shop with all the stuff I picked up from the dealership and they did it all. Don't listen to the dealership. Make sure you do your driveline fluids! Transfer case and diff fluids were the worse. Transmission fluid wasn't terrible but certainly needed to be done.
2018 X3 Xdrive30i
2019 X3 M40i 2004 Supercharged Acura TL 6MT, NAVI A-Spec 2022 M3 Competition XDrive |
Burr0013383.00 kevinwoods26.50 |
08-27-2023, 04:16 PM | #15 | |
Rep 552
08-28-2023, 07:23 AM | #16 | |
Rep 552
24-11-9-503-407 alum ( m cars) 24-11-5-A13-115 plastic |
08-28-2023, 11:07 AM | #17 | |
Rep 1,833
Update: the Inground pan does come with a new fill plug, as I can't read..lol I purchased the pan from Luxious Automotive for $350.00 https://www.luxiousauto.com/products/8hp/oilpan and the service kit for $60.00 https://www.luxiousauto.com/products/8hp/sealkit?v=202 Shipping from Taiwan was $80.00 total and hit the US in 10 days and I should have it in hand from local PO in a day or 2. both kits come with Oil pan screw x 13 Filter screw x 7 Magnetic Oil Drain Plug x 1 Oil filler drain plug x 1 Filter x 1 Pan Gasket/Seal From the pics there are no magnets mounted in the pan like the stock piece, but include a magnetic Oil Drain Plug to collect the shavings. I will take detailed pics when its here. |
Rottweiler4062.50 |
08-28-2023, 01:55 PM | #18 | |
Rep 552
Interesting and ya all the M cars come with the dedicated trans cooler to help cool of the extra fluid. If you don't have a trans cooler I'm not sure the oem upgrade will be ideal. Last edited by Dasky_spas; 08-28-2023 at 03:14 PM.. |
08-30-2023, 07:01 PM | #19 |
Rep 1,833
So the pan came in and the extra service kit, will install it hopefully soon and see how it goes. Not too shabby, nice materials and the filter element is decent. The magnet not so much, but I plan on changing every 40k.
5LEEPR_G01508.00 dinan5m34371.00 Rottweiler4062.50 Gr8ZongB58294.50 jsh1391722.00 kevinwoods26.50 Usachampion189.50 joebie3337.00 |
08-31-2023, 07:05 PM | #21 |
Rep 552
Was there a reason you didn't get the oem aluminum pan? Seems to fit and it has far larger fins for heat dissipation.
08-31-2023, 07:18 PM | #22 |
Rep 1,833
