06-15-2021, 12:32 AM | #1 |
Rep 71
Identification question
Where to begin......
I bought my daughter a 2013 X3 xdrive 28i. Has a late 2012 build date on it. First car... Recently it started to throw the notorious limp mode. Also throwing occasional code about cam sensors. Replaced both sensors, and it going into limp mode more and more. Fearing the worst, I bought a timing chain replacement kit, along with the stupid expensive tools...that will probably only be used once! Following the directions per a great video from a vendor, I'm cruising through the process, until I get UNDER the car... NOTHING is like the directions show. I am not able to find the plastic loop/plug to pull for locking the crank. No kidding...I've searched for hours now, looking and feeling. Nothing. The oil pan is aluminum, vs plastic. And it appears to be integrated into the front axle assembly. I could be wrong about that...but I looked for ANY seam along there, and couldn't find one. Been searching here, and so far all I have been finding is talk about the lawsuit. Just wondering if anyone can tell me "what I have"... Documentation says N20. I haven't been able to find any different documentation regarding variances in build dates or anything. All articles I've read, images show other than what she has. All videos I've watched, show other than what she has. So right now, I'm half tore down, and really need any solid information available on what the proper process for changing this chain will be for this configuration. Thanks!
2016 Glacier Silver 328d Msport Xdrive wagon - Kerma Tune bench flashed - SOLD
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler 1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress. Last edited by graphicjunkie; 06-15-2021 at 12:52 AM.. |
06-15-2021, 01:14 AM | #2 |
Rep 1,933
You would benefit from accessing the BMW Technical Information System (TIS)...the 'free' site was shutdown by BMW Corporate as it was an illegal site.
You can pay to access the authorized BMW TIS site, look here https://www.bmwtis.com/#/login This is the database of all vehicles and contains detailed step by step repair instructions for virtually any possible repair - it's the reference BMW shop Technicians use. Good luck/Bill |
06-15-2021, 08:35 AM | #3 |
Rep 2,928
To answer the simple part of your question, if your car has 4 cylinders it is an N20. That's all they used. I have a 2014, and although I have changed the oil several times I have not paid too much attention to what the oil pan looks like. But if you find the oil drain plug, it is threaded into the oil pan.
06-15-2021, 08:40 AM | #4 |
Rep 2,928
I assume you've seen the DIYs like this one? Not an X3 but that should not matter besides different airboxes or whatever. And it's easy to find pictures of N20 oil pans online.
https://blog.fcpeuro.com/how-to-repl...part-1-removal |
dtox9351.00 |
06-15-2021, 10:50 AM | #5 | |
Rep 223
06-15-2021, 08:32 PM | #7 | |
Rep 71
That was actually the vendor I bought it all from, and the tutorial that I was watching. Just didn't know if it was cool to call them out. It is a 4 cylinder, and I know that the engine it's self is an N20 from everything I've researched...and at this point, that has honestly been quite a bit. Trying to figure out if there were variants of the engine used, and if so, does the timing chain process change. More specifically, the oil drive lower portion, as you need to access the lock mechanism by the screen. The fact that the oil pan is plastic or metal is a moot point in its self...other than the oil pan seems integrated into the front transaxle/transfer case in this scenario, and in every bit of documentation I have found, not the case. In the video, there is a thin inspection cover with 3 bolts (if I recall) that is flat and kind of half circle shaped, that if you slide it out, you can see where the flex plate lock engages, as well as he states that you can see where the pin engages. This thing has no such inspection cover to remove. Not to mention that every image I have seen for this engine, shows the plastic oil pan, with the allen head plastic drain plug. This again is aluminum, with a 17mm drain bolt. As I'm writing this, describing the pan made me think of just searching for it specifically by its self...and this is exactly what it looks like. https://www.ebay.com/itm/35344001966...8AAOSwdGxgZixl Even that shows that it's the "right" engine. But I find no reference to this configuration otherwise. As far as troubleshooting, this is leading up to worst case scenario. But I started with the free/cheap/easy stuff, and have worked my way up to believing that it's the timing chain. Although interestingly enough, nothing I have read up on so far has mentioned the valvetronic motor as possible problem per the symptoms. Being it was throwing limp mode only (at first), I read up on the common issues, and started addressing. Once I got to replacing the cam position sensors, THEN it actually threw a check engine code, for timing out of spec for the intake side. From there, it seemed like everything pointed at the timing chain. I did find one video where the guy skipped the locking pin that I have been chasing for a ridiculous amount of time. Ironically, he ended his video by saying he had to replace his engine, "due to other issues". Is that the truth, or did he just not want to admit that it caused jump and trashed his engine? I don't know. But even his was the plastic pan version. As for the bmwtis site... I'm not cheap, but I think that paying $30 a DAY for subscription based services is asinine, and absolutely raping people. I know I'm "In need"...but I refuse that bs. Now if I was running a business, then fine. Good tax write off @$2500/year.
2016 Alpine white 535d Msport - Kerma Tune, CF rear spoiler 1975 Corvette 496 stroker, ridetech suspension, ATSpeed R-man valve body TH400 - in progress. |
06-15-2021, 08:36 PM | #8 |
Rep 232
N20 with Xdrive has a front axle that passes through the oil pan which makes it a total pain in the ass to remove. The video from FCP euro is not an Xdrive car so it doesn't have a front differential shoving the front axel through the pan.
06-15-2021, 08:51 PM | #9 | |
Rep 1,933
Good luck/Bill Last edited by Wgosma; 06-15-2021 at 09:11 PM.. |
06-16-2021, 12:44 PM | #11 |
Rep 1,933
I can access the site, but as I recall i was 'registered', so to speak right around the time the site was being shutdown. I think right now not just anyone can log on, tho I might be incorrect (?)
