04-02-2022, 02:39 PM | #1 |
Rep 30
Is it normal for the car fans (radiator fans maybe?) to run after car off?
It doesn't always do it but probably 3 times in the 5 months I've had it that I've noticed after I park and turn off the car, the sounds of a fan stay on for a minute or two after. Is this normal? 2022 x3 m40i
04-02-2022, 03:33 PM | #2 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3563
Rep 4,248
Completely normal to continue cooling engine. Your auxiliary water pump runs too and continues cooling turbocharger. It's all part of the strategy for optimizing engine life
ironxcross22.00 hooligan_G016431.50 |
04-02-2022, 04:42 PM | #3 |
Rep 30
04-26-2022, 12:40 PM | #4 |
Rep 280
Drives: 2023 M3 Comp
That just means you're driving it correctly. I try to always drive it hard enough to keep the fan running after it's parked.
04-26-2022, 09:18 PM | #7 |
Rep 75
Totally normal and X3 M40s have been doing it since the start in 2018. If I give the car a good "work out" I'll try to drive it a bit soft before turning it off. As Summer approaches in the northern hemisphere you'll be able to hear it after just regular driving.
