11-04-2021, 09:03 PM | #1 |
Rep 124
Drives: 2022 BMW X3M
Bimmercode for X3M '22 LCI
Hey guys I'm trying to connect my '22 X3M to Bimmercode via the ENET cable but it's not connecting. I turned off wifi, Bluetooth and but the phone in airplane mode and nothing. I'm assigned an IP address but when I press connect I keep getting this notification in the picture attached.
Any help? [IMG][/IMG] |
11-05-2021, 06:56 AM | #2 |
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
1. make sure under settings that the adapter is selected as "ENET cable"
2. go to iOS settings, click Bimmercode, and make sure the Local Network toggle is enabled. 3. if you have iOS 15 you're screwed.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
11-05-2021, 09:03 AM | #5 | |
Rep 900
Get the bluetooth OBD connector, I also tried through ENET and could not get it to work, it works fine with the OBDLink CX (that is what I purchased)
'23 M3 Comp xD, IoMG...
11-05-2021, 09:33 AM | #7 |
Rep 124
I was just looking for anything interesting to code. Ended up just coding a few things. Like auto lock in 10 seconds instead of 2 minutes. There's also a setting that gives you more presets under "sound" like if you had the B&W sound system.
11-05-2021, 01:14 PM | #8 | |
Rep 4,393
i’ll update to ios 15.1 i suppose tonight. hopefully it works.
11-05-2021, 07:13 PM | #9 | ||
Rep 124
11-07-2021, 10:03 AM | #10 |
Rep 1,701
I had to check the box of "share internet through ethernet" for it to work.
11-10-2021, 11:32 AM | #11 |
Rep 1,495
Following up on this thread, I purchased the cheap Mfi-rated Ethernet adapter below and can confirm it works on an iPhone 12 Pro running 15.0.2
Just coded a few minor things via BimmerCode https://www.amazon.com/dp/B099K2B2YJ...UTF8&psc=1
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
