11-28-2022, 04:49 PM | #1 |
Rep 92
Drives: 21 x3m
Help with getting replacement clip
Tried this on my x3m FB group, with no luck, so I figured I would try here hoping someone in parts dept or a scrap yard could help out...
Was running the wiring for the wife's dash cam and I somehow managed to misplace the retaining clip for the attached photos. 21 x3m pass side footwell plastic cover by knee airbags. Cover Part number is 51-45-9-484-240 (thanks scott) but i cant seem to find the PN for the clips that clip into the instrument panel support bar that these twist locks go into |
11-28-2022, 07:24 PM | #2 |
Rep 668
Drives: 2023 X3 xDrive 30i
The clip is 51165A260C9 (item 20). It should be used in conjunction with securing clip - 07149321592. The cover is item 18 on the part diagram.
11-18-2023, 01:39 PM | #3 |
Rep 34
same thing happened to me, and found this post from my google search. I am sharing what've found, hopefully it will help others with this problem. I think that part/clip is really loose from the factory so I don't think I will be the last person that have this issue. Anyway, the
part # are: 07149393174 - quarter turn lock part #20 above 07 14 9321592 - washer that hold the lock so it won't fall out 07149321590 - I think this is the BMW part # of this 'clip' luckily, this is not a proprietary BMW only part. I could be wrong, but it is actually made by Southco, this is their D1 DZUSŪ Dart Quarter-Turn Fasteners part # D1-004-012-010 or D1-004-013-010, 013 is a little bit bigger, so I think this is D1-004-012-010. as mentioned, since this is not a proprietary part, other European cars like Audi also uses this quarter-turn lock/latch system to keep things in place. just search for part # 4A0-805-163.... I ended up buying a kit for Audi on Amazon that has 10 of these and other stuff in the kit for $15. good luck, I hope this help someone else, as I've spent hours to search for this clip. |
