11-30-2022, 01:09 PM | #1 |
Rep 478
Coolant Smell - Drivers Side
Does anyone else experience a strong coolant smell after driving from the drivers side wheel well/underhood area?
I am getting a strong smell of coolant, but no leaks. I took it to the dealership and they said they could smell it, but after a pressure test and visual inspection they found no leaks. They also checked the IC brick. Obviously the smell is still there. Has anyone else experienced this? |
12-03-2022, 11:32 AM | #2 |
Rep 315
Drives: '19 BMW X3 M40
Yes I’ve noticed the smell in garage after pushing hard in Sport or Sport+ No visible leaks on floor.
@enthusiast_1_ Current: 2019 X3 M40x Dark Graphite Metallic; Previous: 2017 BMW M240i xdrive (Sapphire Black); 2013 BMW 335ix M sport coupe (White) beast of a car/let slip away; and 2011 BMW 328ix- coupe (Silver)
95wildtt872.50 |
12-04-2022, 08:11 PM | #3 |
Rep 63
I have the similar issues and I lose a little bit of coolant every few thousand miles. I talk to my SA he said he has seen a couple come in with that issue but it’s not common but he couldn’t tell me exactly what it is. If you find out please post responses here!!!
12-05-2022, 02:46 PM | #4 |
Silent OPerator
Rep 37
Same here
No leaks that I can see on my garage floor, I am missing more than just a little after driving... wonder where to start?
LEV
2011 ///X5 M package/all possible options |
12-05-2022, 06:35 PM | #5 |
Rep 437
Drives: 2021 X3MC
https://g30.bimmerpost.com/forums/sh....php?t=1970498
Different platform I know but these engines are so complicated it can be any of these causes |
12-06-2022, 06:01 PM | #6 |
Rep 478
I am glad I am not the only one. Please come back and post if your dealer finds a remedy. I took mine in and they pressure tested the system and found no leaks, also inspected the IC brick as that was a common failure point on the s55 and found no issues.
They told me to keep an eye on it and bring it back if I get a low coolant warning. Tech did note it was not low. I am OCD so this is going to bother me until I get it figured out ha. My C63s did something similar and I actually sold the car. My G80 did not do this, but it had fewer miles (3k vs 15K) |
12-06-2022, 06:35 PM | #7 | |
Rep 37
After I went home and got a flashlight and what I could tell was coolant came out the overflow and I got a pressure washer (electric) with a low pressure nozzle and cleaned it a little with some simple green. After that a bit of the smell has been gone, but I get a hint again under that heavy pedal sport + typing driving and I pull in my garage. My garage is pretty sealed so and my ocd for this type of stuff is high. It is refreshing to know I’m not the only one, but clearly the dealer isn’t communicating with other dealers or whoever should know further up to determine if we are having an issue. It is a relatively new platform. |
12-18-2022, 03:28 AM | #8 |
Rep 1
My car is at the dealer for 2 things this being one, The first thing has been repaired but i was asked, "what smell?" My car is supposed to be ready in a day (for the first thing) and i am not going to accept that answer and take it home. I will let u know where this goes.
12-21-2022, 10:30 AM | #9 |
Rep 478
Keep us posted mountainrivera
Oddly I notice the smell a lot more in sport or sport+. I wonder if it has something to do with the water pump seeping or more coolant flowing through the system so the overflow leaks? Driving me insane to the point I want to sell the car ha |
12-21-2022, 11:14 AM | #10 |
Rep 7
Drives: 20 X3MC, 2011 VW GTI
I’m having the same issue. It’s going to the dealership tomorrow to take a look at. I’ll report back with what they say.
12-23-2022, 09:24 AM | #11 |
Rep 478
12-24-2022, 10:32 AM | #12 |
Rep 7
They couldn’t find anything wrong. Pressure tested the system and it came back fine.
Frustrating but I’ll keep an eye on it to see if it gets worse. Hoping someone else gets resolution on it. |
12-27-2022, 10:52 PM | #13 |
Rep 478
Same thing with mine. Hoping some others chime in. Glad there doesn't seem to be a glaring issue, but its kind of annoying to know there is definitely coolant somewhere by the smell.
12-28-2022, 08:50 AM | #14 | |
Need mo $$s
873
Rep 913
I have it too, but only when the engine is really hot. Pressure test may not be enough to get it to happen.
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
12-29-2022, 11:39 AM | #15 |
Rep 478
My thought too, evaporative loss you can smell from a vent or something. Kind of sucks for a 80k car to smell like its leaking coolant. My G80 didn't do this but I kind of remember my c63s smelling like this but it had a leak.
12-29-2022, 12:18 PM | #16 |
Need mo $$s
873
Rep 913
Our '20 Macan also does it after being driven a lot in the summer, must be a venting under high pressure/temp or something.
01-02-2023, 07:02 PM | #17 |
Rep 240
I haven't experienced the engine coolant smell, but the other day my "coolant low" light came on when I started the car. THen it went away and hasn't come back on?
It was the coldest it's been where I live in like 20 years though. Not sure if that had anything to do with it or not. |
01-02-2023, 08:27 PM | #18 | |
Need mo $$s
873
Rep 913
I topped it off, no issues since. |
01-03-2023, 09:42 AM | #19 |
Rep 478
If it is low it has to be going somewhere. I am hoping one of us gets lucky with a really thorough tech and we can find the issue and get it fixed for a few of us.
01-03-2023, 03:53 PM | #20 |
Need mo $$s
873
Rep 913
It had gone down about 1/4" in almost 3 years... so I'll just attribute that to acceptable normal losses. But may explain the smell on occasion.
01-10-2023, 04:41 PM | #21 |
Rep 478
I am still getting the smell, I checked the engine bay and dont see any leaks, I am half tempted to put a dye in the coolant and see if I can find it myself but I dont want to be pulling apart my newish car that is under warranty.
Hoping eventually someone finds the issue and can tell us all what to replace! |
02-01-2023, 08:10 AM | #22 |
Rep 478
Drove the car around in the snow yesterday (20 mph the entire time), when I parked it back in the garage the coolant smell was really bad. I checked the res, still full. This is the weirdest issue.
