      09-22-2022, 05:59 AM   #1
mihai_arahidu
mihai_arahidu's Avatar
Drives: BMW X3 F25
Oxygen Sensor, Air Mass System
Hello all, i have the following error codes on my X3 F25, thank you for any sugestions! 🙏
287100 - Oxygen sensor before catalytic converter, signal: too high for partial load
290900 - Air mass system: Measured air mass too high
      09-22-2022, 08:54 AM   #2
Opie55
Drives: '15 650i Convertible
You can look them up on bmwfault.codes and get some additional information.
      09-22-2022, 12:36 PM   #3
mihai_arahidu
Drives: BMW X3 F25
Thank you for the advice, this is what I get from bmwfault.codes:
287100
Check exhaust emission system for tightness. If exhaust emission system is leak-free:
1. Check wires and plug connections
2. If wires and plug connections are OK:
Replace oxygen sensor before catalytic converter.
290900
- Check the sensor system for faults. Here, check in particular the charge-air temperature sensor on the display for plausible values. During a certain period, sensors were installed that displayed excessively high temperatures.
- Check the occurrence of the fault with other faults.
If leaks are found in the exhaust emission system, the following service function must be carried out: Delete adaptations, exhaust emission system.
If leaks are found in the air mass system, the following service function must be carried out: Delete adaptations, air mass system.
If the exhaust-gas recirculation valve is being renewed, the following service function must be carried out: Delete adaptations, air mass system.
