08-27-2022, 07:42 AM | #1 |
Rep 2,558
F97 X3M / F98 X4M -- Members' Wheel & Tire Combinations and Weights
Hopefully this will be a useful resource for wheel/tire combinations as weights and specs are shared by those changing from OEM. I'll keep this OP updated as details are submitted. The lists show completed and with pending weights. I've attached an image of my spreadsheet showing how I'm keeping track.
Appreciation to Members who've already shared their info and to future contributors as this should be a helpful reference for others. Current Number of Combinations with known Weights: 82 Current Number of Combinations with pending Weights: 44 Current Number of Combinations: 126 Current % of Combinations with known Weights: 65% Members' Wheel & Tire Combinations and Weights (heaviest to lightest): GAMA : Total Wt F97/98 for BBS CH-RII (22x9.5 ET20, 22x10.5 ET38)/Contis SpCo6 22 (265/35 R22, 315/30 R22) - 300 lbs https://x3.xbimmers.com/forums/showp...94&postcount=1 and bbs.com and discounttire.com {Ft wheel/tire: 73 lbs, Rear wheel/tire: 77 lbs} {Separate wts - Ft wheel: 43 lbs, Ft tire: 30 lbs, Rear wheel: 42 lbs, Rear Tire: 35 lbs} rj202 - Total Wt F97/98 for BBS SX (20x9 ET30 square)/Bridgestone Blizzak DM-V2 (255/50 R20 square) - 293 lbs https://x3.xbimmers.com/forums/showp...6&postcount=62 and bbs-usa.com for the wheel wts and tirerack.com for the tires {Wheel/tire square: 73.3 lbs} {Separate weights - Wheels: 36.3 lbs; Tires: 37 lbs} 95wildtt : Total Wt F97/98 for BBS SX (20x9 square)/Pirelli Scorpion Zero All Season (255/45 R20, 265/45 R20) - 284 lbs https://x3.xbimmers.com/forums/showp...9&postcount=30 {Ft wheel/tire: 70.8 lbs, Rear wheel/tire: 71.2 lbs} 95wildtt : Total Wt F97/98 for Asanti Black Label ABL-31 (20x9 ET25, 20x10.5 ET38)/Pirelli Scorpion Zero All Season (265/45 R20, 295/40 R20) - 284 lbs https://x3.xbimmers.com/forums/showp...7&postcount=51 and https://x3.xbimmers.com/forums/showp...postcount=2896 {Ft wheel/tire: 70 lbs, Rear wheel/tire: 72 lbs}{Separate wts - Ft wheel: 38 lbs, Ft tire: 32 lbs, Rear wheel: 36 lbs, Rear Tire: 36 lbs} crst4s : Total Wt F97/98 for BMW OEM 764M (20x9J +28, 20x9.5J +39)/Pirelli PZero (255/45 R20, 265/45 R20) - 278 lbs https://x3.xbimmers.com/forums/showp...4&postcount=41 Note the images are not of the OEM 764M wheels - just referencing the post for his weight documentations of the stock wheels. {Ft wheel/tire: 67.6 lbs, Rear wheel/tire: 71.6 lbs} eddesq : Total Wt F97/98 for MSW Type 40 in 'Black/Silver' (20x8.5 ET30 square)/Continental Viking Contact 7 (255/45 R20 square) - 273 lbs https://x3.xbimmers.com/forums/showp...8&postcount=73 and tirerack.com for the Wheel and Tire weights {Wheel/tire: 68.4 lbs, Individual Wheel 35.4 and Tire 33 lbs} brandonloos_21 : Total Wt F97/98 for Brixton RF10 in ‘Satin Black’ (21x9.5 ET20, 21x11 ET25)/ Atturo AZ850 (265/40 R21, 295/35 R21) - 272 lbs https://x3.xbimmers.com/forums/showp...&postcount=176, https://x3.xbimmers.com/forums/showp...4&postcount=12, https://x3.xbimmers.com/forums/showp...&postcount=181, https://x3.xbimmers.com/forums/showp...4&postcount=19, and atturo.com/product/az-850[/url] for the tire weights {Ft wheel/tire: 66.4 lbs, Rear wheel/tire: 69.8 lbs} {Separate wts - Ft wheel: 32.4 lbs, Ft tire: 34 lbs, Rear wheel: 33.7 lbs, Rear Tire: 36.1 lbs} scarzie : Total Wt F97/98 for BBS SX (20x9 +30 square)/Pirelli Scorpion Winters (255/45 R20, 265/45 R20) - 271 lbs https://x3.xbimmers.com/forums/showp...5&postcount=16 and bbs-usa.com and tirerack.com {Wheel/tire: 65.3 lbs, Rear wheel/tire: 70.3 lbs} {Separate wts - Ft wheel: 36.3 lbs, Ft tire: 29 lbs, Rear wheel: 36.3 lbs, Rear Tire: 34 lbs} hamy and J-Pizzle : Total Wt F97/98 for BMW OEM 764M (20x9J +28, 20x9.5J +39)/Pirelli Scorpion Winters (255/45 R20, 255/45 R20) - 269 lbs https://x3.xbimmers.com/forums/showp...98&postcount=2 and https://x3.xbimmers.com/forums/showp...71&postcount=4 Appreciation to J-Pizzle for his PM indicating these weights he measured for the Forum -{Ft wheel/tire: 66.6 lbs, Rear wheel/tire: 67.7 lbs} Riverboa : Total Wt F97/98 for Platinum Retribution in 'Gloss Gunmetal Grey' (20x8.5 +35 square)/Continental Viking Contact 7 (255/45 R20 square) - 268 lbs https://x3.xbimmers.com/forums/showp...27&postcount=3 and tirerack.com {Wheel/tire square: 67 lbs} {Separate weights - Wheels: 34 lbs; Tires: 33 lbs} MJDBMW : Total Wt F97/98 for BMW OEM 765M (21x9.5 J +31, 21x10 J +39)/PS4S (265/40 ZR21, 295/35 ZR21) - 267 lbs https://x3.xbimmers.com/forums/showp...&postcount=706 and tirerack.com and Max Well's weight for the 765M {Ft wheel/tire: 66.4 lbs, Rear wheel/tire: 67.2 lbs} {Separate wts - Ft wheel: 36.4 lbs, Ft tire: 30 lbs, Rear wheel: 36.2 lbs, Rear Tire: 31 lbs} r33_RGSport : Total Wt F97/98 for BMW OEM 765M (21x9.5 +31, 21x10 +39)/Contis SpCo6 (255/40 ZR21, 265/40 ZR21) - 266 lbs https://x3.xbimmers.com/forums/showthread.php?t=1687598 and tirerack.com for the tire weights and Max Well's weight for the 765M {Ft wheel/tire: 64.5 lbs, Rear wheel/tire: 68.5 lbs} {Separate wts - Ft wheel: 36.4 lbs, Ft tire: 29 lbs, Rear wheel: 36.2 lbs, Rear Tire: 31 lbs} cehrl7 : Total Wt F97/98 for BMW OEM 892M (21x9.5 +31, 21x10 +39)/Michelin PS All Season 4 (265/40 R21, 295/35 R21) - 266 lbs https://x3.xbimmers.com/forums/showp...postcount=2724 and tirerack.com and Bestle's deduced weight for the 892M {Ft wheel/tire: 65.3 lbs, Rear wheel/tire: 67.6 lbs} {Separate wts - Ft wheel: 35.3 lbs, Ft tire: 30 lbs, Rear wheel: 34.6 lbs, Rear Tire: 33 lbs} jackal15 : Total Wt F97/98 for BBS SX in 'Crystal Black' (20x9 ET30 square)/Vredestein Wintrac Pro XL (255/40 R20 square) - 265 lbs https://x3.xbimmers.com/forums/showp...7&postcount=27 and https://x3.xbimmers.com/forums/showp...postcount=2859 and bbs-usa.com and tirerack.com {Wheel/tire square: 66.3 lbs} {Separate weights - Wheels: 36.3 lbs; Tires: 30 lbs} denniss : Total Wt F97/98 for GTS Wheels G508_K in 'Gloss Black' (20x9.5 +35 square)/Bridgestone Blizzak (275/45 R20 square) - 265 lbs https://x3.xbimmers.com/forums/showp...6&postcount=88 and https://x3.xbimmers.com/forums/showp...3&postcount=91{Appreciation to denniss for sharing these weights in a PM, 3 Oct 2022 at 452PM- Square wheel/tire: 66.2 lbs} Max Well : Total Wt F97/98 for BMW OEM 765M (21x9.5 +31, 21x10 +39)/PS4S (255/40 ZR21, 265/40 ZR21) - 264 lbs https://x3.xbimmers.com/forums/showp...5&postcount=44 and tirerack.com for the tire weights {Ft wheel/tire: 65.4 lbs, Rear wheel/tire: 66.4 lbs} {Separate wts - Ft wheel: 36.4 lbs, Ft tire: 28 lbs, Rear wheel: 36.2 lbs, Rear Tire: 30 lbs} danniexi : Total Wt F97/98 for BMW OEM 764M square winter setup (20x9 +28 square)/Pirelli Scorpion Winters (255/45 R20 square) - 264 lbs https://x3.xbimmers.com/forums/showp...76&postcount=7 {square setup - wheel/tire each: 65.9 lbs} {Although danniexi didn't measure the weight, it can be reasonably estimated - crst4s measured the 764M PZero front wheel combination at 67.6 lbs, carid.com states Pzero 255/45 R20 weighs 32.7 lbs, so 764M is ~34.9 lbs, and the Scorpion Winters 255/45 R20 weigh 31 lbs (tirerack.com)} Chi-X4M : Total Wt F97/98 for Beyern Damon (22x10 +30, 22x11 +30)/Pirelli P Zero All Season (275/35 R22, 315/30 R22) - 263 lbs https://x3.xbimmers.com/forums/showp...13&postcount=9 Weight info per tirerack.com, customwheeloffset.com, and fitmentindustries.com - {Ft wheel/tire: 63.6 lbs, Rear wheel/tire: 67.9 lbs} {Separate wts - Ft wheel: 33.6 lbs, Ft tire: 30 lbs, Rear wheel: 32.9 lbs, Rear Tire: 35 lbs} D-Pat Murph : Total Wt F97/98 for MSW Type 74 (20x8.5 +35, 20x9.5 +42)/Vredestein Wintrac Pro XL (255/45 R20, 265/45 R20) - 262 lbs https://x3.xbimmers.com/forums/showp...5&postcount=21 and https://x3.xbimmers.com/forums/showp...7&postcount=22 Weight info per tirerack.com - {Ft wheel/tire: 65.5 lbs, Rear wheel/tire: 65.7 lbs} {Separate wts - Ft wheel: 35.5 lbs, Ft tire: 30 lbs, Rear wheel: 34.7 lbs, Rear Tire: 31 lbs} RFGuy_KCCO : Total Wt F97/98 for MSW Type 74 (20x8.5 +35 square)/Vredestein Wintrac Pro XL (255/45 R20 square) - 262 lbs https://x3.xbimmers.com/forums/showp...6&postcount=18 and https://x3.xbimmers.com/forums/showp...0&postcount=16 Weight info per tirerack.com - {Wheel/tire: 65.5 lbs} {Separate wts - Wheel: 35.5 lbs, Tire: 30 lbs} jv004 : Total Wt F97/98 for BMW OEM 892M (21x9.5 +31, 21x10 +39)/PS4S (265/40 R21, 295/35 R21) - 262 lbs https://x3.xbimmers.com/forums/showp...postcount=2193 and tirerack.com and Bestle's deduced weight for the 892M; mr.almeida https://x3.xbimmers.com/forums/showp...&postcount=212 and https://x3.xbimmers.com/forums/showp...ostcount=2590; Kabes https://x3.xbimmers.com/forums/showp...&postcount=184 and https://x3.xbimmers.com/forums/showp...&postcount=187 and https://x3.xbimmers.com/forums/showp...&postcount=193 {Ft wheel/tire: 65.3 lbs, Rear wheel/tire: 65.6 lbs} {Separate wts - Ft wheel: 35.3 lbs, Ft tire: 30 lbs, Rear wheel: 34.6 lbs, Rear Tire: 31 lbs} DKX4///M : Total Wt F97/98 for BC Forged HCS02 in 'Gloss Black lip, Matte Black spokes, Blue titanium bolts' (21x9.5,21x11)/Pirelli Scorpion Zero All Season Plus (265/40 R21, 295/35 R21) - 261 lbs https://x3.xbimmers.com/forums/showp...15&postcount=7 and tirerack.com for tire weights and with appreciation to BC Forged NA for providing the exact wheel weights in a personal communication 17 Nov 2022 AND Jayf97 - https://x3.xbimmers.com/forums/showp...1&postcount=19 and https://x3.xbimmers.com/forums/showp...0&postcount=11 {and with appreciation to BrockDM for assisting in the ID of this BC Forged Model/Style!} {Ft wheel/tire: 62.7 lbs, Rear wheel/tire: 67.8 lbs} {Separate wts - Ft wheel: 29.7 lbs, Ft tire: 33 lbs, Rear wheel: 30.8 lbs, Rear Tire: 37 lbs} Daninavan : Total Wt F97/98 for Verde Empire in 'Graphite Gray' (20x8.5 ET20 square)/Yokohama BluEarth Winter V905 (255/45 R20 square) - 260 lbs https://x3.xbimmers.com/forums/showp...2&postcount=32 and tirerack.com and walmart.com/ip/Verde-Wheels-V44-Empire... {Wheel/tire: 65 lbs} {Separate wts - Wheel: 36 lbs, Tire: 29 lbs} freesole : Total Wt F97/98 for Vossen HF-5 in 'Satin Bronze' (21x9.5 Et16, 21x11 Et35)/Michelin PS4 All Season (255/40 R21, 295/35 R21) - 260 lbs https://x3.xbimmers.com/forums/showp...postcount=2892 and https://x3.xbimmers.com/forums/showp...8&postcount=50 and wheel wts from 95wildtt's estimation and tirerack.com for the tire wts {Ft wheel/tire: 60.8 lbs, Rear wheel/tire: 69.4 lbs} {Separate wts - Ft wheel: 32.8 lbs, Ft tire: 28 lbs, Rear wheel: 36.4 lbs, Rear Tire: 33 lbs}[/I] 95wildtt : Total Wt F97/98 for Vossen HF-5 in 'Satin Silver' (21x9.5 ET16, 21x11 ET35)/Michelin PS4S (275/35 R21, 315/30 R21) - 260 lbs https://x3.xbimmers.com/forums/showp...&postcount=104 and https://x3.xbimmers.com/forums/showp...9&postcount=30 and tirerack.com for the tire wts so the wheel wts could be derived {Ft wheel/tire: 61.8 lbs, Rear wheel/tire: 68.4 lbs} {Separate wts - Ft wheel: 32.8 lbs, Ft tire: 29 lbs, Rear wheel: 36.4 lbs, Rear Tire: 32 lbs} hybridel : Total Wt F97/98 for Alibaba Mnfr replica custom-forged 827M CSL in ‘Gold’ (21x9.5 ET17, 21x10.5 ET29)/Atturo AZ850 (265/40 R21, 295/35 R21) – 256 lbs https://x3.xbimmers.com/forums/showthread.php?t=2106579 and https://atturo.com/product/az-850 for the tire weights {Ft wheel/tire: 62.4 lbs, Rear wheel/tire: 65.7 lbs}{Separate wts - Ft wheel: 28.35 lbs, Ft tire: 30 lbs, Rear wheel: 29.56 lbs, Rear Tire: 33 lbs} Bestle : Total Wt F97/98 for BMW OEM 892M (21x9.5 J +31, 21x10 J +39)/PS4S (255/40 ZR21, 265/40 ZR21) - 256 lbs https://x3.xbimmers.com/forums/showp...9&postcount=37 {Ft wheel/tire: 63.3 lbs, Rear wheel/tire: 64.6 lbs}{Separate wts - Ft wheel: 35.3 lbs, Ft tire: 28 lbs, Rear wheel: 34.6 lbs, Rear Tire: 30 lbs} spta97 : Total Wt F97/98 for Drag DR-77 (20x9 +22 square)/Pirelli Scorpion (255/45 R20 square) - 256 lbs https://x3.xbimmers.com/forums/showp...29&postcount=1 {Ft wheel/tire: 64 lbs, Rear wheel/tire: 64 lbs} tarmactrr : Total Wt F97/98 for Curva C300 (20x9.5 ET30 square)/Continental Viking Contact 7 (265/45 R20 square) - 255 lbs https://x3.xbimmers.com/forums/showp...3&postcount=84 and https://x3.xbimmers.com/forums/showp...6&postcount=93 and fitmentindustries.com and tirerack.com Although tarmactrr didn't weigh these, the Mnfr's weights are from the two links shown. {Wheel/tire square: 63.8 lbs} {Separate weights - Wheels: 28.8 lbs; Tires: 35 lbs} V8MAN : Total Wt F97/98 for Niche Vosso M203 in 'Matte Black' (20x9 ET27, 20x10.5 ET30)/Pirelli Scorpion Winters (255/45 R20, 265/45 R20) - 254 lbs https://x3.xbimmers.com/forums/showp...0&postcount=98 and nicheroadwheels.com and discounttire.com for the wheel and tire wts. {Ft wheel/tire: 61 lbs, Rear wheel/tire: 66 lbs} {Separate wts - Ft wheel: 32 lbs, Ft tire: 29 lbs, Rear wheel: 32 lbs, Rear Tire: 34 lbs} xSOJUx : Total Wt F97/98 for Platinum Retribution in 'Gloss Gunmetal Grey' (20x8.5 ?+35 square)/Pirelli Scorpion Winters (255/45 R20 square) - 252 lbs https://x3.xbimmers.com/forums/showp...&postcount=116 and customwheeloffset.com {Wheel/tire: 63 lbs} {Separate wts - Wheel: 34 lbs, Tire: 29 lbs} Klazu : Total Wt F97/98 for Niche Vosso in 'Matte Anthracite' (20x9 ET27 square)/Nokian Hakkapeliitta R3 (255/45 R20 square) - 252 lbs https://x3.xbimmers.com/forums/showp...9&postcount=76 and nicheroadwheels.com and discounttire.com for the wheel and tire wts. {Wheel/tire: 63 lbs} {Separate wts - Wheel: 32 lbs, Tire: 31 lbs} crst4s : Total Wt F97/98 for Asanti ABL22 (20x9 +35, 20x10.5 +38)/Pirelli Scorpion Winters (255/45 R20, 285/40 R20) - 251 lbs https://x3.xbimmers.com/forums/showp...4&postcount=41 {Ft wheel/tire: 60.8 lbs, Rear wheel/tire: 64.8 lbs} fatalius : Total Wt F97/98 for Dotz Tanaka 'Black' (20x9 ET28 square)/Michelin X-Ice Snow (255/45 R20 square) - 250 lbs https://x3.xbimmers.com/forums/showp...6&postcount=25 {Wheel/tire: 62.6 lbs} {Separate wts - Wheel: 31.2 lbs, Tire: 31.4 lbs} Strick : Total Wt F97/98 for Niche Vosso 'Black' (20x9 ET27 square)/Vredestein Wintrac Pro XL (255/45 R20 square) - 248 lbs https://x3.xbimmers.com/forums/showp...postcount=2853 and nicheroadwheels.com and discounttire.com for the weights {Wheel/tire square: 62 lbs} {Separate weights - Wheels: 32 lbs; Tires: 30 lbs} BlownLSX : Total Wt F97/98 for Rohana RFX11 in ‘Gloss Black’ (20x10 ET25, 20x11 ET30)/ Atturo AZ850 (275/40 R20, 315/35 R20) - 246 lbs https://x3.xbimmers.com/forums/showp...&postcount=167 and https://x3.xbimmers.com/forums/showp...&postcount=169, 1nityrider 's post for the wheel wts at https://x3.xbimmers.com/forums/showp...&postcount=171, and https://atturo.com/product/az-850 for the tire weights {Ft wheel/tire: 59.4 lbs, Rear wheel/tire: 63.6 lbs} {Separate wts - Ft wheel: 26 lbs, Ft tire: 33.4 lbs, Rear wheel: 27 lbs, Rear Tire: 36.6 lbs} Gxs615 : Total Wt F97/98 for BC Forged HCA386 (21x9.5 ET17, 21x11 ET35), PS4S (265/40 R21, 295/35 R21) - 245 lbs https://x3.xbimmers.com/forums/showp...63&postcount=1 and appreciation to BC Forged NA for a personal communication on 21 Nov 2022 detailing the exact wheel weights {Ft wheel/tire: 60.6 lbs, Rear wheel/tire: 62.0 lbs} {Separate wts - Ft wheel: 30.6 lbs, Ft tire: 30 lbs, Rear wheel: 31.0 lbs, Rear Tire: 31 lbs} 2020X3MCDG : Total Wt F97/98 for TSW Vale (20x8.5 ET20 square)/Nokian Hakkapeliitta R3 (255/45 R20 square) - 244 lbs https://x3.xbimmers.com/forums/showp...1&postcount=43 and tsw.com and discounttire.com Although 2020X3MCDG didn't weigh these, the Mnfr's weights are from the two links shown. {Wheel/tire square: 61 lbs} {Separate weights - Wheels: 30 lbs; Tires: 31 lbs} Transfer : Total Wt F97/98 for Niche Vosso Matte Black (20x9 ET25 square)/Pirelli Scorpion Winters (255/45 R20 square) - 244 lbs https://x3.xbimmers.com/forums/showp...8&postcount=53 and nicheroadwheels.com and discounttire.com {Wheel/tire square: 61 lbs} {Separate weights - Wheels: 32 lbs; Tires: 29 lbs} slicer : Total Wt F97/98 for BBS CI-R (20x10 ET25 square)/Michelin X-Ice Snow (265/45 R20 square) - 244 lbs https://x3.xbimmers.com/forums/showp...2&postcount=41 and tirerack.com for tire weights. Appreciate slicer's PM 9 Oct 2022 reporting wheel weights. {Wheel/tire square: 60.9 lbs} {Separate wts - Wheels: 27.9 lbs, Tires: 33 lbs} Twilight_G80 : Total Wt F97/98 for Rohana RFX10 Gloss Black (21x9 ET07, 21x10.5 ET11)/PS4S (255/40 ZR21, 265/40 ZR21) - 238 lbs https://x3.xbimmers.com/forums/showp...15&postcount=1 and https://x3.xbimmers.com/forums/showp...35&postcount=4 and https://x3.xbimmers.com/forums/showp...32&postcount=8 and fitmentindustries.com for the wheel wts and tirerack.com for the PS4S. {Ft wheel/tire: 58 lbs, Rear wheel/tire: 61 lbs} {Separate wts - Ft wheel: 30 lbs, Ft tire: 28 lbs, Rear wheel: 31 lbs, Rear Tire: 30 lbs} slicer : Total Wt F97/98 for BBS LM21 (21x10 ET40 square)/PS4S (255/40 ZR21, 265/40 ZR21) - 234 lbs https://x3.xbimmers.com/forums/showp...&postcount=815 and tirerack.com for tire weights. Appreciate slicer's PM 9 Oct 2022 reporting wheel weights. {Ft wheel/tire: 57.4 lbs, Rear wheel/tire: 59.4 lbs} {Separate wts - Ft wheel: 29.4 lbs, Ft tire: 28 lbs, Rear wheel: 29.4 lbs, Rear Tire: 30 lbs} bigred_m3 : Total Wt F97/98 for BBS CH-R (20x10 ET25 square)/Continental ExtremeContact DWS06+ (265/45 R20 square) - 232 lbs https://x3.xbimmers.com/forums/showp...&postcount=125 and bbs-usa.com for wheel wts (note used CI-R in same size and ET for wt estimation as CH-R in this size/ET didn't list wt), and continentaltire.com/tires/extremecontact-dws06-plus for tire weights. {Wheel/tire square: 58 lbs} {Separate wts - Wheels: 27.9 lbs, Tires: 30.1 lbs} VIBE Motorsports : Total Wt F97/98 for Rohana RFX17 in 'Gloss Bronze' (20x9 ET25, 20x10 ET43)/Pirelli Scorpion Zero All Season (255/45 R20, 265/45 R20) - 232 lbs https://x3.xbimmers.com/forums/showp...&postcount=119 and https://x3.xbimmers.com/forums/showp...71&postcount=1 and tirerack.com for tire weights {Ft wheel/tire: 57 lbs, Rear wheel/tire: 59 lbs} {Separate wts - Ft wheel: 26 lbs, Ft tire: 31 lbs, Rear wheel: 28 lbs, Rear Tire: 31 lbs} bryan03tls : Total Wt F97/98 for Variant Xenon Satin Black (21x10 ET25, 20x11 ET35)/Pirelli P Zero (265/45 R20, 295/40 R20) - 232 lbs https://x3.xbimmers.com/forums/showp...&postcount=106 and variantwheels.com/product/xenon-satin-black/ {Ft wheel/tire: 58 lbs, Rear wheel/tire: 58 lbs} {Separate wts - Ft wheel: 26 lbs, Ft tire: 32 lbs, Rear wheel: 26 lbs, Rear Tire: 32 lbs} Edgar_FriendlyX3M : Total Wt F97/98 for TSW Bathurst (21x9 ET25, 21x10 ET42)/PS4S (255/40 R21, 295/35 R21) - 232 lbs https://x3.xbimmers.com/forums/showp...postcount=3147 {Ft wheel/tire: 56 lbs, Rear wheel/tire: 60 lbs} {Separate wts - Ft wheel: 28 lbs, Ft tire: 28 lbs, Rear wheel: 29 lbs, Rear Tire: 31 lbs} EricP3 : Total Wt F97/98 for Richland Forged GT4 in 'Satin Black' (21x9.5 ET16, 21x10.5 ET30)/PS4 All Season (255/40 R21, 295/35 R21) - 232 lbs https://x3.xbimmers.com/forums/showp...postcount=3576, https://x3.xbimmers.com/forums/showp...postcount=3588, https://x3.xbimmers.com/forums/showp...71&postcount=1 , PM 28 Oct 2023, 0902AM from EricP3 indicating wheel weights, and tire type and tirerack.com for the tire weights {Ft wheel/tire: 54.9 lbs, Rear wheel/tire: 61 lbs} {Separate wts - Ft wheel: 26.9 lbs, Ft tire: 28 lbs, Rear wheel: 28 lbs, Rear Tire: 33 lbs} paxton306 : Total Wt F97/98 for Richland Forged GT4 in 'Double Brushed Dark' (21x9.5 ET16, 21x10.5 ET30)/PS4S (265/40 R21, 295/35 R21) - 231 lbs https://x3.xbimmers.com/forums/showp...&postcount=148 and https://x3.xbimmers.com/forums/showp...&postcount=150 and tirerack.com for the tire weights {Ft wheel/tire: 56.1 lbs, Rear wheel/tire: 59.3 lbs} {Separate wts - Ft wheel: 26.1 lbs, Ft tire: 30 lbs, Rear wheel: 28.3 lbs, Rear Tire: 31 lbs} Mscarn2014 : Total Wt F97/98 for BC Forged RZ01 in 'Brushed Dark Black' (21x9.5 ET17, 21x11 ET35)/PS4 All Season (265/40 R21, 295/35 R21) - 231 lbs https://x3.xbimmers.com/forums/showp...51&postcount=9 and https://x3.xbimmers.com/forums/showp...8&postcount=34 and https://x3.xbimmers.com/forums/showp...postcount=1176 and https://x3.xbimmers.com/forums/showp...postcount=1181 and BrockDM for the wheel weights and tirerack.com {Ft wheel/tire: 55.6 lbs, Rear wheel/tire: 59.8 lbs} {Separate wts - Ft wheel: 25.6 lbs, Ft tire: 30 lbs, Rear wheel: 26.8 lbs, Rear Tire: 33 lbs} scottyfw : Total Wt F97/98 for Dinan DC3 (20x10 ET26, 20x11 ET31)/Pirelli Scorpion Winters (265/45 R20, 285/40 R20) - 230 lbs https://x3.xbimmers.com/forums/showp...&postcount=104 and dinancars.com and discounttire.com (for wheel and tire wts) {Ft wheel/tire: 56.5 lbs, Rear wheel/tire: 58.6 lbs} {Separate wts - Ft wheel: 22.5 lbs, Ft tire: 34 lbs, Rear wheel: 23.6 lbs, Rear Tire: 35 lbs} floating.spirit : Total Wt F97/98 for Vossen S21/Contis SpCo6 (255/40 ZR21, 265/40 ZR21) - 230 lbs https://x3.xbimmers.com/forums/showp...33&postcount=8 and https://x3.xbimmers.com/forums/showp...&postcount=918 and https://x3.xbimmers.com/forums/showp...&postcount=721 and https://x3.xbimmers.com/forums/showp...&postcount=680 and https://x3.xbimmers.com/forums/showp...&postcount=643 and tirerack.com for tire weights {Ft wheel/tire: 55 lbs, Rear wheel/tire: 60 lbs}{Separate extrapolated wts - Ft wheel: 26 lbs, Ft tire: 29 lbs, Rear wheel: 29 lbs, Rear Tire: 31 lbs} BrockDM : Total Wt F97/98 for TSW Bathurst (21x9 ET25, 21x10 ET42)/PS4S OEM (255/40 ZR21, 265/40 ZR21) - 230 lbs https://x3.xbimmers.com/forums/showp...5&postcount=33 {Ft wheel/tire: 56 lbs, Rear wheel/tire: 59 lbs} {Separate wts - Ft wheel: 28 lbs, Ft tire: 28 lbs, Rear wheel: 29 lbs, Rear Tire: 30 lbs} m630 : Total Wt F97/98 for BBS CI-R (20x9 square)/Bridgestone Blizzak LM005 (255/45 R20 square) - 229 lbs https://x3.xbimmers.com/forums/showthread.php?t=1897295 and bbs-usa.com and bridgestonetire.com {Wheel/tire: 57.2 lbs}{Separate wts - Wheel: 27.2 lbs, Tire: 30 lbs} Y0jjimb0 : Total Wt F97/98 for Volk Racing Rays G025 in ‘Matte Gunblack/Rim Edge DC’ (20x9.5 ET15, 20x10.5 ET20)/ Nitto NT555 G2 (275/40 R20, 295/40 R20) - 229 lbs https://x3.xbimmers.com/forums/showp...&postcount=189, https://x3.xbimmers.com/forums/showp...postcount=1719, and nittotire.com/car-tires/nt555-g2-ultra-high-performance-tire/ for the tire wts {Ft wheel/tire: 55.3 lbs, Rear wheel/tire: 59.1 lbs} {Separate wts - Ft wheel: 21.9 lbs, Ft tire: 33.4 lbs, Rear wheel 23.2 lbs, Rear Tire: 35.9 lbs} DBU : Total Wt F97/98 for Vertini RFS1.2 (20x10 ET20 square)/Firestone Firehawk Indy 500 (275/40 R20 square) - 228 lbs https://x3.xbimmers.com/forums/showp...&postcount=104 and https://x3.xbimmers.com/forums/showp...&postcount=111 and vertiniwheels.com/rfs1-2/ {Wheel/tire: 57 lbs}{Separate wts - Wheel: 25 lbs, Tire: 32 lbs} Custom X4M Comp : Total Wt F97/98 for Jova Wheels custom-forged in brushed bronze (21x9.5 ET22, 21x10 ET29)/Michelin PS4S (255/40 R21, 265/40 R21) – 228 lbs https://x3.xbimmers.com/forums/showp...&postcount=140 and https://x3.xbimmers.com/forums/showp...00&postcount=2 and https://x3.xbimmers.com/forums/showp...56&postcount=6 {Ft wheel/tire: 56.2 lbs, Rear wheel/tire: 58 lbs}{Separate wts - Ft wheel: 28.2 lbs, Ft tire: 28 lbs, Rear wheel: 28 lbs, Rear Tire: 30 lbs} ONLYA6 : Total Wt F97/98 for Alutec Raptr Machined w/Black Accent (20x8.5 +30 square)/Yokohama BluEarth Winter V905 (255/45 R20 square) - 228 lbs https://x3.xbimmers.com/forums/showp...95&postcount=3 and tirerack.com for details and weights. {Wheel/tire: 57 lbs}{Separate wts - Wheel: 28 lbs, Tire: 29 lbs}{*Note the ET and tire size choices were estimated after researching tirerack, but a PM was sent to ONLYA6 to see if he can confirm these specs - at which time this note will be deleted*} kyleb350 : Total Wt F97/98 for ASA GT16 (20x8.5 square)/Yokohama BluEarth Winter V905 (255/45 R20 square) - 228 lbs https://x3.xbimmers.com/forums/showp...6&postcount=30 and tirerack.com for the weights {Wheel/tire: 57 lbs}{Separate wts - Wheel: 28 lbs, Tire: 29 lbs} e90trbo : Total Wt F97/98 for BBS LM 407 (20x9 +25 square)/Continental ? Sport Contact 5 (255/45 R20, 265/45 R20) - 228 lbs https://x3.xbimmers.com/forums/showp...5&postcount=96 and bbs-usa.com and discounttire.com {Ft wheel/tire: 56 lbs, Rear wheel/tire: 58 lbs}{Separate wts - Ft wheel: 28 lbs, Ft tire: 28 lbs, Rear wheel: 28 lbs, Rear Tire: 30 lbs} BrockDM : Total Wt F97/98 for BC Forged RZ01 in 'Brushed Dark Black' (21x9.5 ET17, 21x11 ET35)/PS4S (265/40 ZR21, 295/35 R21) - 227 lbs https://x3.xbimmers.com/forums/showp...69&postcount=1 {Ft wheel/tire: 55.6 lbs, Rear wheel/tire: 57.8 lbs} {Separate wts - Ft wheel: 25.6 lbs, Ft tire: 30 lbs, Rear wheel: 26.8 lbs, Rear Tire: 31 lbs} BrockDM : Total Wt F97/98 for Advan GT Beyond in 'Racing Hyper Black' (20x9.5 ET25, 20x10.5 ET32)/Nitto NT555RII Drag Radials (275/40 R20, 315/35 R20) - 226 lbs https://x3.xbimmers.com/forums/showp...&postcount=223 and https://x3.xbimmers.com/forums/showp...&postcount=229 and https://x3.xbimmers.com/forums/showp...3&postcount=79 {Ft wheel/tire: 54.5 lbs, Rear wheel/tire: 58.7 lbs} {Separate wts - Ft wheel: 24 lbs, Ft tire: 30.5 lbs, Rear wheel: 24.2 lbs, Rear Tire: 34.5 lbs} r33_RGSport : Total Wt F97/98 for HRE P101SC (21x9.5, 21x11)/Toyo Tires Proxes Sport (255/40 R21, 295/35 R21) - 225 lbs https://x3.xbimmers.com/forums/showthread.php?t=1687598 {Ft wheel/tire: 52.0 lbs, Rear wheel/tire: 60.4 lbs}[/I] spta97 : Total Wt F97/98 for BBS CI-R (20x9 +25 square)/Pirelli Scorpion Winter XL (255/45 R20 square) - 225 lbs https://x3.xbimmers.com/forums/showp...35&postcount=1 and https://x3.xbimmers.com/forums/showp...99&postcount=5 and https://x3.xbimmers.com/forums/showp...2&postcount=11 and bbs-usa.com and tirerack.com and wt confirmed in a PM from spta97 on 2 Jun 2023 {Square setup wheel/tire: 56.2 lbs} {Separate wts - Wheels: 27.2 lbs, Tires: 29 lbs} BrockDM's Dad : Total Wt F97/98 for BC Forged RS45 in 'Matte Bronze' (20x9.5 ET18, 20x10.5 ET 28)/Michelin PS4 All Season (275/40 R20, 315/35 R20) - 224 lbs https://x3.xbimmers.com/forums/showp...1&postcount=47 and weight info per Brock - {Ft wheel/tire: 53.6 lbs, Rear wheel/tire: 58.4 lbs}{Separate wts - Ft wheel: 24.6 lbs, Ft tire: 29 lbs, Rear wheel: 25.4 lbs, Rear Tire: 33 lbs} BrockDM : Total Wt F97/98 for Japan Racing SL01 in 'Matte Black' (20x10 +25 square)/Michelin Pilot Alpin PA4 (275/40 R20 square) - 224 lbs https://x3.xbimmers.com/forums/showp...&postcount=152 and https://x3.xbimmers.com/forums/showp...&postcount=170 Weight info tires per discounttire.com - {Square setup wheel/tire: 56 lbs} {Separate wts - Wheels: 25 lbs, Tires: 31 lbs} Must_Go_FASTER : Total Wt F97/98 for BC Forged RZ22 (21x9.5 +17, 21x11 +35)/Michelin PS4S (265/40 R21, 295/35 R21) - 223 lbs https://x3.xbimmers.com/forums/showp...65&postcount=1 and https://x3.xbimmers.com/forums/showp...0&postcount=12 {Ft wheel/tire: 55.7 lbs, Rear wheel/tire: 55.7 lbs}{Separate wts - Ft wheel: 25.7 lbs, Ft tire: 30 lbs, Rear wheel: 24.7 lbs, Rear Tire: 31 lbs} BrockDM's Dad : Total Wt F97/98 for Neuspeed RSe102 Satin Black (20x9.5 ET25 square)/Vredestein Wintrac Pro (275/40 R20 square) - 222 lbs https://x3.xbimmers.com/forums/showp...1&postcount=55 and weight info per Brock - {Wheel/tire: 55.5 lbs square}{Separate wts - Wheel: 23.5 lbs, Tire: 32 lbs} BeaminF97 : Total Wt F97/98 for Advan GT Beyond 'Titanium Black' (20x9.5 ET25, 20x10.5 ET32)/Michelin PS4S (275/40 R20, 315/35 R20) - 220 lbs https://x3.xbimmers.com/forums/showp...&postcount=146 and BrockDM's wts for the same wheel specs and tirerack.com for the tires {Ft wheel/tire: 53 lbs, Rear wheel/tire: 57.2 lbs}[/I] {Separate wts - Ft wheel: 24 lbs, Ft tire: 29 lbs, Rear wheel: 24.2 lbs, Rear Tire: 33 lbs} jneumss : Total Wt F97/98 for Asanti ABL27 Dynasty (20x9 ET25 square)/Yokohama BluEarth Winter (255/45 R20 square) - 219 lbs https://x3.xbimmers.com/forums/showp...8&postcount=17 and https://x3.xbimmers.com/forums/showp...9&postcount=77 and https://www.asantiwheels.com/asanti-black-dynasty {Wheel/tire: 54.8 lbs square}{Separate wts - Wheel: 25.8 lbs, Tire: 29 lbs} joebie3 : Total Wt F97/98 for Neuspeed RSe102 Hyperblack (20x9.5 ET25 square)/Vredestein Wintrac Pro (265/45 R20 square) - 218 lbs https://x3.xbimmers.com/forums/showp...&postcount=122 and wheel weight info per BrockDM in his Dad's listing at https://x3.xbimmers.com/forums/showp...1&postcount=55 and tirerack.com for the tire weights - {Wheel/tire: 54.5 lbs square}{Separate wts - Wheel: 23.5 lbs, Tire: 31 lbs} Max Well : Total Wt F97/98 for BC Forged RZ05 in 'Gloss Black' (21x9.5 +31, 21x10 +39)/Michelin PS4S (255/40 R21, 265/40 R21) - 217 lbs https://x3.xbimmers.com/forums/showp...4&postcount=41 and https://x3.xbimmers.com/forums/showp...5&postcount=37 and https://x3.xbimmers.com/forums/showp...5&postcount=44 and https://x3.xbimmers.com/forums/showp...2&postcount=46 and https://x3.xbimmers.com/forums/showp...postcount=2860 and https://x3.xbimmers.com/forums/showp...postcount=1110 and BC Forged directly for the weights {Ft wheel/tire: 53.5 lbs, Rear wheel/tire: 55.1 lbs}{Separate wts - Ft wheel: 25.5 lbs, Ft tire: 28 lbs, Rear wheel: 25.1 lbs, Rear Tire: 30 lbs} KayTees : Total Wt F97/98 for HRE FF11 in 'Hyper Silver' (21x9.5 ET30, 21x10 ET25)/PS4S (285/35 R21, 295/30 R21) - 217 lbs https://x3.xbimmers.com/forums/showp...70&postcount=1 and https://x3.xbimmers.com/forums/showp...08&postcount=5 and https://x3.xbimmers.com/forums/showp...&postcount=109 {Ft wheel/tire: 53 lbs, Rear wheel/tire: 55.4 lbs}{Separate wts - Ft wheel: 25 lbs, Ft tire: 28 lbs, Rear wheel: 25.5 lbs, Rear Tire: 29.9 lbs} Kozumasbullitt : Total Wt F97/98 for HRE P101 in 'Gloss Black' (21x9.5 +16, 21x11 +35)/PS4S (265/40 R21, 295/35 R21) - 215 lbs https://x3.xbimmers.com/forums/showp...postcount=1785 and https://x3.xbimmers.com/forums/showp...6&postcount=48 and https://x3.xbimmers.com/forums/showp...&postcount=709 and https://x3.xbimmers.com/forums/showp...27&postcount=4 {Ft wheel/tire: 52.8 lbs, Rear wheel/tire: 54.8 lbs}{Separate wts - Ft wheel: 22.75 lbs, Ft tire: 30 lbs, Rear wheel: 23.75 lbs, Rear Tire: 31 lbs} pmark837 : Total Wt F97/98 for Neuspeed RSe102 Gloss Black (20x9.5 ET25 square)/Michelin Alpin 5 SUV (255/45 R20 square) - 214 lbs https://x3.xbimmers.com/forums/showp...4&postcount=63 and tirerack.com for tire wt and neuspeedrswheels.com for wheel wt {Wheel/tire: 53.5 lbs}{Separate wts - Wheel: 23.5 lbs, Tire: 30 lbs} Detailers Domain : Total Wt F97/98 for BMW 827M in "Gold Bronze" (20x10.5 ET20 square)/Michelin PS4S (275/40 R20 square) - 213 lbs https://x3.xbimmers.com/forums/showthread.php?t=2087020 and for the wheel wt- swagon's thread 'G8x M3/4 Alloy Wheel Weight List' https://g80.bimmerpost.com/forums/sh....php?t=1852984 where in the 2nd post, Draper shared this specific wheel's wt - https://g80.bimmerpost.com/forums/sh...55&postcount=2 and tirerack.com for the tire wts {Wheel/tire: 53.2 lbs}{Separate wts - Wheel: 24.2 lbs, Tire: 29 lbs} AJFIllinois : Total Wt F97/98 for Flow One F5 Race Spec (20x10 ET40 square)/Michelin PSAS4 (275/35 R20 square) - 212 lbs https://x3.xbimmers.com/forums/showp...8&postcount=82 {Wheel/tire: 53.0 lbs}{Separate wts - Wheel: 24.0 lbs, Tire: 29 lbs} gapband : Total Wt F97/98 for Flow One F5 (20x8.5 +28 square)/Michelin Pilot Alpin 5 SUV (255/45 R20 square) - 211 lbs https://x3.xbimmers.com/forums/showp...postcount=2843 and https://x3.xbimmers.com/forums/showp...postcount=2847 and https://x3.xbimmers.com/forums/showp...postcount=2852 and tirerack.com for the weights {Wheel/tire: 52.8 lbs}{Separate wts - Wheel: 22.8 lbs, Tire: 30 lbs} BrockDM's Winter 2024 Setup : Total Wt F97/98 for LFI Wheels TRS01 in 'Matte Black' (20x9.5 ET18 square)/Michelin Pilot Alpin 4 N Spec (275/40 R20 square) - 210 lbs https://x3.xbimmers.com/forums/showp...&postcount=135 {Ft wheel/tire: 52.5 lbs, Rear wheel/tire: 52.5 lbs} {Separate wts - Wheel: 22.5 lbs, Tire: 30 lbs} AJFIllinois : Total Wt F97/98 for HRE P101SC (21x10 ET25, 21x10 ET23)/Michelin PSAS4 (275/35 R21 square) - 208 lbs https://x3.xbimmers.com/forums/showp...&postcount=128 {Wheel/tire: 52.0 lbs}{Separate wts - Wheel: 22.5 lbs, Tire: 29.5 lbs} goldfz8 : Total Wt F97/98 for Rays Gram Lights 57CR (19x9.5 +25 square)/Nitto NT555RII (275/40 R19 square) - 207 lbs https://x3.xbimmers.com/forums/showp...1&postcount=57 and https://x3.xbimmers.com/forums/showp...7&postcount=66. Dawgz then purchased this set from goldfz8 - https://x3.xbimmers.com/forums/showp...&postcount=551 and https://x3.xbimmers.com/forums/showp...53&postcount=1 {Wheel/tire: 51.8 lbs}{Separate wts - Wheel: 22.8 lbs, Tire: 29 lbs} BrockDM : Total Wt F97/98 for LFI Wheels TRS01 in 'Matte Black' (20x9.5 ET18, 18x10 ET27)/Nitto NT555RII Drag Radials (275/40 R20), Mickey Thompson ET Street R (305/45 R18) - 207 lbs https://x3.xbimmers.com/forums/showp...&postcount=318 and wheel and tire wts provided by Brock in a PM on 7 Nov 2023, 1011AM {Ft wheel/tire: 53 lbs, Rear wheel/tire: 50.4 lbs} {Separate wts - Ft wheel: 22.5 lbs, Ft tire: 30.5 lbs, Rear wheel 18.4 lbs, Rear Tire: 32 lbs} diirk : Total Wt F97/98 for ORT Motorsport BS-10F in 'Brushed HyperBlack' (20x9.5 ET19, 20x10.5 ET33)/Continental ExtremeContact DWS06+ (275/40 R20, 315/35 R20) - 206 lbs https://x3.xbimmers.com/forums/showp...postcount=3803 and continentaltire.com/tires/extremecontact-dws06-plus/specs for the tire wts {Ft wheel/tire: 49.7 lbs, Rear wheel/tire: 53.2 lbs} {Separate wts - Ft wheel: 21 lbs, Ft tire: 28.7 lbs, Rear wheel 21 lbs, Rear Tire: 32.2 lbs} ---- Weights Not Available (N/A) Yet: mtndog : Total Wt F97/98 for Vossen HF-5 Satin Silver (21x9.5, 21x10.5)/PS4S (265/40 ZR21, 295/35 ZR21) - wt N/A yet https://x3.xbimmers.com/forums/showp...3&postcount=42 satx_yas : Total Wt F97/98 for HRE RC104 (21x9.5 ET20, 21x11 ET35)/PS4S (255/40 ZR21, 295/35 ZR21) - wt N/A yet https://x3.xbimmers.com/forums/showp...0&postcount=43 and https://x3.xbimmers.com/forums/showp...33&postcount=1 and https://x3.xbimmers.com/forums/showp...&postcount=138 w2blw_x3m : Total Wt F97/98 for BC Forged LE72 'Matte Gunmetal centres with Gloss Gunmetal lip & black hardware' (21x9.5 ET20, 21x11 ET35)/PS4S (255/40 ZR21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...10&postcount=1 goldfz8 : Total Wt F97/98 for VS Forged VS06 (20x?, 20x?)/Nitto NT555 (275/40 R20, 305/35 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=420 and https://x3.xbimmers.com/forums/showp...postcount=1020 and https://x3.xbimmers.com/forums/showp...&postcount=417 Vettethret : Total Wt F97/98 for Vossen HF-5 (21x10 ET33, 21x11.5 ET41)/Pilot Super Sport (285/35 R21, 325/30 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...08&postcount=6, https://x3.xbimmers.com/forums/showp...&postcount=112 for more images and his order sheet showing the ET and comment regarding use of H&R 15mm spacers, and for this set on his new X4MC described in his thread 16 Dec 2023 - https://x3.xbimmers.com/forums/showthread.php?t=2068626 . mit_p : Total Wt F97/98 for Japan Racing JR21 in 'Matte Bronze' (21x10.5 square)/Michelin ? style/size - wt N/A yet https://x3.xbimmers.com/forums/showp...4&postcount=34 AlexFL : Total Wt F97/98 for Vossen EVO-3R (21x9.5, 21x10.5)/PS4S (265/40 ZR21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=161 and https://x3.xbimmers.com/forums/showp...04&postcount=1 and https://x3.xbimmers.com/forums/showp...&postcount=157 Will Pwr : Total Wt F97/98 for Volk Racing TE37 - Ultra Track Edition II (20x9.5 +20, 20x10.5 +30)/Falken FK510 SUV (265/40 R20, 295/40 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=976 and https://x3.xbimmers.com/forums/showp...0&postcount=60 jsnkim : Total Wt F97/98 for HRE P101/Pirelli Scorpion P Zero (265/40 R21, 305/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=1065 larsmin : Total Wt F97/98 for Volk Racing Rays G025 (20x9J +25, 20x10J +25)/Pirelli P Zero4 (255/45 R20, 265/45 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=1378 FastPanther : Total Wt F97/98 for HRE P101SC (21x9.5, 21x11)/Pirelli P Zero (265/40 R21, 305/35 R21) - [/B] wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=1389 and https://x3.xbimmers.com/forums/showp...postcount=1394 dapangro : Total Wt F97/98 for Vossen VFS-4 in 'Graphite' (20x9, 20x10.5)/Pirelli Scorpion Winters (255/45 R20, 275/40 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...1&postcount=22 BeamerLife : Total Wt F97/98 for Vossen M-X6 (20x9.5 +16, 20x10.5 +31)/Nitto NT555RII (275/40 R20, 305/35 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=572 and https://x3.xbimmers.com/forums/showp...&postcount=575 hamy : Total Wt F97/98 for HRE FF04 (21x9.5 +30, 21x10.5 +35)/Pirelli Scorpion Zero All Season Plus (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showthread.php?t=1693366 MSUGOGRN : Total Wt F97/98 for BC Forged KL11 (22x10 +24, 22x10.5 +24)/Pirelli Scorpion Zero All Season (275/35 R22, 285/35 R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...7&postcount=37 Mike_OGm2 : Total Wt F97/98 for Vossen HF-5 Satin Bronze (21x9.5 ET16, 21x10.5 ET30)/Contis OEM SpCo6 (255/40 R21, 265/40 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...75&postcount=8 jump2man3 : Total Wt F97/98 for Vossen HF-5 in 'Satin Silver' (22x9.5, 22x11)/Contis SpCo6 (265/35 R22, 295/30 R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...98&postcount=1 and https://x3.xbimmers.com/forums/showp...8&postcount=47 and https://x3.xbimmers.com/forums/showp...7&postcount=49 bylkylov : Total Wt F97/98 for HRE Classic 300 (21x?, 21x?)/PS4S (275/35 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=108 lyjw88 : Total Wt F97/98 for Vorsteiner VFF103 Carbon Graphite (21x9 ET35, 21x10.5 ET40)/Michelin PS4 SUV (265/40 R21, 285/40 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...29&postcount=1 and https://x3.xbimmers.com/forums/showp...02&postcount=3 and https://x3.xbimmers.com/forums/showp...51&postcount=9 and https://x3.xbimmers.com/forums/showp...4&postcount=11 and https://x3.xbimmers.com/forums/showp...6&postcount=14 and https://x3.xbimmers.com/forums/showp...&postcount=143 crst4s : Total Wt F97/98 for Asanti ABL22 (22x9 +32, 22x10.5 +35)/Pirelli Scorpion All Season Plus (265/35 R22, 295/30 R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=366 {Note this is a different Asanti set-up at 22" from the 20" in the weighed section} KodiakEd : Total Wt F97/98 for Vossen HF-2 'Gloss Black' (21x9.5 +19, 21x10.5 +27)/Michelin PS All Season 4 (255/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...48&postcount=1 and https://x3.xbimmers.com/forums/showp...9&postcount=54 and https://x3.xbimmers.com/forums/showp...74&postcount=6 and https://x3.xbimmers.com/forums/showp...0&postcount=13 1StockX3M : Total Wt F97/98 for BC Forged RZ01 (21x9.5 ET17, 21x11 ET35)/Continental SpCo 7 MGT (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...3&postcount=18 and https://x3.xbimmers.com/forums/showp...2&postcount=23 Vettethret : Total Wt F97/98 for Vossen VFS-1 (22x9.5 +21, 22x11 +12)/PS4S (285/30 R22, 315/30 R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...0&postcount=11 and https://x3.xbimmers.com/forums/showp...47&postcount=1 mm3power : Total Wt F97/98 for HRE P101 (?x9.5, ?x11)/Pirelli PZero (?,? size) - wt N/A yet https://x3.xbimmers.com/forums/showp...82&postcount=1 1Volfan : Total Wt F97/98 for Neuspeed RSE103 (? specs)/Pirelli Scorpion Winters (255/45 R20 square) - wt N/A yet https://x3.xbimmers.com/forums/showp...2&postcount=48 2kaccordocoupe : Total Wt F97/98 for Art Replica 181 (20x9 ET35 square)/Pirelli Scorpion Winters (255/45 R20 square) - wt N/A yet https://x3.xbimmers.com/forums/showp...4&postcount=10 GainCypher : Total Wt F97/98 for Vossen HF-1 (21x9 ?ET, 21x10.5 ?ET)/Michelin PS4 AS (255/40 R21, 265/40 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...1&postcount=55 and https://x3.xbimmers.com/forums/showp...6&postcount=18 and https://x3.xbimmers.com/forums/showp...34&postcount=8 aw305 : Total Wt F97/98 for Vossen HF-5 Anthracite (21x9.5 ET17, 21x10.5 ET29)/Michelin PS4S (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...14&postcount=1 and https://x3.xbimmers.com/forums/showp...3&postcount=88 and https://x3.xbimmers.com/forums/showp...39&postcount=7 arosey9 : Total Wt F97/98 for Asanti Black Label ABL-21 GLS Black (20x9, 20x10.5)/Pirelli Scorpion Winters (255/45 R20, 285/40 R20) -wt N/A yet https://x3.xbimmers.com/forums/showp...7&postcount=55 and https://x3.xbimmers.com/forums/showp...8&postcount=56 and https://x3.xbimmers.com/forums/showp...5&postcount=58 JLT : Total Wt F97/98 for Vossen HF-5 (22x9.5 ET18, 22x11 ET21)/Continental ExtremeContact DWS 06 Plus (285/35 R22 square) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=199 and https://x3.xbimmers.com/forums/showp...&postcount=198 Koturbo : Total Wt F97/98 for BC Forged MLE10 in 'Color-matched lip and Satin Black centers' (21x?, 21x?)/Continental Sport Contact 5P (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...25&postcount=1 Frio11 : Total Wt F97/98 for Vossen HF-5 in 'Gloss Black' (22x?, 22x?)/Vercelli Strada IV (265/35 R22, ? R22) - wt N/A yet https://x3.xbimmers.com/forums/showp...53&postcount=1 gjodexter : Total Wt F97/98 for Vossen HF-3 (21x9.5 Et16, 21x11 Et35)/Michelin PS4S (255/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...1&postcount=53 larsmin : Total Wt F97/98 for BBS LM Custom Spec, Diamond Black (20x9 ET10, 20x10 ET23)/Pirelli PZero PZ4 (255/45 R20, 265/45 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...4&postcount=70 and https://x3.xbimmers.com/forums/showp...postcount=1232 NLYFANSX3M : Total Wt F97/98 for BC Forged RZ05 (21x9.5 ET17, 21x11 ET35)/PS4S (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=480 and BrockDM for indicating the RZ05 specs at https://x3.xbimmers.com/forums/showp...&postcount=484 {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 30 lbs, Rear wheel: ? lbs, Rear Tire: 31 lbs} bad430benz : Total Wt F97/98 for Ferrada Forge-8 Series FR5 Silver, powder-coated 'Highland Bronze' (21x9 ET25, 21x10.5 ET40)/Lionhart LH-FIVE Ultra-high Performance AS (265/40 R21, 295/40 R21) – wt N/A yet https://x3.xbimmers.com/forums/showp...32&postcount=5 and https://x3.xbimmers.com/forums/showp...43&postcount=9 and https://x3.xbimmers.com/forums/showp...3&postcount=84 and https://lionharttires.com/tire/lh-five/ for the tire weights. {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 35.23 lbs, Rear wheel: ? lbs, Rear Tire: 36.97 lbs} Stereolab42 : Total Wt F97/98 for Vossen HF-2 'Gloss Black' (21x? ET?, 21x? ET?)/Michelin PS4S (265/40 R21, 295/35 R21) – wt N/A yet https://x3.xbimmers.com/forums/showthread.php?t=2040763 ThirstyX3M : Total Wt F97/98 for BC Forged HC010 in 'Brushed Carbon Gray, black hardware and polished lip' (21x10 ET33, 21x10 ET30)/Conti ExtremeContact DWS06+ (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=1573 and https://x3.xbimmers.com/forums/showp...postcount=1575 and continentaltire.com/tires/extremecontact-dws06-plus/specs for the tire weights {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 29.6 lbs, Rear wheel: ? lbs, Rear Tire: 30.3 lbs} Brandt51 : Total Wt F97/98 for HRE FF10 in ‘Satin Gold’ (21x9.5 ET30, 21x10.5 ET35)/Michelin PS4 AS (265/40 R21, 295/35 R21) – wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=3623 and PM from Brandt51 on 29 Nov 2023 updating the wheel specs (sans weight) and tirerack.com for the tire weights {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs}{Separate wts - Ft wheel: ? lbs, Ft tire: 30 lbs, Rear wheel: ? lbs, Rear Tire: 33 lbs} 21X3Mcompetition: Total Wt F97/98 for ? Manufacturer and ? Style/Model Name or Number (20x9.5 ET16, 20x11 ET36)/Michelin PS4 SUV (265/45 R20, 305/40 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...89&postcount=9 , https://x3.xbimmers.com/forums/showp...7&postcount=10 , and https://x3.xbimmers.com/forums/showp...4&postcount=14 Thtshowiroll47 : Total Wt F97/98 for Vossen HF-2 'Satin Bronze' (21x9.5 +17, 21x11 +35)/Michelin PS All Season 4 (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...15&postcount=9 and https://x3.xbimmers.com/forums/showp...postcount=3663 and https://x3.xbimmers.com/forums/showp...87&postcount=6 and https://x3.xbimmers.com/forums/showp...46&postcount=9 and PM from Thtshowiroll47 on 14 Mar 2024 1119AM confirming tire sizes. kregers : Total Wt F97/98 for Volk Racing Rays GT090 (21x10 +26, 21x11 +30)/ Continental SportContact 7 (265/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...&postcount=185 and tirerack.com for the tire wts {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 29 lbs, Rear wheel: ? lbs, Rear Tire: 32 lbs} JaCole9 [his brother, SM2, shared the details] : Total Wt F97/98 for Advan ADV.1-ADV5.0 in ‘Platinum’ (20x10.5 ET32 square)/Michelin PS4 SUV (265/45 R20, 275/45 R20) - wt N/A yet https://x3.xbimmers.com/forums/showp...63&postcount=1, https://x3.xbimmers.com/forums/showp...69&postcount=7 and tirerack.com for the tire wts {Wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts - Ft wheel: ? lbs, Ft tire: 33 lbs, Rear wheel: ? lbs, Rear Tire: 34 lbs} bad430benz : Total Wt F97/98 for BBS LM409 & LM410 ‘Diamond Silver' w/ 'Nardo Grey face finish & Black hardware' (21x9 ET22, 21x10 ET40)/Accelera IOTA ST68 (255/40 R21, 285/35 R21) – wt N/A yet https://x3.xbimmers.com/forums/showp...76&postcount=1, https://x3.xbimmers.com/forums/showthread.php?t=2106445, and www.bbs-usa.com for the wheel wts {Ft wheel/tire: ? lbs, Rear wheel/tire: ? lbs} {Separate wts – Ft wheel: 29.4 lbs, Ft tire: ? lbs, Rear wheel: 29.4 lbs, Rear tire: ? lbs} Last edited by Max Well; 05-23-2024 at 04:44 PM.. Reason: Added to the list |
16
Edgar_FriendlyX3M610.50 Travisbach238155.50 2Times1065.50 dmanb2b2134.00 Chubbiejones894.50 BrockDM2051.50 Radman_F97249.50 ando2006.00 ///minh564.00 Jason41356.50 J-Pizzle127.00 Gfit2759.50 gapband240.00 BimrCA0.00 floating.spirit1017.00 Will Pwr750.00 |
08-27-2022, 03:11 PM | #2 |
Rep 3,361
Wow, Vossen combo dropping 10lbs of unsprung weight per corner...must feel like a different car!
Max Well4814.50 floating.spirit1017.00 |
08-28-2022, 10:02 AM | #3 | |
Rep 2,558
Didn't realize the number of different combinations of styles and sizes Members have opted for until I started making this list. Hoping we'll be able to fill in the pending weights over time for a more complete picture of the weight range top to bottom. |
dmanb2b2134.00 |
08-29-2022, 09:55 AM | #4 |
Rep 1,000
I love this thread already haha. I'll have BC forged weights for you soon as well as a 20x10 - 275/40 squared setup in the near future too. My winter setup just landed today.
Thanks for doing this! It deserves a sticky
Max Well4814.50 |
08-29-2022, 10:55 AM | #5 | |
Rep 2,558
08-31-2022, 06:42 PM | #6 |
Rep 1,000
Ok I have some updates!
Unfortunately I don't have pics on the scale due to the width of the tires covering the display. My BC Forged setup that you have above is as follows: Front Wheel - 25.6lbs Front Tire (PS4S) - 30lbs Rear Wheel - 26.8lbs Rear Tire (PS4S) - 31lbs Grand Total for the set: 226.8lbs Im in the process of ceramic coating my winter setup but it should be ever so slightly lighter than these. Will report back when I have photos and such!
Max Well4814.50 |
09-01-2022, 06:23 AM | #7 | |
Rep 2,558
Very helpful to have the separate wheel and tire weights as well, as we'll be able to use those tire weights to come up with sum totals for Members who might've only weighed their wheels. As example, I think Kozumasbullitt shared just his wheel weights somewhere but I'll have to look for that. {Edit 0744AM - found it: https://x3.xbimmers.com/forums/showp...6&postcount=48 , so I'll now be able to add his info to the completed list} I've also started showing the Ft and Rear wheel/tire separately to aid in more detailed comparison. Last edited by Max Well; 09-01-2022 at 06:45 AM.. Reason: Added link to Kozumasbullitt wheel weights |
BrockDM2051.50 |
09-01-2022, 02:46 PM | #8 |
Rep 1,363
Drives: '17 340i & '18 M2
Vossen HF5
Satin Bronze finish 21x9.5 ET +16 Deep concave 21x10. 5 Deep ET +30 Deep Concave Stock Conti rubber (for now) H&R springs |
09-01-2022, 02:53 PM | #9 |
Rep 1,000
What do they weigh?
09-01-2022, 03:03 PM | #10 |
Rep 1,363
09-01-2022, 05:23 PM | #11 | |
Rep 2,558
Last edited by Max Well; 09-02-2022 at 11:16 AM.. Reason: Added to the pending list note |
09-13-2022, 05:57 AM | #12 |
Rep 2,558
Appreciation to @crst4s who documented weights on two different 20" wheel combinations (which I found this morning buried in a thread back in 2020). I've added these to the documented weight list, now up to 9 combinations, and we're up to 26 others with pending weights.
As Fall approaches and Winters start going on up North, if others can place even on a bathroom scale when they make the change it'd help to fill out the pending list. Screen grab of the spreadsheet with crst4s's data entered: |
09-16-2022, 06:19 AM | #13 |
Rep 158
Vossen HF2s
Here is my info. Offsets were to mimic 12mm spacers.
2022 X3MC MBB (mine), 2021 X7 40i BSM (wife's), 2014 640i BSM (sold)
Build page --> https://x3.xbimmers.com/forums/showthread.php?t=1849502 Last edited by KodiakEd; 09-16-2022 at 07:10 AM.. |
09-16-2022, 07:42 AM | #14 |
Rep 2,558
Excellent, KodiakEd - thanks for sharing! Really helpful to also see your formal order details as wheel sizes and offsets can be confusing for some of us with limited experience in sizing. And if you get a chance to weigh them sometime if they have to come off, would be interesting to see where they land in the weight range we have so far.
09-18-2022, 01:32 PM | #15 |
Rep 2,221
Hey Max Well.
Per my PM, I have not yet weighed the BBS CI-Rs but will do so in Nov before I put them on. For my previous Drag Wheel setup: Tires: 255/45R-20 PIRELLI SCORPION WINTER XL https://www.tirerack.com/tires/tires...=545VR0SCORWXL TPMS Sensors (Tire Rack – no link): HUF RDE077 Wheels: Drag DR-77 20x9, 22mm offset https://www.discounttiredirect.com/b...-dr-77/p/62919 Weight per wheel + tire = 64 lbs Total weight (x4 wheels/tires) = 256 lbs |
Max Well4814.50 |
09-18-2022, 05:16 PM | #16 | |
Rep 2,558
09-19-2022, 10:10 AM | #17 |
Rep 2,558
BrockDM, just came across your brief mention of the TSW Bathursts with OEM PS4S in your build thread https://x3.xbimmers.com/forums/showp...5&postcount=33 . I don't know much about the company but seems like a fairly reasonably priced option for those wishing to stay OEM tire size yet still get some weight savings without breaking the bank?
Did you ever happen to get an image with them mounted (sorry if I missed it)? Can you comment on their quality c/w with other similarly-priced brands? |
09-19-2022, 03:31 PM | #18 | |
Rep 1,000
TSW has been around for quite a while and they have a nice selection of wheels. They are flow formed and great quality for the price. Especially their RotaryForged series. I had them refinished in a custom Hyper Gunmetal so here are a few pics.
Max Well4814.50 Radman_F97249.50 |
09-20-2022, 06:28 AM | #19 | |
Rep 2,558
On a side note, curious if you or others know Chi-X4M's Wheel and tire Mnfr/model names which he shared at https://x3.xbimmers.com/forums/showp...13&postcount=9 ? I've been wanting to add his info to the pending list (22x10 +30, 22x11 +30)/(275/35 R22, 315/30 R22) but despite downloading the images and zooming, and reviewing Vossen, Vorsteiner, HRE, TSW, BC-Forged... I haven't been able to conclusively nail down which model, and the tire details become too fuzzy when zoomed. I sent a PM but haven't received a reply or 'read' notice so not sure how often he checks in. Thanks in advance for any assistance on the mystery. |
09-20-2022, 09:22 AM | #20 | |
Rep 1,000
I can't tell right off the get go what wheels they are but I'm sure I can find something. Tire looks like Pirelli P Zero All season for sure. They have the tri section of velvet around the sidewall and come in that size. Not many do. Will report back!
Max Well4814.50 |
09-20-2022, 01:04 PM | #22 | ||
Rep 2,558
With your wheel info and BrockDM's note of the tires, I was able to look up the weights so have now added to the known list. Thanks to you both for assisting in developing the Members' list. |
