11-09-2022, 01:48 PM | #67 |
Rep 913
Drives: 2022 X3 M40i LCI
Unfortunately the instructions I’ve now been sent don’t even appear to be for an X3 LCI and all the wiring appears to be plug and play with no bare pinned wires. I’ve messaged the seller but I’m beginning to think I’m not going to be getting anywhere with them.
The videos posted in this thread show two bare pinned wires and a supplied plug to re pin an original plug and then connect using the supplied plug the remaining bare pinned wires together. Anyone else who has fitted these buttons let me know if their kit came with 3 bare pinned wires and if so where they go please?
2022 X3 M40i LCI. Brooklyn Grey Metallic. Driving Assistant Professional. Black with Blue Stitching Vernasca Leather M Seats. Comfort Pack. Pano Roof. OEM Carbon Fibre Interior Trim. 21” 718 Alloys.
11-10-2022, 12:32 PM | #68 | |
Rep 60
Armonica28.50 |
11-10-2022, 12:38 PM | #69 |
Rep 60
But unfortunately, as have been mentioned in this thread, moving seat and windows are PAIN to deal with, I am thinking of uninstalling this module. It is a shame because buttons themselves work perfectly, if only there was a way to disable moving seat
Armonica28.50 |
11-10-2022, 03:44 PM | #70 | |
Rep 913
11-10-2022, 09:01 PM | #71 |
Rep 60
Oh, yours is completely different, very interesting. But looks easy as well. Instead of just taking one wire 12 out of big plug you take three wires out - 10, 12 and 11 and insert them into supplied 3 pin plug (A) that then connects to harness (B) and then you take three bare pin wires coming from the harness and insert them in place of the original wires you just taken out.
Shaun1701088.50 |
11-11-2022, 03:12 AM | #72 | |
Rep 913
11-12-2022, 03:17 PM | #73 |
Rep 913
Fitted today. Was very simple in the end really, took about an hour to do. I would say easier looking than other kits out there. Far less plugging and unplugging to do. Re pinned the original single plug under the shifter with the wireless module. Steering wheel for me was easy to do as I’ve already replaced the trim for carbon and replaced the paddles with G80 ones so I knew where all the screws were to get the trim off. Other than a connection issue of my own doing it went really well.
So this kit only changes the drive mode, it doesn’t change the levels within each mode like others I’ve seen. So you can scroll between Eco Comfort and Sport that’s it. Can’t adjust between individual or sport plus or standard. Which is fine for me as I normally drive around in Eco but then like Sport Plus occasionally, now to change is a simple two button press on the steering wheel rather than look or fumble around down by the shifter (although I was told today that voice activation can be used to change the modes) If you press the M buttons more than once too quickly it doesn’t change, maybe confuses the wireless side of it perhaps? It also doesn’t move the seat on ignition off or close the windows which is also good as I didn’t want that anyway and it didn’t come with the two silver lower steering wheel trim pieces which again was ok for me as I didn’t need them. It also looks good in my opinion. Overall I’m pleased. £81.12 25% Off | For BMW new 3 Series g20 g28 5 Series g30 g38 M1M2 button x3 x4 X5X6 steering wheel cover modified driving mode switching module https://a.aliexpress.com/_mMJ68nm This was the only seller who could guarantee the correct top trim part with the long fixing tabs. When I questioned where some wiring and the silver trims were as shown in the pictures, seller said they were just stock photos and not representative of the X3 kit. Seller was very helpful with tips and instructions on fitting.
11-12-2022, 05:56 PM | #74 | |
Rep 25
11-13-2022, 02:36 AM | #75 | |
Rep 913
This is how it came from the factory
11-27-2022, 02:06 AM | #76 |
Rep 2,115
ocdx30.00 gofastbmw5100.00 |
11-27-2022, 07:57 AM | #77 |
Rep 913
Yes after using it I have realised that. Which is perfect for my needs.
11-27-2022, 04:34 PM | #78 | |
Rep 2,115
FWIW, I'm going to take a little different route, with just purchasing the electronic "modules" only from him, since i've already sourced the brand new OEM M1/M2 buttons, and going CF top cover from AutoTecknic. |
01-07-2023, 05:41 PM | #79 |
Confused
123
Rep 103
Drives: 2019 X3 M40i
I'll add mine to this thread if people need references. Easy from ordering to install. It added comfort access and I guess the windows will auto close at the end of a trip now
@G01_M40i | 2019 X3 M40i - Vossen HF-5 | MHD Stage 1 | xHP Stage 3 | MST Intake | (not fast enough)
Shaun1701088.50 lakerzfan_24695.00 |
01-16-2023, 04:45 AM | #80 |
Rep 53
I'm looking for this retrofit, it's exactly what i want for mode handling but I found X3M steering wheel by ~650$ and doubt if it's good alternative.
More expensive but - Not require to do nothing over the center console. - Require coding but you get same M buttons as X3M. - You can resell the original steering wheel (w/o airbag). Cracy idea or worth it? Last edited by Armonica; 01-16-2023 at 05:53 AM.. |
01-16-2023, 08:27 AM | #81 | |
Confused
123
Rep 103
The install of the retrofit is way easier than most people think. Center console pops off in like 2 pulls and the whole install can take a half hour. Plus, I kind of prefer having the buttons switch driving modes instead of just a driving preset like they are on the Ms.
01-24-2023, 12:43 AM | #82 | |
Rep 2,115
01-24-2023, 12:46 AM | #83 |
Rep 2,115
01-24-2023, 05:28 AM | #84 |
Rep 913
The M stands for memory. So memory button 1 memory button 2. I don’t think it has to do with BMW M as in M for motorsport.
js_orifici122.50 |
01-24-2023, 02:45 PM | #85 | |
Rep 318
Good afternoon... do you have the right parts needed to get my steering wheel like yours?
Carbon Fiber trim Shifters M1/M2 Buttons Just mine is left driving side. Thank you Quote:
01-24-2023, 03:29 PM | #86 | |
Rep 913
Trim - BMW 32302471439 Shifters - AE https://a.aliexpress.com/_mOgIwqK (type C gloss) M1/M2 buttons - AE https://a.aliexpress.com/_mLomt6e
01-25-2023, 09:32 AM | #87 |
Rep 506
Has anyone installed the modules utilizing the OEM buttons instead of the buttons that come with the kit?
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
01-25-2023, 10:19 AM | #88 |
Rep 913
I’m not sure it would work. The wiring for the buttons connects to the wireless sender that sends the signal to the box of tricks that plugs into the buttons in the centre console. Without the kit buttons I’m guessing the wireless sender won’t get supplied? The OEM buttons might have different wiring and possibly connectors. Can you tell from the photos I posted of my kit?
