06-25-2022, 09:26 AM | #1 |
Rep 1,769
Drives: 2022 X3 M40i
BMS Oil Catch Can install
Thanks to AusX3 I ordered a BMS OCC from https://x-ph.com/burger-tuning-oil-c...b58-s55-s63tu/ (free shipping).
Was considering the Vargas OCC but I didn't want to take the chance the lines wouldn't fit since it comes with compression fittings. I trimmed the plastic so the bracket would fit better and I ordered 19mm hose https://www.amazon.com/dp/B094GMMDT4...t_details&th=1 to complete the install as the one with the kit will be short as the kit is for a G20. FYI the kit without an aftermarket intake comes with a plug to replace the intake muffler to create room from the stock intake pipe. The OCC does clear the shock tower and it shouldn't rub. I found other OCC kits but at least this one comes with a bracket and the 90 degree adaptor that clicks into the stock hose from the top of the valve cover so its PnP. Just need a small worm clamp to keep the one hose from coming off. Last edited by Burr001; 06-25-2022 at 09:39 AM.. |
dinan5m34263.50 AusX3156.50 X3rd Time Is a Charm2812.50 Must_Go_FASTER502.00 Rottweiler3981.50 _ink619.00 abbike18699.50 |
06-25-2022, 10:39 AM | #2 |
Rep 2,067
trail blazer!
Burr0013251.00 Chief Orman671.00 |
06-25-2022, 09:14 PM | #3 | |
Rep 125
It's great sharing but then get nervous sharing in case the next user does not have a good experience, so this is good! |
Burr0013251.00 |
06-25-2022, 10:21 PM | #4 | |
Rep 1,769
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 Last edited by Burr001; 06-25-2022 at 10:29 PM.. |
AusX3156.50 Chief Orman671.00 |
06-26-2022, 11:34 AM | #5 | |
formerly rdougherty85
502
Rep 455
Thanks for posting, this helps me visualize the install a bit better. |
Burr0013251.00 |
06-26-2022, 04:39 PM | #6 | ||
Rep 1,442
06-26-2022, 07:45 PM | #7 | |
Rep 1,769
After installing it and taking off to the next stop sign, the turbo noise was so much louder and then the wastegate dumped, I pulled over and thought the f'ing filter popped off or I broke something. But who knows, Its BLUE, just BLUE Chief. If you want I can send you my K&N filter(its RED) and you can have that sit on the floor next to your desk and cool parts.lol BTW those hose clamps in 19mm don't fit ,too small, OD of the hose i Ordered is 27mm FYI. |
06-27-2022, 09:33 AM | #9 | ||
Rep 366
I agree the intake made a difference in acceleration according to the butt dyno. First time I heard that turbo whoosh; I did the same thing! Pulled over and popped the hood, thought something was "wrong". Chief they make a RED intake you can order and keep in your office for a few months…. 🤔😂 |
Burr0013251.00 |
06-27-2022, 09:35 AM | #10 | ||
Rep 1,769
06-27-2022, 09:04 PM | #11 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
AusX3 how long have you had yours installed for? Have you had any blow by oil in the can as yet?
06-27-2022, 09:19 PM | #12 | |
Rep 125
I pulled the inlet line hose off and didn't feel anything on the internal of the hose. I have a dyno session and some works planned for the 6th July so will take another look then |
_ink619.00 |
06-29-2022, 12:29 AM | #13 |
619
Rep 3,021
Nice, do keep us posted!
06-30-2022, 02:34 PM | #14 |
Rep 1,769
the hose I got from amazon was triggering my OCD, so I got a 90 degree hose from the b48 and it fits better and used those t-bolt clamps to make sure hose stays on and seals better.
07-25-2022, 05:20 PM | #15 |
Rep 1,769
Update:
So I wanted to put a small piece of foam as extra protection from rubbing on the shock tower as vibration might cause it to move. It has been 30 days after installing the OCC and about 1800 miles of driving for the month, I found very light film of oil in the OCC. |
02-10-2023, 09:02 PM | #17 |
Rep 554
Burr001 what's the inside of the can look like now?
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
02-11-2023, 10:51 AM | #19 |
Rep 1,769
Here is whats inside the OCC since I installed in June/July of 2022 I think with 11k miles and 2 oil changes if that means anything.
02-11-2023, 10:53 AM | #20 |
Rep 554
Nice thanks for posting! That's a good reference point. All that stuff isn't on your intake now!
Burr0013251.00 |
02-11-2023, 11:03 AM | #21 |
Rep 1,769
08-02-2023, 04:17 AM | #22 |
Rep 5
Drives: 2022 X3 sDrive30i LCI G01
Thank you for your amazing post and recommendation. Gives a lot of support and confidence for my project.
Where did you get your strut bar? It looks great. Also, I notice that when ordering the catch can, it says something like "requires BMS intake." I am running with aFepower GT Momentum intake so will this oil can setup not work?? Instead of installing rubber piece, wonder if oil can fits into a beer can koozie to keep it from making noise 😄 |
