12-11-2021, 11:36 PM | #1 |
Rep 35
Cargo Management Systems
Anyone have any cleaver solutions to securing items in the back?
I'd usually use bungee cords, but the hooks available are worthless. I bought a bar to try and pinch against the sides of the trunk (see picture), but the trunk liner is too flimsy to push against. I have the spare tire so there are no rails to attach to, was hoping there was a system I could buy that would keep items from sliding around. I tried to search the forum, but no luck. |
12-12-2021, 12:22 AM | #2 |
Rep 632
Just use these since you have that trunk mat. They work well and you can get away with just 1 or 2 most of the time.
https://www.weathertech.com/cargotech/ |
12-12-2021, 02:49 PM | #3 |
Rep 5,469
Was just going to ask the same question, the moron at BMW that designed the spare tire raise floor should be fired, shit just falls out all the time when I open the back door. Coming form an X5 with the split tailgate which is better, but even the x3 I had back in 2013 was better as without the raise floor, the floor is just a bit lower than the opening. The BMW mat has about a 1" lip which may be better than the weathertech one but still not enough. I was thinking of exactly what you did with a bar across the back, so guess I won't try that. Was also thinking a cargo net, something like this https://www.amazon.com/CARTMAN-Hammo...cont06-20&th=1
It could attach to the lower cargo tie downs and then mount the buttons on the side, at least keeps stuff in, other though was a couple of the collapsable bins BMW sells that stick down and don't move but fold flat when you don't need the. It seems BMW has decided since it is an M car you can't possibly need to put stuff in the back and since it is an M car it flies around way more since you can drive it way harder. Also nice that they delete the cargo track when you get the spare to make it so you can do just a 5 corner mounted floor cargo net.
2025 X5 Msport
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
X3mcesq57.00 |
12-12-2021, 08:08 PM | #4 | |
Rep 35
12-12-2021, 08:14 PM | #5 | |
Rep 35
I didn't realize how much trunk space the spare tire takes up. Sure it's only a few inches high, but because of the slope of the rear seats it takes a big chunk of useable space out. It would be nice if BMW came up with a better way to store the tire and still keep the rails, I miss them as well. |
