08-30-2021, 02:15 PM | #1 |
Rep 4
How to configure X3 power tailgate lift
I just replaced a defective power tailgate strut on the right. Symptom: It closes when I push the button on the tailgate. It unlatches when I use by FOB or push the button inside the vehicle. But it does not open up. After a second it re-latches and pulls the door tight. When I use the FOB and it unlatches and I immediately manually lift the door, it opens all of the way to the top. Again if I hit the button on the tailgate it closes.
How do I configure it to properly open and close without taking it to the dealer? I've seen the coding instructions posted elsewhere but would like to avoid that. Thanks, Rob |
08-30-2021, 02:28 PM | #2 |
Rep 1,933
Take a look at the 'settings' function via your iDrive, one can 'set' the lift height of the tailgate....maybe it's not set properly - that may be all that's needed.
Settings>Tailgate |
