07-29-2021, 12:48 PM | #1 |
Rep 8
Installed 20" 469M Wheels and H&R Springs on F25 X3 xdrive35i
Installed set of 20" 469M wheels (off of x5 M-sport) on my F25 X3 xdrive35i. Currently have Pirelli RF's on them that will be swapped out.
Also installed H&R Sport Springs. Fronts needed 5 mm spacers, ordered and installed from BimmerWorld. Notes: Springs feel great. Front right tire was rubbing plastic on full turns so I modified a bit. Rears rub plastic slightly on larger dips when springs are compressed, not enough to mod. Coming from 19"'s and NRF tires I feel the added weight. Need to swap to NRFs asap. Mod list: VRSF Catless DP Stage 2 MHD Tune Dry Filter 20" 469M wheels H&R Sport Springs |
04-26-2023, 10:11 AM | #4 |
Rep 212
Quick question for OP: I am thinking about going with this setup and here are my questions:
what hub centric rings did you use to fit these 469M wheels? Did you experience any issues with transfer case after installing them? Did you notice any difference in acceleration, steering feel since these are wider and weight more than the regular setup? Thank you for your input.
F25 X3 35i
981 Cayman S 6speed Past Cars: 02 E46M3 SMG; 98 E36M3/4/5; R56 Cooper S 6speed 17 ZCP F80M3; F36 435i; E93 335i; E46 330Ci 6Speed |
05-03-2023, 12:12 AM | #6 | |
Rep 12,567
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
https://www.ecstuning.com/b-hd-tunin...our/74726~hdt/ |
01-08-2024, 12:12 PM | #7 | |
Rep 1
Tags |
bmw, f25, n55 |
