11-21-2022, 02:15 PM | #1 |
Rep 3
Lugs seized - any advice?
Working on my 2013 F25 and using a breaker bar only managed to get one lug off. Blasted it with WD40 yesterday and soak overnight - still no go. Even hit it with impact gun and no bueno. Any other suggestions?
11-21-2022, 02:59 PM | #2 |
Rep 152
IMO What works best is shock therapy. Get 1 ball pein hammer and one small sledge hammer and put the ball pein hammer on the lug and whack it with the sledge. Doing that a few times shocks the threads and loosens them, then hit it with the impact or breaker.
11-21-2022, 04:22 PM | #3 |
Rep 2,650
Drives: Z4MC, X3-35i,525i, Corrado G60
Welcome to the forum...
WD-40 is not much of a penetrating oil, use something like PB-Blaster, Liquid Wrench, etc... that are meant for this type of application. Is that a 1/2" drive or 3/8" drive socket? The breaker bar looks kinda wimpy as well as the impact gun. You could always take it to a garage where they have the proper equipment to loosen them or go buy some better tools |
tracer bullet3432.50 |
11-21-2022, 04:33 PM | #4 |
Rep 2,928
Being from Ohio originally I know corrosion/rust can be an issue, but the one bolt laying on the ground does not look corroded and neither does the hole it came from. That raises the question of who last tightened the wheel bolts. A lot of people think wheel bolts are supposed to be as tight as you can get them, but they are only supposed to be about 100 ft/lbs, which is not really all that much. But I agree that is a pretty wimpy breaker bar. Your biggest issue may be the one with the wheel lock. You may not get much torque on that before it strips off.
11-21-2022, 06:51 PM | #5 |
Rep 8,098
Do you have a pipe that you can use to extend your breaker bar? If you do, adding length to your breaker bar may help break the bolts free. Hopefully you have someone to help you so that the socket stays on the bolt so that you don't strip them…then gently apply pressure to your extended breaker bar and let physics do its thing.
I have a 4 foot led pipe that helped get a neighbors lug bolts free. I added it to my 2.5 ft breaker bar…when it broke free…it popped like a gunshot…but didn’t strip or snap in half…just gave it a gentle pressure counter clockwise and the lug bolts broke free.
11-21-2022, 08:59 PM | #7 |
Rep 134
It’s not coming off .. I’m stuck with two of the same security bolts on my X3. They will not come off no matter what .. they were stuck on my car when I bought it or were over torqued and stripped somewhere along the way. I’ve tried everything , tire shop, BMW dealer, and all sorts of different tools and methods. This might be our only hope… do you want to go in 1/2 with me?
https://www.ecstuning.com/b-aga-tools-parts/wheel-lock-removal-tool/aga-wlrt~agt/ |
11-22-2022, 11:35 AM | #8 | |
Rep 2,928
11-22-2022, 04:05 PM | #9 |
Rep 1,058
A Big O or Americas Tire will get the locks off. They deal with this every day.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
11-27-2022, 09:48 AM | #10 |
Rep 3
Thanks all for suggestions. Agree prior tire place over torqued it. Should never be this bad. I had my son try whom is much stronger than I at this point and was afraid of rounding it. Taking it into a shop.
Again, thanks all! |
12-05-2022, 12:18 PM | #11 |
Rep 3
Follow up. Took it into specialty shop. They called about 90 mins later stating someone over torqued the lugs and stripped the lug key. Asked who recently worked on it. Lol. So i wasnt the weak one originally thought
12-06-2022, 08:10 AM | #12 |
Rep 2,928
12-06-2022, 10:10 AM | #13 |
Rep 21
I fell out with a garage who tried to charge me for taking the locking wheel nuts off for me after they’d brayed them on in the first place after doing some work on my breaks. I’ve replaced them all with normal nuts now. More trouble than they’re worth the locking wheel nuts
